CJ Miller
Posted: Sat Jun 21, 2008 6:06 pm Post subject:
| If I shave about 1mm off of the corner of the socket, near pin1, I can fit Q6 and - just barely - a 28-pin shrink DIP socket. I bought these for the SN voive, but they didn't fit. Nice to know that I don't need to have all of these fragile pins soldered in, in case of any problems. |
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
a.b.o.z.
G2 patch files: 4
Posted: Tue Aug 12, 2008 9:26 am Post subject:
annoying experience: two times faulty parts in one project. but after all it works and it seems you have some fun with it.
lit LEDs are a good indicator for issues with the transistors (faulty, reversed...). _________________
Tech Buddy at Random*Source |
a.b.o.z.
G2 patch files: 4
Posted: Tue Aug 12, 2008 9:32 am Post subject:
thats funny.
i get cv workin normally and filter too but led-s are lit when no cv is applied.
is that normal? |
Posted: Tue Aug 12, 2008 10:02 am Post subject:
i set the trimmers until the LEDs are low... _________________
a.b.o.z.
G2 patch files: 4
Posted: Tue Aug 12, 2008 10:06 am Post subject:
oh I see.
I've set trimmers to get 0V on base of 550. I've read it somewhere along..
Ok it is all good now.
Thnx M.
Ivan |
Posted: Tue Aug 12, 2008 11:03 am Post subject:
oh, and was not as precise as i could have been: i turned the initial frequency potentiometers fully counterclockwise and then set the trimmers.
the LEDs just show whats going on inside the vactrols. so as soon as one turnes up the initial freq pot, current starts to flow... _________________
a.b.o.z.
G2 patch files: 4
Posted: Tue Aug 12, 2008 11:42 am Post subject:
| ok, thnx for help. |
rjd2
Posted: Thu Aug 28, 2008 8:04 pm Post subject:
| i have a question about C8, 10, and 12. will the silver mica caps sound better? ive only got ceramic for those values now. much difference? |
Posted: Fri Aug 29, 2008 4:20 pm Post subject:
| rjd2 wrote: | | i have a question about C8, 10, and 12. will the silver mica caps sound better? ive only got ceramic for those values now. much difference? |
i don't believe you'll hear the difference in a blind test. i built the test units with mica though, so i can't tell for shure.
ther PS3100 used mica. _________________
sneakthief
Posted: Tue Sep 16, 2008 12:30 am Post subject:
i finally slapped together my resonator - it works great i used some 910pf polystyrene's (aka styroflex) that funkyfarm sent me and they sound great.
to recap, long before fonik made this pcb, i was really interested in recreating the mam resonator's pan pot.
when the pot was fully CCW, resonator 1 would be panned hard left, resonator 2 would be permanently panned in the centre, and resonator 3 panned hard right.
as you panned the pot from CCW to CW, resonators 1 and 3 would reverse their positions in the stereo field. the effect is really fantastic.
i remember bringing this idea up and scott stites mentioned that he had done the same thing with his Triple Wilson SVVCF. so i perfboarded part of his "Balanced Pan" circuit and it works beautifully:
http://mypeoplepc.com/members/scottnoanh/sitebuildercontent/sitebuilderfiles/triple_svvcf_audio_102.pdf
you know, it would be really tempting to build a dual-vactrol version of this simple circuit as a standalone panning/vca module.
thanks scott for the great circuit!
ps. i still shake my head in wonderment at the insane brilliance of your triple svvcf. what a great idea, especially if the builder can overcome wiring this beast  _________________ Sneak-Thief - raw electrofunk |
Posted: Tue Sep 16, 2008 12:40 am Post subject:
interesting point, sneakthief. i had some conversation lately with someone interested in a 3rd run of the resonators concerning a stereo version.
a dual gang pot would be a simple and effective solution. and think of applying an inverted LFO signal to one of the BPFs. it would be great to have the panning voltage controlled, though. would be possible with two simple discrete VCAs.
at a certain point it would not be a PS3100 clone then  _________________
sneakthief
Posted: Tue Sep 16, 2008 1:51 am Post subject:
ooh, an inverter on resonator 2 is a super idea! it would be best if you could switch between inverted and non-inverted.
would it be possible to adapt one of the attenuverting channels from your mixer for this job?
yes, i know there's feature-creep happening here, but these two mods would put this project into legendary-module status
in any case, your comments have inspired me to change the lfo wiring on the panel: currently the lfo is connected to the normalized switch on the cv input to resonator 1, then chained to cv2 and cv3.
if you want to apply an inverted or totally different lfo to the centre resonator, then the cv's should be connected as follows:
cv1 -> cv3 -> cv2.
so for anybody who does this panning mod, you can plug in an external lfo to cv2 and not interrupt the internal lfo on cv's 1 and 2. _________________ Sneak-Thief - raw electrofunk |
American Gladiator
Posted: Tue Sep 16, 2008 8:36 am Post subject:
| Just wanted to confirm that this project worked right after building it. A very enjoyable build, and a super good filter. I hope that Mr. Fonik has time to release more PCB designs, especially one for the LPG, as I am no good at the press and peel method. Thanks for the great circuit. |
sneakthief
Posted: Tue Sep 16, 2008 1:35 pm Post subject:
| American Gladiator wrote: | | Just wanted to confirm that this project worked right after building it. A very enjoyable build, and a super good filter. I hope that Mr. Fonik has time to release more PCB designs, especially one for the LPG, as I am no good at the press and peel method. Thanks for the great circuit. |
all credits go to KORG
i am not sure about the LPG. it is p. gr. circuit and he is actually making money from it.
someone contacted me concerning a PCB for the LPG. he will probably do a professional PCB if he gets permission from p.gr. - we will see. _________________
aerogramma
Joined: Feb 27, 2008 Posts: 156 Location: Roma, Italy - London, UK
Posted: Sat Sep 27, 2008 9:19 am Post subject:
Resonator build n.1 |
We've built 2 resonators,
an incredibly good sounding and well thought project... thanks fonik!
we implemented all the mods suggested by fonik and got deep into modding the LFO which now has a multi turn switch to select for different rate ranges (switching through capacitors)
we liked the LFO so much we got an LFO out too to drive other stuff!
here's a picture of the 1st module case being dried in the sun and more importantly a little movie of the module in action
it's from my mobile phone so i hope you can read 3gp format
soon, for your delight, pictures of Resonator n.2
aero
1 MB |
| Viewed: |
232 Time(s) |
| A movie of the resonator in action in all its led glory! |
 Download (listen) |
| Filename: |
Resonator Alive.3gp.zip |
247.07 KB |
| Downloaded: |
264 Time(s) |
neandrewthal
Posted: Mon Sep 29, 2008 9:47 am Post subject:
| zthee wrote: | Fonik, I put the BC550 in backwards, and now it works! I don't know if there som strange cheap chinese copies, or something else. I honestly don't care - as long as it works!  |
OMG, zthee, you are an angel I suffered the same problem and reversing the BC550s fixed it, but it doesn't stop there. I've got some other busted circuits on the pile, and guess what, I have stupid backwards chinese BC550's in those too Time to go on a fixin' spree. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
Posted: Mon Sep 29, 2008 11:49 am Post subject:
the BC transistors are CBE while the 2N transistors are EBC. it's easy to mix it up, especially when you want to substitute them by each other.
there is a little reminder at my site (technical hints):
neandrewthal
Posted: Mon Sep 29, 2008 1:46 pm Post subject:
But, yours worked fine with the BC550's installed according to board legending didn't it? That would mean that zthee and I got backwards ones. I'll have to start being careful and check the pinout of each bag of transistors I buy even when I'm not substituting.
One funny, thing: since I reversed the BC550's the third LED won't light. Before, all of them were staying lit  _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
neandrewthal
Posted: Mon Sep 29, 2008 5:12 pm Post subject:
P.S. I went with Sneakthief's idea of having an inverting switch for resonator 3 and normalling the CV from socket 1 to 3 then 2. Great idea! I didn't have room for the LFO out, so it's normalled into the first input of the CGS cascade mixer, which is sure to provide cool ways to sweep the filters as well. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
sneakthief
Posted: Mon Sep 29, 2008 5:48 pm Post subject:
neandrewthal -
what is the invert switch connected to and did you invert cv3 with an opamp? _________________ Sneak-Thief - raw electrofunk |
neandrewthal
Posted: Mon Sep 29, 2008 5:56 pm Post subject:
Yup, I used the circuit funky40 posted in this thread with 1k as the output resistor and 100k for the others. Works like a charm! The switch just selects between the original and inverted signal. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
Luka
