 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
setup problems with Nomad and Micro Modular
Page 1 of 1 [2 Posts]
christian g
PostPosted: Sat Sep 20, 2008 11:10 am    Post subject: setup problems with Nomad and Micro Modular
Subject description: setup problems with Nomad and Micro Modular
Im having problem setting up the Nomad editor and my new Modular. Im using a Macbook running 10.4.11 Tiger, a Midiman 2x2 midisport and a Micro Modular.
The editor opens fine when I click the nomad icon (which is inside the same directory as the nomad.jar file) and in the connection setting my midisports in-A and out-A are found, but in the settings (properties for Nord Modular) all options are greyed out. So im not able to set the Midi-clock to external.
I cant run the command line: java -jar nomad.jar from the Terminal.
Then I get this message: Unable to access jarfile nomad.jar
If i click the nomad.jar file directly it cant open and the following message is in the Consol:
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/java/plugin/boot/Boot (Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:123)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:274)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302)
I have the following Java installed: J2SE 5.0.
-java version "1.5.0_13"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_13-b05-241)
Java HotSpot(TM) Client VM (build 1.5.0_13-121, mixed mode, sharing).
I have already placed the libosxmidispi.jnilib and
osxmidispi.jar files inside the extensions folder. Also tried the mmj.jar file but without succes.
Futher I cant find any nomad/conf/application.xml directory (or any application.xml file) on my computer. So I havent been able to change the "<entry>4</entry>"
to "<entry>1</entry>". (I am using a Nord Micro Modular).
Read somewhere this forum about people using Ta Horng MIDI I/O midi device for the setup. In my Audio MIDI Setup both the Ta Horng and the MIDISPORT 2X2 is displayed but im not sure if i need to configure anything?
The logfile.txt is as follows:
INFO : logging system initialized
INFO : application root is /Applications/nomad-0-3_2
INFO : got SAX parser factory - com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl@6458a6
INFO : configured, stopOnError=false, isValidating=true
INFO : plug-in and fragment descriptors registered - 15
INFO : integrity check done: errors - 0, warnings - 0
INFO : application plug-in is net.sf.nmedit.nomad.core
INFO : plug-in started - com.jgoodies.looks@2.1.4 (active/total: 1 of 15)
INFO : plug-in started - com.jgoodies.forms@1.1.0 (active/total: 2 of 15)
INFO : plug-in started - org.apache.xerces@2.9.0 (active/total: 3 of 15)
INFO : plug-in started - net.sf.nmedit.nmutils@0.1.0 (active/total: 4 of 15)
INFO : plug-in started - net.sf.nmedit.nomad.core@0.2.2 (active/total: 5 of 15)
INFO : [System Properties]
INFO : java.version=1.5.0_13
INFO : java.vendor=Apple Computer, Inc.
INFO : java.vendor.url=http://apple.com/
INFO : java.home=/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home
INFO : java.vm.specification.version=1.0
INFO : java.vm.specification.vendor=Sun Microsystems Inc.
INFO : java.vm.specification.name=Java Virtual Machine Specification
INFO : java.vm.version=1.5.0_13-121
INFO : java.vm.vendor="Apple Computer, Inc."
INFO : java.vm.name=Java HotSpot(TM) Client VM
INFO : java.specification.version=1.5
INFO : java.specification.vendor=Sun Microsystems Inc.
INFO : java.specification.name=Java Platform API Specification
INFO : java.class.version=49.0
INFO : java.class.path=/Applications/nomad-0-3_2/nomad.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/.compatibility/14compatibility.jar
INFO : java.library.path=.:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
INFO : java.io.tmpdir=/tmp
INFO : java.compiler=null
INFO : java.ext.dirs=/Library/Java/Extensions:/System/Library/Java/Extensions:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/ext
INFO : os.name=Mac OS X
INFO : os.arch=i386
INFO : os.version=10.4.11
INFO : file.separator=/
INFO : path.separator=:
INFO : line.separator=
INFO : user.name=christiangjelstrup
INFO : user.home=/Users/christiangjelstrup
INFO : user.dir=/Applications/nomad-0-3_2
INFO : [/System Properties]
INFO : plug-in started - net.sf.nmedit.jpdl2@2.0.0 (active/total: 6 of 15)
INFO : plug-in started - org.w3.sac@1.3.0 (active/total: 7 of 15)
INFO : plug-in started - org.apache.xmlgraphics.batik@1.6.0 (active/total: 8 of 15)
INFO : plug-in started - org.mozilla.rhino@0.0.0.1_6R5 (active/total: 9 of 15)
INFO : plug-in started - net.sf.nmedit.jpatch@0.1.0 (active/total: 10 of 15)
INFO : plug-in started - net.sf.cssparser@0.9.4 (active/total: 11 of 15)
INFO : plug-in started - org.jdom@1.0.0.xcvs (active/total: 12 of 15)
INFO : plug-in started - net.sf.nmedit.jtheme@0.1.0 (active/total: 13 of 15)
INFO : plug-in started - net.sf.nmedit.jsynth@0.1.0 (active/total: 14 of 15)
INFO : plug-in started - net.sf.nmedit.nordmodular@0.1.0 (active/total: 15 of 15)
INFO : Activating services...
INFO : Connected extensions: 7
INFO : Service implementation / Service: net.sf.nmedit.nomad.core.service.initService.ExplorerLocationMemory (description=remembers explorer locations) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.NmFileService (description=Nord Modular patch 3.0) / net.sf.nmedit.nomad.core.service.fileService.FileService
INFO : Service implementation / Service: net.sf.nmedit.jpatch.nomad.InstallerService (description=JPatch Installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.jsynth.nomad.Installer (description=JSynth installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.Installer (description=Nord Modular plugin installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.NewNordModularService (description=Nord Modular factory) / net.sf.nmedit.nomad.core.service.synthService.NewSynthService
INFO : Service implementation / Service: net.sf.nmedit.jtheme.InstallerService (description=Module Pane Installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Setting UIDefaults ClassLoader in net.sf.nmedit.jtheme.clavia.nordmodular.JTNM1Context@4c803d: {PluginClassLoader: uid=11251596; {PluginDescriptor: uid=net.sf.nmedit.nordmodular@0.1.0}} (class org.java.plugin.standard.StandardPluginClassLoader)
INFO : Shutting down {net.sf.nmedit.nomad.core.NomadPlugin: manager=org.java.plugin.standard.StandardPluginManager@523be, descriptor={PluginDescriptor: uid=net.sf.nmedit.nomad.core@0.2.2}}
INFO : plug-in stopped - net.sf.nmedit.nordmodular@0.1.0 (active/total: 14 of 15)
INFO : plug-in stopped - net.sf.nmedit.jsynth@0.1.0 (active/total: 13 of 15)
INFO : plug-in stopped - net.sf.nmedit.jtheme@0.1.0 (active/total: 12 of 15)
INFO : plug-in stopped - org.jdom@1.0.0.xcvs (active/total: 11 of 15)
INFO : plug-in stopped - net.sf.cssparser@0.9.4 (active/total: 10 of 15)
INFO : plug-in stopped - net.sf.nmedit.jpatch@0.1.0 (active/total: 9 of 15)
INFO : plug-in stopped - org.mozilla.rhino@0.0.0.1_6R5 (active/total: 8 of 15)
INFO : plug-in stopped - org.apache.xmlgraphics.batik@1.6.0 (active/total: 7 of 15)
INFO : plug-in stopped - org.w3.sac@1.3.0 (active/total: 6 of 15)
INFO : plug-in stopped - net.sf.nmedit.jpdl2@2.0.0 (active/total: 5 of 15)
INFO : plug-in stopped - net.sf.nmedit.nomad.core@0.2.2 (active/total: 4 of 15)
INFO : plug-in stopped - net.sf.nmedit.nmutils@0.1.0 (active/total: 3 of 15)
INFO : plug-in stopped - org.apache.xerces@2.9.0 (active/total: 2 of 15)
INFO : plug-in stopped - com.jgoodies.forms@1.1.0 (active/total: 1 of 15)
INFO : plug-in stopped - com.jgoodies.looks@2.1.4 (active/total: 0 of 15)
INFO : shutdown done
INFO : logging system finalized
INFO : ---------------------------------
WARN : unknown listener org.java.plugin.standard.StandardPluginManager$1@b77816
Realy hope someone can help me out as I spend hours trying and trying, still being stocked..
Thanks in advance
julien
PostPosted: Thu Oct 16, 2008 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you try to upgrade to the last version of Java and see if it works ?
