Simmons SDS 3 - DIY?
Page 8 of 14 [345 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10, 11, 12, 13, 14 Next
bubblechamber
PostPosted: Fri Oct 03, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
just wrapping up the corrections, let a few resistors off and missed a couple connections. should be etching a prototype or 2 real soon(hopefully over the weekend/early next week). we're getting there. just taking a little longer than i had hoped. this is by far the biggest thing i've ever taken on. i'm pretty happy with it so far, just pretty complicated and i want to take my time and not screw this up.
david
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
vtl5c3
PostPosted: Mon Nov 17, 2008 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Will T4 & T5 (the two 2N5459s) need to be matched?
Luka
PostPosted: Tue Nov 18, 2008 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
can someone list all the I/O and pot functions
i want to start designing my new midiboxMPSSDS
problemchild
melbourne australia
Luka
PostPosted: Tue Nov 18, 2008 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
from photos/schems i can see
pots:
impact click (is this envelope amount?)
decay time
bend level (is this attack?)
effect amount (what does this do - lfo?)
and 2 more
+ channel volume slider (not sure if this is included in the single voice run)
jacks
decay kill
ext. pitch
trigger input
bend up/down switch (or is it a pot)
problemchild
melbourne australia
johans121
PostPosted: Thu Nov 20, 2008 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm definitely in for 4!
Don't feed me Indian, you WILL regret it!
-Jim
JohnnyBusca
PostPosted: Thu Nov 27, 2008 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ola!
This is also a piece of SDS-3..
http://www.tonyblack.org/mp3/external/SDS3.mp3
This is really the best drum machine ever...
http://schleyer.org/simmons/sds3.htm
johans121
PostPosted: Sat Dec 06, 2008 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is this project still alive?
-Jim
bubblechamber
PostPosted: Sun Dec 07, 2008 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jim, sorry for the delay.
It's still moving forward in a slightly on hold kinda way. i'm finishing up my apartment search/relocation from Los Angeles to NYC. that, along with my job, really slowed things down(i've got a new line of eurorack modules heading towards Analogue Haven right now). but i'm hoping to start testing a prototype when i get back home next weekend. i've pretty much wrapped up all my other projects and work stuff till the end of the year and i'm hoping to finish the testing and revisions in that time.
i'll be posting the results of the tests, and if we're really lucky, samples...
i'll also be posting a PCB for a eurorack sized panel for pots and jacks. if there's a lot of interest in that we can talk about doing a run of those, too. it'll be a almost completely wire-free design(jacks will need buss wire), using header rows and connectors with PCB mounted pots. so it'll be set up a lot like the Livewire AFG.
sorry for the delay, guys. sometimes life really gets in the way of plans, but i am completely committed to getting this and having it exactly like the original. mostly cause i really want about 8 of these in my cabinet.
david
mono-poly
PostPosted: Mon Dec 08, 2008 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
A run of Eurosize panels souns interesting to me.
neandrewthal
PostPosted: Fri Dec 26, 2008 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
pots:
decay time
and 2 more
jacks
decay kill
ext. pitch
trigger input
Arghhhhhh, I'm trying to figure out what the essential controls are too.
Randal said:
1) LFO rate
2) Mic. level (input sensitivity)
3) Click level
4) Pitch
5) Decay
6) Bend
7) Noise /Tone mix
Cool Bend level
9) Run time (Arp. length-TIME)
10) Effects level (modulation input atten. for LFO and Arp.)
11) Channel level
But, I clearly only see 7 pots per voice, plus the fader. What was he smoking?
Can anyone explain what controls and options are available on the PCB?
Audio files: 278
PostPosted: Fri Dec 26, 2008 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some of the pots apparently Rolling Eyes
Randaleem
PostPosted: Fri Jan 02, 2009 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Just noticed this couple of posts.
On the original SDS3, Channel Pots From top to bottom, left to right:
1) Mic. Sensitivity
2) Impact Click
3) Pitch
4) Decay Time
5) Noise/tone Mix
6) Bend Level
7) Effect Range
8 ) Channel Level (slider)
Then there are four more pots in the effects section:
9) LFO Speed
10) Run Time (Arpeggiator)
Having individual LFO's and Arp's greatly! increases the available variety.
11, 12) Overall pitch and overall level (unnecessary with individual modules, but still useful for a group of SDS3 modules IMO)
Bubblechamber's board is different from mine; I don't know what his board supports. But these 12 pots are the original SDS3 controls.
No smoking involved. Here's a close look at an SDS3.
Kind regards, Randal
 Filesize:  193.34 KB
 Viewed:  388 Time(s)
neandrewthal
PostPosted: Fri Jan 02, 2009 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! Thanks. I've been trying for a long time to find a decent pic of that thing.
urbanscallywag
PostPosted: Fri Jan 02, 2009 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Neat paintjob and rockin' skirted pots. Cool
ickystay
PostPosted: Thu Jan 08, 2009 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see you here, Randal.
jmejia
PostPosted: Mon Apr 04, 2011 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is anyone still working on this project? I'd be happy to pick it up and continue if no-one else had bandwidth for it!
TekniK
PostPosted: Mon Apr 04, 2011 9:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
PM fonik
PostPosted: Mon Apr 04, 2011 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
pick it up! i once did a proto PCB for testing purposes, which did not work, actually. i already handed it over to someone else one year ago... so go ahead.
brother303
PostPosted: Tue Apr 05, 2011 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Coooool!
4 channels of Simmons, 2x DS7 and one MPS stuffed in a nice (euro-)case...
...awesome! party time!
Go ahead jmejia... Please
jmejia
PostPosted: Thu Jun 09, 2011 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Quick update here - nothing too much to tell.. I'm learning kicad so I can transfer the existing design from eagle. I'm an eagle lite user - and not particularly keen on buying the full version. (The design is too big for the free eagle)
It is fairly high in my backlog pile though.. so it will happen. Just not with the speed I had initially hoped. It also looks like the majority of the work has already been done.. so likely just needs a prototype, troubleshoot, prototype, troubleshoot kind of deal.
diablojoy
PostPosted: Thu Jun 09, 2011 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile yay good to see someone is still working on this
PostPosted: Thu Jun 09, 2011 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
jmejia wrote:
... so likely just needs a prototype, troubleshoot, prototype, troubleshoot kind of deal.
or breadboard it first?
just my 2 pence
jmejia
PostPosted: Fri Jun 10, 2011 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
just my 2 pence
Yeah... my breadboarding skills aren't super awesome - and I have access to cheap rapid pcb prototyping through a local group I'm involved with here in Portland. So I tend to skip the breadboard step. That would be a whole seperate set of variables to troubleshoot for me! I should definitely get some practice in sometime though - I know I'd be better at all this stuff if I did!
vout
PostPosted: Fri Oct 26, 2012 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Any update on this project? I would be very interested in a set of boards.
Cheers, vout
Moogah
PostPosted: Fri Oct 26, 2012 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Been watching this with interest since the beginning too. Seems like the circuit is a bit tricky to get working reliably!
I captured the schematic in eagle a while ago (the first time this thread went dead). If nobody else is still working on this I'd be glad to do a layout and get a prototype made and see if I have better luck!
