LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Thu Mar 12, 2009 4:46 am Post subject:
Stripboard Soundlab build Subject description: with step by step photos |
This may be of use to the guys starting out; my build of the Soundlab in stages.
This thread is basically about the circuit build, and not so much about the front panel. Maybe someone will be kind enough to do a tutorial on panel making to compliment this thread.
First off, I used a 4mm drill bit (slightly wider than the copper tracks of the stripboard) and gave it a couple of light turns to cut the necessary tracks. It is absolutely essential to get this right, double check, and double check again before you cut! As you will see I made a mistake on my board, but this was rectified by bridging the erroneous cut with a short piece of wire (tweezers are very useful for small jobs like this)
It is always good practice to populate every circuit in stages, starting with the lowest profile components first, in this case the wire links. I always pre-bend the pins before mounting.
Next the horizontally mounted resistors. Notice they are all of the same orientation, makes it a lot easier should I need to troubleshoot later.
I then added the IC sockets and smaller capacitors, also I decided to use a female pin strip for connecting the panel components.
Continuing to add the components until the tallest components were in.
Next job was to wire the panel. I didn't have all the components to start with, but enough to be getting on with some of the wiring.
Once I got the required components, finished the panel wiring.
Added spaghetti.
A few more sockets and she's up and running:
Special thanks to Ray Wilson, Uncle Krunkus and everyone involved for making this project possible.
YouTube video coming soon... _________________ LektroiD |
Posted: Thu Mar 12, 2009 4:55 am Post subject:
Nice job LektroiD!  _________________ What makes a space ours, is what we put there, and what we do there. |
Joined: Apr 03, 2004 Posts: 24432 Location: The Netherlands, Enschede
Audio files: 297
Posted: Thu Mar 12, 2009 6:09 am Post subject:
Or how a well structured path leads to success, good job indeed. _________________ Jan
Posted: Thu Mar 12, 2009 6:41 am Post subject:
very cool
fwiw, I've got an exact replica upstairs of picture 2. It stopped there as this was the point when Ray's boards arrived. Now I also have a Ray board populated with resistors and erm.... not much else
one day Tom. One day.  _________________ ACHTUNG!
Audio files: 297
Posted: Thu Mar 12, 2009 7:03 am Post subject:
v-un-v wrote: | fwiw, I've got an exact replica upstairs of picture 2. |
You could frame it for above the sofa I guess  _________________ Jan
LektroiD
Posted: Thu Mar 12, 2009 7:22 am Post subject:
Blue Hell wrote: | v-un-v wrote: | fwiw, I've got an exact replica upstairs of picture 2. |
You could frame it for above the sofa I guess  |
I had a friend in the early '90s who had a broken TR606 on his wall. _________________ LektroiD |
Joined: Jan 31, 2003 Posts: 18240 Location: Durham, NC
Audio files: 224
Posted: Thu Mar 12, 2009 8:22 am Post subject:
A very nice job and nice pictures. This will help someone who is doing a stripboard project for the first time. Thanks. _________________ --Howard
my music and other stuff |
Posted: Thu Mar 12, 2009 8:59 am Post subject:
Nope, I WILL finish it
concentration has never been my forte  _________________ ACHTUNG!
Posted: Thu Mar 12, 2009 9:00 am Post subject:
mosc wrote: | This will help someone who is doing a stripboard project for the first time. |
That'll be me then??  _________________ ACHTUNG!
Posted: Thu Mar 12, 2009 3:13 pm Post subject:
If it's any consolation Tom, I think the level of concentration required to get a stripboard that size working perfectly is something which comes and goes. I doubt I'd have the chops to even begin one these days!  _________________ What makes a space ours, is what we put there, and what we do there. |
LektroiD
LektroiD
Posted: Fri Sep 18, 2009 1:09 am Post subject:
in its current state (click for larger photo):
Joined: Jan 07, 2009 Posts: 1217 Location: Scottish Borders
Posted: Fri Sep 18, 2009 3:55 am Post subject:
very good build, well laid out from start to finish, my friend built the strip layout WSG and made such a good job that i commandeered it to use in Epicyclus project he he |
