zthee
Posted: Wed Mar 18, 2009 8:01 am Post subject:
Aha, BP1 means Break Point 1 ! That kinda threw me off, thinking - why does he have like 24 band pass filters
But now I get it!
Looks great! |
Posted: Thu Mar 19, 2009 6:32 am Post subject:
there is one thing i am still not sure about. it is the wiring of the shapers gain potentiometers: as i understand it now for each shaper the summed vowel CVs are fed into the negative input of an OpAmp, whereas the positive input is fed by the vowel CVs that went through a potentiometer. The Opamp will compare and cancel out the original CVs!? the output of the OpAmp is mixed with the shaped CV anyways, so how could this influence the gain of the shaper?
i am still not sure, just because i don't understand it, and i don't see the connection from the pot to the vowel CVs for two of the gain potentiometers. _________________
Tech Buddy at Random*Source |
andrewF
Posted: Thu Mar 19, 2009 8:11 am Post subject:
Vowel Out, pin15 of JP5 connects to all 3 Master Gain pots, although only one connection is shown.
are these the 2 gain pots you are unsure of? |
Posted: Thu Mar 19, 2009 8:21 am Post subject:
exactly. so i am right about the connection - i still don't understnd the gain functionality... _________________
andrewF
Posted: Thu Mar 19, 2009 3:42 pm Post subject:
you are right, the gain pots are dividing the CV signal and feeding it to the inv inputs.
Originally I had assumed they were differential amp stages with adjustable gain, but now after your question and a closer look, not so sure
Maybe it is worth setting one of these stages up in Pspice or on a breadboard to see how it works.
Or contact Jim, for the definitive answer. |
knarleybass
Posted: Sun Mar 22, 2009 2:27 pm Post subject:
it's one crazy filter, I built one about 5 years ago. |
Posted: Mon Mar 23, 2009 4:20 pm Post subject:
knarleybass wrote: | it's one crazy filter, I built one about 5 years ago. |
so you like it? i hope it is worth the effort. would it be insolent to ask you for some sound samples?
i found a little company that will print on a front panel i send them. i ordered the cabinet and will then send them the panel to print my graphics on (one color/black). it will cost less than a schaeffer panel, i will have to do all the drilling, though.
Posted: Mon Mar 23, 2009 4:23 pm Post subject:
if you wonder about the CV/potentiometer combination on the break points: i plan to wire the jacks normalled to the +10V reference. this way i could use the pot as manual control with no CV plugged in. as soon as the CV in socket is used, the pot would work as attenuator... _________________
knarleybass
Posted: Mon Mar 23, 2009 4:56 pm Post subject:
sadly, where I live now I don't have room for my modular, it's in storage.
Posted: Tue Mar 24, 2009 2:15 am Post subject:
knarleybass wrote: | sadly, where I live now I don't have room for my modular, it's in storage. |
a real pitty, isn't it? great work, knarleybass. _________________
knarleybass
Posted: Wed Mar 25, 2009 11:45 am Post subject:
Someday I will get it out again. |
ach_gott
Posted: Wed Mar 25, 2009 12:58 pm Post subject:
knarleybass wrote: | Someday I will get it out again. |
If you ever decide you don't want to store it anymore, drop me a PM. I'll still build one though... more vocal sounds! |
Posted: Mon Mar 30, 2009 1:12 am Post subject:
some progress here. now i am waiting for the frontpanel...
andrewF
Posted: Mon Mar 30, 2009 1:32 am Post subject:
lookin' good
*just* the wiring to go
knarleybass
Posted: Mon Mar 30, 2009 1:42 am Post subject:
it is going to be amazing! |
Posted: Mon Mar 30, 2009 1:44 am Post subject:
i am Klee2-proven. so no concerns on my side
or at least no big concerns. _________________
TekniK
Posted: Mon Mar 30, 2009 4:11 am Post subject:
andrewF wrote: | lookin' good
yes,and from then he can post his own demo's |
Posted: Fri Apr 03, 2009 3:30 pm Post subject:
the frontpanel arrived today. the result is amazing, IMHO at least. actually i am a littlebit overwhelmed and i must show it to you, even though i still have to drill the holes. Without the holes it ahs been less than a schaeffer panel. i will ahve to contact the company about the drilling (what do they need, how does it fit with the print (offset tolerances).
a little bit blurry, sorry:
close-up:
Sine
Joined: Sep 10, 2007 Posts: 111 Location: Netherlands
Posted: Fri Apr 03, 2009 3:47 pm Post subject:
Very nice fonik !
Now the trick is to drill it without damaging the print. |
Posted: Fri Apr 03, 2009 3:50 pm Post subject:
the "printing" is actually black anodized. i drilled black anodized panels before without any issues!?
do you have some experiences with this kind of print and drilling? what should i be aware of? i wanted to start tomorrow... _________________
TekniK
Posted: Fri Apr 03, 2009 4:14 pm Post subject:
fonik wrote: | what should i be aware of? i wanted to start tomorrow... |
noting,just drill
seriously |
zthee
knarleybass
Posted: Wed May 06, 2009 1:03 pm Post subject:
I can't wait to see more progress on your filter. |
Posted: Wed May 06, 2009 1:31 pm Post subject:
me too
i mounted all front panel components and made the ground star configuration. this all goes alongside with my other projects. i hope it will be finished end of month for the german modular meeting. _________________
ryktnk
Posted: Wed May 06, 2009 1:41 pm Post subject:
hello
That's a great design for your panel, very cool
Do you mind me asking who made it ?
Is it not Schaeffer ?
Thanks
-ryk |
