How to make Dubstep Bass
Page 1 of 1 [7 Posts]
RyanB
PostPosted: Thu Apr 23, 2009 10:14 am    Post subject: How to make Dubstep Bass Reply with quote  Mark this post and the followings unread
Hi there,
I want to make the typical wooble bass which is most used in Dubstep. I found a Tutorial to make it with Reasons Subtractor (look here: http://www.mashit.com/category/tutorials/) and tried to do it with the G2. I use the Subtractor.pch2 patch from G2DREAM with some modifys. But it doesn't sounds like the wooble bass.
So which patch can I use for it or someone have a patch with the typical wooble bass for Dubstep?
Thanks for help!
Regards,
Bryan
peterkadar
PostPosted: Fri Apr 24, 2009 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like there was some overdrive on his bass sounds that isn't a part of Subtractor. So I think there must be some kind of insert effect somewhere he forgot to mention.
Try dragging and dropping an overdrive effect into the FX area, and messing with it. If that doesn't work, you could try doing the same thing, but inserting it before the filter in the voice area.
Lemme know how that works out for you.
Peter
grimley
G2 patch files: 9
PostPosted: Fri Apr 24, 2009 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is as close as I could get to that patch ... not close enough Confused
WubBass JG.pch2
Wobble Bass attempt
 Filename:  WubBass JG.pch2
 Filesize:  2.72 KB
 Downloaded:  1623 Time(s)
suthnear
PostPosted: Sun Apr 26, 2009 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
here's another attempt. This could also be closer (especially for synth bass 1) but I don't have any more time to spend on getting the modulation amounts right...
dubbed step.pch2
 Filename:  dubbed step.pch2
 Filesize:  2.63 KB
 Downloaded:  1318 Time(s)
grimley
G2 patch files: 9
PostPosted: Sun Apr 26, 2009 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahhh .... LFOShpA. That's what I needed!
RyanB
PostPosted: Mon Apr 27, 2009 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there,
thanks for the answers.
I like the WubBass JG from grimley that sounds great and helps me to improve my patch. The main mistake I did was the Amp Env. It was too short to hear the wobble bass.
So here is the first result of my patch.
Regards,
Bryan
RBdubstep_substr.pch2
RyanB's Dubstep Bass 1st try
 Filename:  RBdubstep_substr.pch2
 Filesize:  4.74 KB
 Downloaded:  1385 Time(s)
grimley
G2 patch files: 9
PostPosted: Mon Apr 27, 2009 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool ... Looking forward to trying it out this evening. I've been creating some great dub step basses on my vsynth ... the filters are key. Maybe we should try using some of the custom filters posted here.
