How do i get the tipical delay effect?
Page 1 of 1 [3 Posts]
arecio
PostPosted: Thu Jun 04, 2009 1:44 pm    Post subject: How do i get the tipical delay effect?
Subject description: like in a Boss delay pedal for example
Hi!
I am replacing the microkorg with the G2, and i was using a vocoder effect to process drums wich had a delay that i could tweak and then change the pitch of the repetitions, like in most of the delay pedals.
In the G2, when i change the delay time it doesn't speed up or down the reading of the repetitions, but cuts up or adds the time it needs.
So...how can this old-school delay effect be emulated?
Thanks in advance.
Arecio
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Jun 14, 2009 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Very simple. Just use a constant level module as an external delay time control and run that through a glide module. See attachment.
SmoothDelaytime.pch2
Demonstration of "analogue style" delay time smoothing
 Filename:  SmoothDelaytime.pch2
 Filesize:  1.23 KB
 Downloaded:  1794 Time(s)
djfoxyfox
PostPosted: Tue Sep 13, 2011 2:54 pm    Post subject: Stereo Ping-Pong Delay Reply with quote  Mark this post and the followings unread
While searching for something else, I accidentally ran across this thread. Since it was on my To Do List, I took a look at the patch. I liked it so much that I turned it into a ping-ponging stereo delay and assigned some knobs for control. I hope you like it.
Stereo Delay.pch2
Stereo Ping Pong Delay with effect level, regeneration amount, and delay time knobs. Both channels delay by the same amount for simplicity.
 Filename:  Stereo Delay.pch2
 Filesize:  1.17 KB
 Downloaded:  5099 Time(s)
