 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Can't connect Micro Modular and Nomad!
Page 1 of 1 [4 Posts]
loseen
PostPosted: Tue Oct 06, 2009 2:33 am    Post subject:  Can't connect Micro Modular and Nomad! Reply with quote  Mark this post and the followings unread
Im having problem setting up the Nomad editor and my Micro Modular. Im using a Macbook running 10.5.8.
I have already placed the libosxmidispi.jnilib and
osxmidispi.jar files inside the extensions folder. Also tried the mmj.jar file but without succes.
I've installed MIDI monitor on my macbook. The connection is ok. Midi messages are running.
I've tried to find original Clavia editor for my OS version, but there is no one.
I don't understand how to choose midi ports in Nomad. When I connect Micro Modular and run Nomad, nothing happens.
Maybe someone can help me out, or write some manual "How to connect Micro Modular", as I wasted hours trying and trying(
Thanks in advance
loseen
PostPosted: Wed Oct 07, 2009 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
hm((
nobody had the same problem?
Audio files: 271
PostPosted: Wed Oct 07, 2009 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
hi loseen, welcome
Many people have this problem ... you can read some about it here on our forum ... it seems to require some fiddling dunno
loseen
PostPosted: Wed Oct 07, 2009 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell, I've read all the topics about it)
tried Nomad on PC running on Windows 7
and result is :
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 11 more
