2010 Build Pictures
Page 3 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 22, 23, 24 Next
mark_olson
PostPosted: Mon Mar 01, 2010 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really nice, Kevin.
Now how about some samples? Smile
Mark
PostPosted: Mon Mar 01, 2010 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
mark_olson wrote:
Really nice, Kevin.
Mark
Thank you, Mark.
OK, just recorded a track that demos the MPS. Hope you enjoy it.
http://electro-music.com/forum/post-286075.html
droffset
PostPosted: Tue Mar 02, 2010 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished building this for someone, it's a NAND synth but everything is separated and patchable with single header jumpers to extend the fun. There are also phototransistors linked to each pot and a four channel output simple mixer so you can have up to four thingies going crazy at the same time. I'll be sad trading this one away.
Cleanest build I've done yet:
Designed to be used while open for patching on the fly.
Sample 'patch'
Edit: Spelling mistakes.
macumbista
PostPosted: Tue Mar 02, 2010 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice idea! Any reason the pots are so tall though?
D.
macumbista.net
Broadwave
Audio files: 6
PostPosted: Tue Mar 02, 2010 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought it was time to build a keyboard for my modular, and being a bit of an ARP freak, I based it on the 3620 Keyboard with a few modifications.
The keyboard mechanics and midi PCB is from an M-Audio 49e, which feeds a Doepfer MCV4, but I'm only using CV and Gate at the moment.
The LFO, Delay, Kbd repeat, Transpose, Pitch Bend and Portamento were taken directly from the 3620 schematics (although the only copy I could find was very low resolution, and I could only guess at some of the component values).
I added a very basic version of Alain Coupel's PIC Sequencer, which is triggered from the LFO or keyboard gate, and also a switch to disconnect the LFO reset trigger.
Unfortunately, in my excitement to get the build done, I sent the wrong file to Front Panel Express... The correct file had a few extra graphics for slider levels and a few additional holes for the Doepfer CV2, 3 & 4 outputs - never mind, silly mistake that can be corrected later.
Just needs a coat of black paint inside the case to finish... bare MDF is not a good look Very Happy
 Filesize:  281.79 KB
 Viewed:  485 Time(s)
 Filesize:  293.05 KB
 Viewed:  524 Time(s)
Synth DIY Projects
Musical Doodlings
droffset
PostPosted: Tue Mar 02, 2010 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was afraid to cut them down and ruin it. Embarassed The knobs need the semicirclular cut shaft and it looked like an accident waiting to happen.
So now it's an artistic decision!
D.
ericcoleridge
PostPosted: Tue Mar 02, 2010 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're out of control, this is amazing. I'd love to hear more about the making of the cabinet/tolexing. I've started to build some simple cabinets that I'd eventually like to tolex, and could use some pointers.
AnalogCustom
PostPosted: Tue Mar 02, 2010 5:23 pm    Post subject: My new BSS, Blue Sky Synth Reply with quote  Mark this post and the followings unread
New versión, as always in "guitar tube amp" style:
dual oscillators (osc 2 with saw detuned)
moog filter + env
dual amp exp y lin serial connection (formant type but with JRC13600 OTA) + env
Simple MIDI Interface
Full pachable and pre-routed
Panel letraset
Sl2!!!
Marco Antonio
j.dilisio
PostPosted: Tue Mar 02, 2010 9:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I second this. The tolex is a nice touch.
DRONEGOAT
Broadwave
Audio files: 6
PostPosted: Wed Mar 03, 2010 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Eric, I started another cabinet just before you sent this message, but I'll take photos as I go along and try to get a simple guide together. I'll either post it here or put up a link to my site as soon as I can.
Synth DIY Projects
Musical Doodlings
RF
Audio files: 28
PostPosted: Wed Mar 03, 2010 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful work AnalogCustom, and AndyR1960....
props
The DIY bar is being raised every time I look at this thread....
bruce
www.sdiy.org/rfeng
andrewF
PostPosted: Wed Mar 03, 2010 8:29 am    Post subject: Re: My new BSS, Blue Sky Synth Reply with quote  Mark this post and the followings unread
great looking synth
Anything with chickenheads makes me happy cheers
PostPosted: Wed Mar 03, 2010 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, indeed. beautiful work on the NAND synth, keyboard, and the "Guitar Tube Amp" style synth.
droffset
PostPosted: Thu Mar 04, 2010 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Shorter pots! Laughing
You guys make me want to make better stuff.
PostPosted: Thu Mar 04, 2010 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great. What is a NAND synth? Any samples?
andrewF
PostPosted: Sat Mar 06, 2010 1:11 am    Post subject: Reply with quote  Mark this post and the followings unread
This is not exactly a synth, its an analogue computer.
patch it up properly and will sound like a synth tho
jumping the gun a bit with this one as it has not been wired up yet.
but everything else has been done, and i'm geekishly excited
more info - here!
Funky40
G2 patch files: 5
PostPosted: Sat Mar 06, 2010 5:50 am    Post subject: Reply with quote  Mark this post and the followings unread
not built any modules the last two month, but two racks.
another euro-modular, and a 19" Rack to replace the old studiorack
eurorack with ventilation slots cause i run the modules so hot
 Filesize:  110.74 KB
 Viewed:  310 Time(s)
the new rack for my 19" mixer
 Filesize:  105.6 KB
 Viewed:  313 Time(s)
TekniK
PostPosted: Sat Mar 06, 2010 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
hey ,thats a nice arcade rack
zthee
PostPosted: Sat Mar 06, 2010 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
more info - here!
WOW! Shocked
j.dilisio
PostPosted: Sat Mar 06, 2010 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
The board looks so simple for the amount of patch points there are on the panel.
I've always wondered how you could use an analog computer in a modular setup. Would you use it mostly as a CV generator/processor?
It would be cool to have a VU meter in there too.
DRONEGOAT
macumbista
PostPosted: Sat Mar 06, 2010 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Consider me [fr]/[g]eekishly interested in any PCBs you might have for this project!!!!
D.
macumbista.net
glacial23
PostPosted: Sat Mar 06, 2010 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
D.
Seconded. I was planning on building an analogue computer anyway - this would simplify matters a bit!
glacialcommunications.com
droffset
PostPosted: Sat Mar 06, 2010 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well i thought I'd have samples by now but I can show you a previous example of this same circuit:
http://www.youtube.com/watch?v=Xq3rPsZG8ZY
It's four digital oscillators that modulate each other, based on the 4093 quad schmitt trigger NAND IC. There are also some phototransistors and momentary buttons that can be set up to muck around with each feedback loop.
Fun toy!
j.dilisio
PostPosted: Sat Mar 06, 2010 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a sequencer panel I've been working on for a while.
There's a Klee in the center flanked by two Ryk 185 sequencers.
This thing is a blast!
DRONEGOAT
Audio files: 278
PostPosted: Sat Mar 06, 2010 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've seen that bottom synth before, hope I said it is beautiful, but anyway that looks pretty damned good all!
