2010 Build Pictures
Page 7 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, ..., 22, 23, 24 Next
TekniK
PostPosted: Thu Apr 15, 2010 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dego wrote:
Funky40 wrote:
you are building there a awesome modular technik !
hope i get someday the full picture to see
+1
Fantastic work TekniK! Smile
Thanks for kind words Very Happy
Thalassa
PostPosted: Fri Apr 16, 2010 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
My first finished project of this year MFOS Ultimate + Expander Very Happy
Audio files: 43
PostPosted: Fri Apr 16, 2010 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
The MFOS Ultimate looks great as well as Teknic's latest work, too. I am also impressed with droffset's simple mixer -- a very neat layout on perfboard. (My own perfboard work tends to be a little bit "unweildy".)
I'm just finishing up a CGS Modulo Magic module and will post a pic once I have it up-and-running.
TekniK
PostPosted: Fri Apr 16, 2010 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice units,and great casing work it seems!
Today i made one seq.switch module from matt,6 more to built! Razz
Thalassa
PostPosted: Sat Apr 17, 2010 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Your modular is awesome and also your building speed Wink
PostPosted: Sat Apr 17, 2010 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's a real beauty! perfect choice of colors IMHO!
PostPosted: Sat Apr 17, 2010 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
your panel designs are more than awesome! each modul has it's special look, and all modules fit in the whole system as well. great concept!
Thalassa
PostPosted: Sun Apr 18, 2010 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Fonik Smile
TekniK
PostPosted: Sun Apr 18, 2010 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dual X-pan from matt:
mono-poly
PostPosted: Sun Apr 18, 2010 12:49 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Sweet!
Audio files: 43
PostPosted: Sun Apr 18, 2010 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
The chips that I needed for Modulo Magic arrived -- they are installed and the module now works properly.
A new CGS40 Modulo Magic module lives!
The CGS40 Modulo Magic mounted in the case with other recently-built modules.
 Filesize:  1.6 MB
 Viewed:  202 Time(s)
The top case (temporary) contains all that I've built in 2010. Next step is to built the permanant case that will hold six additional modules. The Klee Sequencer is purposely non-standard width to accomodate the case that will match the main case.
 Filesize:  1.71 MB
 Viewed:  226 Time(s)
TekniK
PostPosted: Sun Apr 18, 2010 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
For what is the place reserved above the B-52 panel kevin?
andrewF
PostPosted: Mon Apr 19, 2010 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
j.dilisio wrote:
Here's a sequencer panel I've been working on for a while.
There's a Klee in the center flanked by two Ryk 185 sequencers.
This thing is a blast!
I knew I'd seen these synths somewhere before
http://spectrum.ieee.org/slideshow/geek-life/hands-on/diy-analog-synths
enjoyed the vid
nice to see ieee taking an interest in the lo-tech side of electronics
Luka
PostPosted: Mon Apr 19, 2010 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
great vid
"just keepings ourselves busy"
hehe totally
problemchild
melbourne australia
Audio files: 43
PostPosted: Mon Apr 19, 2010 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
The top case is my original Aries case with space for 11 3"-wide modules.
Originally the synth was housed in three separate cases -- two 11 module cases and a home-made wing case on the left that holds the green switches, etc.
In 1983, I did away with the three separate cases and a woodworking friend of mine built the single case that houses all the Aries Modules and the left panel. I made no effort to make the inner dimension of the case a multiple of 3" -- I never expected to add anything to this synthesizer.
For the moment, my new modules are housed in one of the leftover 11-module Aries cases -- within a couple of months I will replace this case with a new case with an interior width to match the bottom case --
50 9/16 -- just short of 17 3"-wide modules. The Klee sequencer will be be the leftmost module -- and it is intentionally sized to fit the space (11 9/16"). Thus, all the modules will line up vertically across the synthesizer.
Teknik, your panel lettering is gorgeous -- how do you do it?
TekniK
PostPosted: Mon Apr 19, 2010 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
The black panels are laser engraved,and some logo's where vectorized.
joshco
PostPosted: Tue Apr 20, 2010 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a finished Filterbox, I did for a friend. 2 x CGS Steiner Parker VCF, with LFO and a Phase invert, for nice modulations.
The other unit a Studer 169 EQ Clone from parts I had laying around, very sweet, but ghetto style case.
 Filesize:  239.71 KB
 Viewed:  163 Time(s)
joshco
PostPosted: Tue Apr 20, 2010 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
 Filesize:  205.75 KB
 Viewed:  149 Time(s)
TekniK
Emu remuance series,this is the dual ssm2050 adsr + its cv input unit.
stolenfat
PostPosted: Thu Apr 22, 2010 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
i finished this one in laaaaaate 2009 when i was on xmas break from class, hope it still counts... its that orange thing. this is a shot from a recording session. Also in there, the diy stuff at least, if a modded casio with a full blown array of filters and lunneta style oscillators built into it (no circuit bending), and the green/black wired thing was an experiment gone wrong and now is a simple passive mixer.
the orange thing is on top: baby10 sequencer, with pulse driver, then controls and outs for the baby10, then some 555 noise oscillators, and then some more lunneta stuff, with a terrible(?) build of ray's wsg filter.
Heres me using the orange thing and current improvised set up at rock and roll performance featuring mostly "metal" and "hardcore" music in Oakland, California.
The promoters were nice enough to allow my noise troupe, Chief Grand Cherokee, to open the evening with a mood setting blast of harsh noise. Hurray for Art!
 Filesize:  101.77 KB
 Viewed:  158 Time(s)
 Filesize:  96.13 KB
 Viewed:  177 Time(s)
ericcoleridge
PostPosted: Thu Apr 22, 2010 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is just about the nicest modular synth I've ever seen, diy or commercial.
adambee7
PostPosted: Fri Apr 23, 2010 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Teknik's stuff is the mutts nuts. Love to see a full picture of his system now he has his new modules. Very Happy Very Happy
sduck
PostPosted: Fri Apr 23, 2010 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's one I just finished -
Dual Choices profile
Dual Choices back
Skellz
PostPosted: Fri Apr 23, 2010 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice sduck im jealous
Where did you get the joysticks?
sduck
PostPosted: Fri Apr 23, 2010 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - they're from the Devi Ever Etsy store - http://www.etsy.com/shop/deviever?section_id=6842853
