LFO sync questions
Page 1 of 1 [8 Posts]
bootlegtrader
PostPosted: Thu May 27, 2010 10:30 am    Post subject: LFO sync questions
Subject description: noobish...
How can I sync an LFO or delay to the midi clock coming into my G2?
And...
How can I make the LFO reset every time I hit a key, say to have a saw wave effect pitch?
Thank you so much!
paul
Audio files: 278
PostPosted: Thu May 27, 2010 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use an LFO with a sync input, like LFO B. Connect that input to the sync output of the clock module, or to the gate out of the kbd module.
Not sure what you mean by synced delays ... you can set some of the delays to follow the clock though it that is what you mean.
bootlegtrader
PostPosted: Thu May 27, 2010 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I meant to have a delay follow the clock, much like the LFO... Also, how can I make the LFO reset every time I press a key? Much appreciated!
paul
Roland Kuit
G2 patch files: 127
PostPosted: Thu May 27, 2010 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
do you mean this?
lfo resets.pch2
lfo resets
 Filename:  lfo resets.pch2
 Filesize:  1.4 KB
 Downloaded:  1768 Time(s)
Audio files: 278
PostPosted: Thu May 27, 2010 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was mentioned in my reply Wink
bootlegtrader
PostPosted: Fri May 28, 2010 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info Mr. Hell and that patch was a perfect example Roland!
*Roland, I have been meaning to get a copy of your DVD in English. Is it still available? Am I reading the price correctly: 59.95 Euro shipped outside of Europe?
paul
Roland Kuit
G2 patch files: 127
PostPosted: Sun May 30, 2010 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes Boot, it is still available in English. Check out:
http://rolandkuit.blogspot.com/
G2 patch files: 626
PostPosted: Sun May 30, 2010 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 4TAP, DLYA, DLYB and STER delay modules have a CLOCK/TIME toggle switch for syncing to midi clock.
