yusynth Sawanimator
Page 3 of 3 [73 Posts]
Goto page: Previous 1, 2, 3
Argitoth
G2 patch files: 6
PostPosted: Tue Aug 31, 2010 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Yves.
I have a friend who is having a problem (maybe?) with the saw animator I built for him. This is his message:
"Last night I plugged it up and it mostly seems to work fine. I do get a popping sound out of the 2nd channel when nothing is plugged in to it. With nothing going to the "In" of channel 1 and the 1 out going to the amp I don't get anything, but doing the same with channel 2 gives the popping. Once something is plugged into channel 2 the sound goes away and it sounds fine. Got any ideas on what it could be?"
Thank you,
-Elan
yusynth
PostPosted: Tue Aug 31, 2010 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a perfectly normal behaviour, the saw animator needs to be fed with something (i.e a sawtooth) otherwise the output delivers the DC of the internal modulator. There is no point at listening at the output of this module if nothing is plugged in at the input Wink
Yves
Argitoth
G2 patch files: 6
PostPosted: Tue Aug 31, 2010 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Yves! I thought that was the case.
Ojd
PostPosted: Sat Oct 02, 2010 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to interrupt conversation, but can anyone post a samples of saw animator itself (normal operation mode) fed with something else than saw wave, any samples really? It seems like it does magic to single vco.
yusynth
PostPosted: Sun Oct 03, 2010 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Feeding it with something else then a sawtooth is meaningless because all the effect is based on a saw. For example if you feed it with a triangle what you get is the equivalent of a mix between a triangle and a PWM pulse. Feeding it with a sqaure returns a square. Feeding it with some audio signal gives a distorted audio signal but if that's what you want you can get a better result with a disto box...
Yves
Ojd
PostPosted: Sun Oct 03, 2010 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
The reason i'm asking is because i've found this one
http://www.cyndustries.com/modules_sawtooth.cfm
I'm sure you are aware of this module, seems like it has pulse wave animation too (like many vco's doing pwms at different speeds), so i thought if your module could do that too?
yusynth
PostPosted: Sun Oct 03, 2010 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
But this type of feature is already available on PWM VCOs, feed the PWM with a random votage and you'll get the same effects.
Yves
thermionicjunky
PostPosted: Sun Oct 03, 2010 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm guessing that the Cyndustries module processes the output of the saw animator to produce a squared version. It uses the same input saw. You can do similar things with external waveshapers.
LektroiD
PostPosted: Thu Dec 02, 2010 11:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there an interconnection wiring diagram available for this add on board?
I'm not too great at reading schematics.
LektroiD
yusynth
PostPosted: Sat Dec 04, 2010 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
No, but I will try to draw one...
Yves
LektroiD
PostPosted: Fri Dec 10, 2010 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Much appreciated. Looking forward to getting this module working Smile
LektroiD
LektroiD
PostPosted: Mon Jan 03, 2011 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Assuming Yves is busy since there's been no further action in this thread for the past month, I wondered if anyone else has managed to get this working?
I have both boards assembled, but just awaiting an interwiring diagram. Does anyone else who has successfully interwired them have a few spare moments to put a basic wiring diagram together for me (and whoever else is stuck on this)?
It doesn't have to be anything flash, a simple hand drawn sketch would do the job.
Thanks in advance Wink
LektroiD
iopop3
PostPosted: Tue Jan 04, 2011 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
My pcb is still in the backlog, but this is how I would wire it up. Not tested so it might be some errors!
For the first part, the waveshaper, exchange the red cable going from LFO to Mod in the original wire diagram with,
Code:
                     ________________
LFO ---> Triangle_in*| add on board |*Sine out --> Mod in
                     |______________|
and for the output,
Code:
                                    ________________
Dry Saw input       -->      Saw In*| add on board |*Output --> New Output
Original Saw Output --> Shifted Saw*|              |
                                    |______________|
"Dry saw input" is the same signal as you insert into the SAW pin, copper coloured.
"Original Saw Output" should the the purple output pin.
"New Output" is your output jack on the panel.
Do the same for both animators.
Yves mentions a switch on the output, that have not been added in this example. Havn't had the chance to try it out, so not sure if you need it.
yusynth
PostPosted: Tue Jan 04, 2011 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes iopop3, your diagram is correct, nice ascii rendering by the way !
Yves
LektroiD
PostPosted: Tue Jan 04, 2011 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can't really understand the ascii examples as there is only the add on board and not the main board showing, plus the labels you used don't match up with what's on the silk screen (I guess it's ok if you already know how it should be).
Although from what I can work out it would be like this..
 Filesize:  90.51 KB
 Viewed:  320 Time(s)
LektroiD
yusynth
PostPosted: Wed Jan 05, 2011 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
No LektroiD, your diagram is not correct. I sketched one very quickly that shows the wiring for one channel only in order not to overload the sketch.
Here it is :
 Filesize:  121.79 KB
 Viewed:  366 Time(s)
Yves
LektroiD
PostPosted: Mon May 02, 2011 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here it is :
I wired up exactly as you suggested, but it doesn't work. I have attached an mp3 example of what I'm getting. It was working better without this add-on board, at least I had some kind of saw happening. The results are the same for both sides of the circuit (saw anim 1 and saw anim 2).
Basically I get clicks as the modulation cycles. you can hear the saw input as I switch it on and off. I also increase the rate up and down, once without the saw and second time, with.
Untitled.mp3
 Filename:  Untitled.mp3
 Filesize:  554.29 KB
 Downloaded:  1236 Time(s)
LektroiD
yusynth
PostPosted: Mon May 02, 2011 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Post a photo of the add on board track side and one photo of the components side such that I can check there is no mistake.
Just to be sure were you powering the addon board ? I did not show the power wire on the wiring diagram because it was obvious but one never knows...
Yves
LektroiD
PostPosted: Tue May 03, 2011 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I piggy-backed the power from the main board.
Top
 Filesize:  2.76 MB
 Viewed:  305 Time(s)
Bottom
 Filesize:  2.04 MB
 Viewed:  324 Time(s)
LektroiD
LektroiD
PostPosted: Sun May 08, 2011 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please let me know if those photos are ok, or if anything is amiss.
I left the saw in 1 tip connected to the switch terminal of saw in 2, would that cause any problems? It's the only wiring that's not mentioned on the add-on board.
Incidentally, has anyone managed to get their add on boards working successfully, or am I the only one who can't get it working?
LektroiD
yusynth
PostPosted: Sun May 08, 2011 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
The wiring diagram is logically completed by mirror symetry.
I know at least three other people beside myself who built it without a problem.
I cannot see any obvious error on your PCB however you may check with a continuity tester that there is no shortcut between tracks or a microbreak in a track.
Check that the ICs on the board are correctly powered (+15V on pin 8 an -15V on pin 4). Have you checked the AOP ICs ?
Yves
bassculture
PostPosted: Tue Jul 11, 2017 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm gonna build two Yusynth Saw Animator with all the bells & wistles Cool
- depth pot
- saw to sine converter
- mod output (why not having two more lfo's)
- mixer section (see below)
i'm refering to this thread and those two others :
mod output >
https://www.muffwiggler.com/forum/topic-21170-0.html&postdays=0&postorder=asc&highlight=&sid=a8006fd2316ed4ea68c4480bfb81f592
http://electro-music.com/forum/topic-49965.html
I have questions :
- i suppose the sine to saw converter can be made switchable
with a non shorting SPDT switch ?
- the original saw will be phase reversed at the output of the mixer ?
when layering, i would not want this.
i'd be more interested by a summing stage with Dry/Wet control
and phase flip switch for the phase shifted saw.
in the best case scenario with a VC crossfader
Do you think a circuit like this one could be integrated ?
either the manual or the VCA
http://electricdruid.net/single-vca-crossfader/
thanks
wackelpeter
Audio files: 10
PostPosted: Thu Aug 31, 2017 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
just finished one half of the saw animator on the free parts of the stripboard from the Mutant BPF Version. Worked from start, but i was a bit curious how it would be if i can attentuate the Input Signal... so i placed a 100k attentuating pot with a 4k7 resistor in series from it's wiper and well it worked and gave some interesting results... fully cw normal behavoiur and with the Input level slowly reduced it gave some intersting sounding and looking figures until when nearly Zero Input only the Modulator Input remained at the Output...
