Stomper
Stomper
Posted: Mon Nov 22, 2010 6:02 am Post subject:
Sloved the gate with another env with gate like settings and a switch between regular env and gate env.
still wonder if its possible to make the portamento act like the one on the sh.
Stomper. |
Joined: Apr 03, 2004 Posts: 24119 Location: The Netherlands, Enschede
Audio files: 279
Posted: Mon Nov 22, 2010 6:46 am Post subject:
Sounds like you want the portamento to never jump? If so just disconnect that jmp wire - or route it through a switch to make it configurable.
Re. the amp gate ... could put a VCA after the gate that is either controlled by the envelope or by the gate itself?
Not sure I understood the issues correctly. _________________ Jan
Stomper
Posted: Wed Dec 15, 2010 7:12 pm Post subject:
Got the jump thing while playing with the patch. not exectly the way the real sh works but you cant get everthing i guess.
One thing though, when i connect the portamento to the pitch, the pitch goes down about 3semitones i think for some reason. is that normal?
the input on the osc is fully open.
Regards,
Stomper. |
Stomper
Posted: Sat Dec 25, 2010 4:01 pm Post subject:
| Stomper wrote: | One thing though, when i connect the portamento to the pitch, the pitch goes down about 3semitones i think for some reason. is that normal?
the input on the osc is fully open. |
Anyone? |
G2 patch files: 626
Posted: Sat Dec 25, 2010 5:24 pm Post subject:
| Stomper wrote: | | Stomper wrote: | One thing though, when i connect the portamento to the pitch, the pitch goes down about 3semitones i think for some reason. is that normal?
Anyone? |
I don't know much about the classic but, if you feed a note value through a portamento, then patch that to a pitch input of a master oscillator, the KBT should be turned off. The pitch mod input should also be at 100%
I think the Keyboard1 module in the patch is surplus to requirements, just use the Patch Gate signal for the ADSR as well (unless you want multi-trigger?).
The SH101 had the two glide modes, so a switch before the Jmp input should allow for the normal glide mode.
The G2 has 'built in' portamento(Glide) settings, including an auto (sometimes called legato or fingered) mode. |
