Switching Variations On G2 Engine Via External MIDI
Page 1 of 1 [7 Posts]
TEMAS
G2 patch files: 6
PostPosted: Fri Dec 03, 2010 4:28 am    Post subject: Switching Variations On G2 Engine Via External MIDI
Subject description: How to set up an external device to switch variations
I'm having trouble setting my MPD32 to switch variations of the G2 Engine.
I've worked out a way to do it by assigning the MPD32 buttons to Momentary Constant Switches which in turn are sample & held and sent to MIDI CC70.
But the problem is that when I press a button on the MPD32, the patch switches variations before I've taken my finger off the button, so the previous variation never receives the release signal of the button.
So when I return to the first variation, the Momentary Switch is still on.
Any ideas on this?
 Filesize:  162.66 KB
 Viewed:  7143 Time(s)
 Filesize:  163.11 KB
Trevor Masterson
TEMAS
G2 patch files: 6
PostPosted: Fri Dec 03, 2010 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I've made a solution. Not that elegant and fairly expensive too. But it works. I'm sure there must be a cheaper solution.
 Filesize:  245.37 KB
 Viewed:  368 Time(s)
Switch Variations.pch2
 Filename:  Switch Variations.pch2
 Filesize:  1.46 KB
 Downloaded:  1743 Time(s)
Trevor Masterson
PostPosted: Fri Dec 03, 2010 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't know if it is an option in your case, but doing the CC70 change from another patch/slot would avoid the original problem.
PostPosted: Fri Dec 03, 2010 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why not just program the MPD32 to send CC70 straight to SlotA (on SlotA's channel)?
TEMAS
G2 patch files: 6
PostPosted: Fri Dec 03, 2010 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes, of course. That would definitely be cheaper.
MPD32 Buttons 1-8 assigned directly to the mixer buttons 1-8.
 Filesize:  126.8 KB
 Viewed:  7041 Time(s)
Trevor Masterson
TEMAS
G2 patch files: 6
PostPosted: Fri Dec 03, 2010 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm using momentary buttons on the MPD32, not the pads, and I'd like to have button 1 for variation 1, button 2 variation 2, etc for 8 buttons.
AFAIK the buttons only send 127 for on or 0 for off, so I can't send all 8 buttons to CC70. At least I don't think I can.
Trevor Masterson
PostPosted: Wed Dec 08, 2010 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I forgot how limiting Akai MIDI interfaces can be sometimes. You're on the right track, then.
