steampump
G2 patch files: 14
Posted: Fri Feb 11, 2005 2:31 pm Post subject:
Advice and help for PC Sequencer needed |
First i hope this is the best place for my question.
Since i have installed XP I'm in big trouble. All my old sequencers seem to be obsolet.
I have now bought Cubase but i'm not really happy with for synthesizer and drum control.
My first good sequence was cakewalk under DOS, and then i found Cakewalk apprentice for windows and it worked fine until W98se release.
But XP is no more supporting midi map where i could mix intenal and diffrent exernal midi device. I have not found any tricks yet for a maybe midi map replacement. (or there one?)
So if i want a new midi sequencer i need your advice.
In my old cakewalk i could make different a loop for each track and actived or mute just with simply with keyboard. I could also select all different device for each track. No audio is needed.
I have also used Sonar Start under W98se (do not work under XP and i have lost the installe procedure delivered with the german Keys Magazin Klemm does no more colaborate with Cakewalk ) but do not remeber if diffrent loops are usable for diffrerent tracks. So my question is there an easy midi XP sequencer who can do this job and have frienly handling ?
What are you using with your synths under XP , live on stage ? _________________ Artworks Music Computer |
Posted: Fri Feb 11, 2005 2:45 pm Post subject:
Cubase is not bad at all. Are you sure you have invested enough time learning that application? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
steampump
G2 patch files: 14
Posted: Fri Feb 11, 2005 3:03 pm Post subject:
I do not say cubase is bad, but i'm missig the loop option of the old cackewalk programms.
I could make a bassdrum track of 3 bars , a snare track of 10 bars and toms of 5 bars and mix them together. Then repeat each track for a certain times. An other thing i miss is the midi offset to create midi effects. (In realltime).
Last but not list, in Cubase there is a very bad midi sync when you use same midi notes with same chanel on diffrent tracks. It sounds garbage.... but not in Cakewalk. _________________ Artworks Music Computer |
Posted: Fri Feb 11, 2005 3:30 pm Post subject:
Ableton Live4 meets all of those criteria. Very easy to use and well laid out, very stable too. _________________ Kassen |
Posted: Fri Feb 11, 2005 3:37 pm Post subject:
Hmm, yup... Kassen is right. Live is THE app for you!  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Dichotomy
Posted: Fri Feb 11, 2005 6:55 pm Post subject:
FL Studio 5 Producer Edition |
If your on XP, and are willing to spend about $150, I would buy a version of FL Studio.
There is no limits, and the new one almost is Fruity Loops meets Logic, however Logic has a certain sound.
You can make loops with any amout of bars you wish.
Feel free to ask any questions. _________________ -=Carpe Noctem=-
(website comming soon) |
Joined: Jan 31, 2003 Posts: 18263 Location: Durham, NC
Audio files: 229
Posted: Fri Feb 11, 2005 8:14 pm Post subject:
I guess the app is "almost" free... but yes.. it is very promising.. Live is expensive.. and I guess you have to be familiar with it it before you understand you really need it. Personally I think Live is magnificent, but I haven´t yet seen any use for it. i am quite pleased with Cubase 5.2. I am simply using it as a "better" reel to reel" multitracker. Tracktion is interesting because it allows you to use basically one window no matter what you do. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
steampump
G2 patch files: 14
Posted: Sat Feb 12, 2005 6:56 am Post subject:
Is there no midi only sequencer any more for XP ? _________________ Artworks Music Computer |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Sat Feb 12, 2005 7:21 am Post subject:
Steam, it sounds like what you want to do is exclusively midi stuff, not audio.
Do you want to do midi recording too, or just pattern manipulation?
Applications like Cubase, Live, Sonar are probably overkill.
I'm sure there are lots of midi oriented programs, maybe they are older but I guess that some of them will run in XP. Most people these days seem to be manipulating audio, not midi. I can't help you much with this one, since I use hardware sequencers for these functions. |
steampump
G2 patch files: 14
Posted: Sat Feb 12, 2005 2:26 pm Post subject:
Your right Greg but only midi programm seems overflooded by all in one products today.
Easy access to command seem not have priority in the new programs,
but Ableton Live and Tracktion may be an alternativ. I just used the Live demo.
Or is there a new hardware sequencer with good computer exchange ?
Its a pitty that Cakewalk has left the philosophie of there first product, when they use midi loop support and very clear overview of what should be used first. I could just use the keyboard to navigate through a stylesheet like surface, and change parameters with 1 or 2 keystrokes. But now cakewalk and cubase have no big differences and are no more made for midi live performance.
Maybe some one knows how making working the cakewalk apprentice with XP. It works only with the internal midimap (who cannot be modified ) the other midi devices do not appair in midi in and out liste. This Cakewalk is a 16bit release , maybe i have to add something in win.ini or system.ini to make the device visible but what ? _________________ Artworks Music Computer |
Audio files: 229
Posted: Sat Feb 12, 2005 6:51 pm Post subject:
Steam. If you are only interested in MIDI, the look carefully at Keykit. It's very powerful. If you are a programmer, then this is THE program to use.
See... http://nosuch.com/tjt/software.html
The author, Tim Thompson, is a member here, TJT. _________________ --Howard
my music and other stuff |
steampump
G2 patch files: 14
Posted: Sun Feb 13, 2005 3:06 am Post subject:
Hy Mosc, thanks. Sometime Chrismas is comming twice a Year.
I have just downloaded Keyit with all doc . And ..... it works ...... Whoawww.....
Probably the nicest toy after my G2 Engine.... I will probably spend less time programming Pinball Tables )
Ok.this programm is not no made for window addicted.
But for experimental music it is a amazing tool. Programmer faculties are needed. _________________ Artworks Music Computer |
Audio files: 229
Posted: Sun Feb 13, 2005 7:33 am Post subject:
Great, Steam. Glad you like it. Be sure to join the keykit mailing list. You'll find support for keykit there is just as good as support for the NMs is here.
Please let us know what you come up with. _________________ --Howard
Rinxai
Joined: May 26, 2007 Posts: 10 Location: Flat Top Mountain
Posted: Wed Jun 27, 2007 3:31 pm Post subject:
If you're still checking out sequencers, you may find Zynewave Podium ($90) an interesting option. It is professional, unique, highly flexible and stable. Altho released in 2004, has been in development since 1990.
After trying many sequencers out there I'm real happy to finally find a DAW where work flow is swift, smooth and robust.
http://www.zynewave.com |
