Omega
Posted: Mon Mar 28, 2011 6:03 am Post subject:
Filter adjustments Subject description: How to adjust Filters to 1V/Oct |
Hi everyone,
I am new here and have a question on adjusting filters to the 1V/Oct characteristics.
MiniMoog Filter:...
- Set the filter to auto-oscillation (EMPHASIS turned fully clockwise)
==> o.k. understood
- Connect a keyboard (CV/GATE) to the V/Oct input
==> So far so good
- Play a tune and check the goodness of the tracking
==> How and what should I do here concrete ? Should I check for example, when I double the Voltage (from 0V to 1V) that the auto-oscillation will also double the frequency ?
- Slightly adjust T1 to achieve a good chromatic tracking.
==> Same question as above
Steiner Filter:
Trimming is very easy. Adjust the 2k trimmer in order to obtain a V/octave tracking.
==> No self oscillation ? How should I obtain 1 V/Oct tracking?
Thank you in advance answering my silly questions
Bernhard |
Omega
Posted: Thu Apr 28, 2011 11:11 am Post subject:
Hi everone,
since I didn't get any response on my previous problem description, I will start again describing my problem with an ARP Filter, hoping to get a reply this time.
I just went through the trimming procedure for the 1V/Octage adjustments. I do not have any problem to ajust 0 V at the node given in Yves' trimming procdure when applying 0V to the V/Octave input.
Also no problems I have when adjusting via T2 to 18,7 mV when applying 1V to the V/Octave Input.
But I do have a problem in understanding and trimming the next step.
Why should I now, returning to 0V at the V/Octave Input adjust via T1 -187 mV? Even if I try the 47K Trimmer whouldn't give me the possibility to adjust the voltage much more below -90 mV..
What do I do wrong? Did someone had also in the past these problems?
Where should I start searching.
I am looking forward for any suggestions!
Thanks you a lot in advance
Bernhard |
yusynth
Posted: Fri Apr 29, 2011 3:46 am Post subject:
Which version did you build ? 2SA798 one, BC557 one ?
The values on my site are given for the first version. How do you power the module ? _________________ Yves |
Omega
Posted: Fri Apr 29, 2011 10:56 am Post subject:
Hello Yves,
nice to hear from you! I build the 2SA798 version and I powered the module with +/-15V from the Formant power supply.
The problem I have is the understanding of what I am doing... First I use T1 to adjust 0V when applying 0V at the V/Oct input. This is clear. Now I put 1 V to the V/Oct input. Then I use T2 to adjust to 18,7 mV. Also o.k. and understood. Now I lower the voltage again to 0 V at the V/Oct input. And as I expected I measure nearly 0V (as measured in the first step). Why should I now adjust the voltage to -187mV. I think that then applying 1 V I will not measure the 18,7 mV. Where do I have the misunderstanding.
Thanks a lot in advance for answering my questions.
Bernhard |
yusynth
Posted: Fri Apr 29, 2011 11:18 am Post subject:
| Omega wrote: | Hello Yves,
Bernhard |
Hi
The idea is that the exponential relationship between the collector current (Ic) and the Vbe of the transistor leads to roughly a doubling of the Ic whan increasing the Vbe by a step of 18.7mV. Therefore the trimming procedure just checks that when a viriation of 1V is applied to the input I have a variation of 18.7mV of the Vbe. Roughly this set the V/Oct characteristic.
Now if I want the transistor to work in the appropriate range of voltage and frequency for this I need to lower the voltage to what will correspond to the lowest frquency.
What you need to understand is that the value of 18.7mV for 1V at the input is not to be taken in the absolute but it is a variation of 18.7mV at the base of the transistor for a variation of 1V at the input that matters.
Yves _________________ Yves |
Joined: Mar 28, 2006 Posts: 1369 Location: Kansas City, Mo USA
Audio files: 43
Posted: Fri Apr 29, 2011 12:04 pm Post subject:
I know that this may seem a little un-technical -- however, when I calibrate my v/8ve modules I simply connect my keyboard voltage out to the input of the module being calibrated. I simply play an octave interval on the keyboard and adjust the volt per octave trimmer until to the interval is at or near one octave.
Then, I go through the calibration process knowing that I'm already pretty close.
At the end of the day, I always finish the calibration by ear -- moving from one octave to a four octave spread (I tune to fixed reference oscillator).
I have built two Yusynth filters, namely the Diode Ladder and the MiniMoog filter. The Diode Ladder tracks over a wide range -- around eight octaves. The MiniMoog filter tracks over about four octaves (I tried and tried, and that's about all I could get).
The Steiner Filter is the next VCF on my do-list. _________________ -- Kevin
http://kevinkissinger.com |
Omega
Posted: Sat Apr 30, 2011 3:41 am Post subject:
thanks a lot for all those explanations. I did some measurements and want kindly ask you to look at the results and tell me, if I can sleep better now and if everything looks fine
The basics for the measurements were always the same: First apply 0 V to the V/Oct input and adust T1 to 0,000 V. Second step apply 1 V to the input and adjust T2 to 0,0187 V. Then I increased the voltage step by step by 1 V and I measured the Voltage at the given node.
0 V ==> -187,0 mV ==> starting point
1 V ==> -166,1 mV ==> Delta: 20,9 mV
2 V ==> -145,9 mV ==> Delta: 20,2 mV
3 V ==> -125,6 mV ==> Delta: 20,3 mV
4 V ==> -105,4 mV ==> Delta: 20,2 mV
5 V ==> - 85,4 mV ==> Delta: 20,0 mV
6 V ==> - 65,5 mV ==> Delta: 19,9 mV
7 V ==> - 46,0 mV ==> Delta: 19,5 mV
8 V ==> - 26,8 mV ==> Delta: 19,2 mV
9 V ==> - 8,0 mV ==> Delta: 18,8 mV
So from my point of view it doesn't look bad regarding the linearity. So it's quite linear up to 7 Volt but I never reached these 18,7 mV I adjust at the second step in the overall procedure.
In a second step I apply 1 V and adjust the voltage with T2 to 168,3 mV which are exactly the 18,7 mV less then 187 mV from the beginning which I thought the delta should be. But again for the rest of the measurements it seems to be always about 20 mV difference.
1 V ==> -168,3 mV ==> Delta: 18,7 mV
2 V ==> -147,7 mV ==> Delta: 20,6 mV
3 V ==> -127,2 mV ==> Delta: 20,5 mV
4 V ==> -106,7 mV ==> Delta: 20,5 mV
5 V ==> - 86,4 mV ==> Delta: 20,3 mV
6 V ==> - 66,3 mV ==> Delta: 20,1 mV
7 V ==> - 46,6 mV ==> Delta: 19,7 mV
8 V ==> - 27,2 mV ==> Delta: 19,4 mV
9 V ==> - 8,1 mV ==> Delta: 19,2 mV
So, I only get the 18,7 mV at the first measurement. Then again I get about 20 to 20,5 mV for each step until 7 V
So what's your opinion ?
Thanks again for your patience
Bernhard |
yusynth
Posted: Sat Apr 30, 2011 4:19 am Post subject:
Thes figures look OK to me but don't be obsessed by matching exactly the values I gave on my page, they are given there to provide a rough indication of the trimming because in the end what is to be done is that one sets the filter into auto-oscillation mode (Full resonance setting with no input signal) and then by ear one checks that the filter is tracking well and if necessary readjust the V/oct trimmer.
Enjoy you filter,
Omega
Posted: Sat Apr 30, 2011 7:45 am Post subject:
Hello Yves,
thanks a lot for your quick response! So I will sleep better tonight .
But ... I'm afraid, I have the next stupid question.
What do you mean by : "...and then by ear one checks that the filter is tracking well and if necessary readjust the V/oct trimmer."
What should I hear and what not ? Playing the keyboard what should I expect ?
What can be heard, even when it's wrong ? How can I distinguish between "Bad" and "Good".
Sorry again for these questions. But understanding and learning is important for me.
Bernhard |
yusynth
Posted: Sat Apr 30, 2011 7:53 am Post subject:
Bernhard |
In auto-oscillation the filter whistles by itself, if you use a CV/GATE keyboard to drive the filter (V/OCT input) then the whistle of the filter must follow the keyboard play.
If it plays in tune over four octaves then it's OK if not then return to trimming. _________________ Yves |
Omega
Posted: Sat Apr 30, 2011 9:19 am Post subject:
Yves,
I just plugged in my keyboard and Midi/CV converter and I can measure the CV's perfectly. I plugged the CV into the V/Oct input of the filter and raise the Resonance poti. I see a nice sinewave at a given frequency. When I now play the lowest note and then the highest note on the keyboard, I see a very small change in frequency on the Oscilloscope.
Is that the point where I should readjust the V/oct to achieve the smallest change when playing the keyboard ?
Is that the process of "tracking" ?
Bernhard |
Omega
Posted: Sat Apr 30, 2011 9:53 pm Post subject:
I have to apologize, my last post was not correct. Don't know exactly what I was doing wrong, but after a while I saw the nice sinewave changing its frequency when playing the notes. The first surprise was, that I can see the sine wave but plugging into an amp I cannot hear anythng. Strange... Until I played a bit with the Frequency Pot. The whistles were in a range, that I simple cannot here (far behind 15 kHz). Turning the Pot i get now the sinewave auditable.
But now the next and hopefully last question. Which of the trimmer is the one for the 1 V/Oct? T2 ?
I tried it with T2 and it's a bit hard. So not more than 3 Octaves I get in sync with 1 V/Oct. Should I do anything to get it better or should I live with that results ?
Bernhard |
yusynth
Posted: Mon May 02, 2011 7:47 am Post subject:
T2 (2.2K) is the V/OCT trimmer just as it is written on the schematic, and the component layout silkscreen and T1 (47K) is the trimmer for setting the lowest frequency end (the cut-off frequency limit when the FREQUENCY pot is set to min). _________________ Yves |
