Joined: Mar 28, 2006 Posts: 1369 Location: Kansas City, Mo USA
Audio files: 43
Posted: Fri Apr 29, 2011 5:33 am Post subject:
Re: Just built two VCLFOs |
| kkissinger wrote: | | Also, on the LOW frequency range, I get a large offset voltage. Anyway, once I get non-polarized in place I hope this takes care of the symptoms. |
Just to follow up: I reviewed the schematic and found that I had missed that the VCLFO has separate offset adjustments for the low and high ranges. Thus, the offset problem was nothing more than a trim adjustment.
Thus, the only outstanding issue is the sync issue -- not a huge issue and could almost be a "feature".  _________________ -- Kevin
http://kevinkissinger.com |
kupfer_m
Posted: Mon May 02, 2011 8:25 am Post subject:
| yusynth wrote: | | LektroiD wrote: | | The spikes are really obvious through a VCF or VCA. Any way to tame them? |
Try and change the tantalum cap until you minimize the glitch. |
I have the same problem with my VC-LFO2. But I also get spikes on the x1 setting. Will try with some other capacitors. |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Wed Jun 29, 2011 4:44 am Post subject:
| kupfer_m wrote: | | yusynth wrote: | | LektroiD wrote: | | The spikes are really obvious through a VCF or VCA. Any way to tame them? |
did the other capacitors work?
Just a thought, this thread could maybe merge with the other VCLFO one, since it's the same issue _________________ LektroiD |
kupfer_m
Posted: Wed Jun 29, 2011 9:02 am Post subject:
No, still those nasty clicks...
Tried a MAXIM 7555 (more expensive) but still the same.
One day I will find it  |
vinnui
Posted: Mon Jul 04, 2011 9:07 am Post subject:
| I'm building 3 VC-LFO-2s, and today i've checked the waveforms of my first LFO build. The spikes were here. I've found, that i've used a NE555, which i've replaced with a ICM7555CN (I think it's a Philips part). After a complete recalibration procedure, the spikes are gone. |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Mon Jul 04, 2011 1:57 pm Post subject:
ive noticed on the schematics that there is no current limiting resistor going to the power pin of the 555. Would this be worth adding. usually its 100ohms.  |
yusynth
Posted: Tue Jul 05, 2011 4:05 am Post subject:
| adambee7 wrote: | ive noticed on the schematics that there is no current limiting resistor going to the power pin of the 555. Would this be worth adding. usually its 100ohms.  |
This is only valid if one uses the non CMOS version of the 555 ! Here we are using a CMOS 555 and this resistor is of no use. _________________ Yves |
adambee7
Posted: Tue Jul 05, 2011 10:10 am Post subject:
thanks yves . now to find some phillips 555.  |
gibrancurtiss
Posted: Sat Apr 08, 2017 6:57 pm Post subject:
changed C5 |
Changed the C5 from 47pf with other values 470pf and 1K.
| Description: |
| Filesize: |
158.32 KB |
| Viewed: |
307 Time(s) |
| Description: |
| Filesize: |
122.59 KB |
| Viewed: |
312 Time(s) |
| Description: |
| Filesize: |
153.44 KB |
| Viewed: |
276 Time(s) |
| Description: |
| Filesize: |
138.84 KB |
| Viewed: |
293 Time(s) |
