 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
Wicked Sequencer
Page 1 of 1 [6 Posts]
Roland Kuit
G2 patch files: 127
PostPosted: Mon Mar 21, 2005 12:12 pm    Post subject: Wicked Sequencer Reply with quote  Mark this post and the followings unread
Greets, Roland. It's springgggggggggggggg time!
Wicked Sequencer.pch2
You can do a lot with this Seq.
 Filename:  Wicked Sequencer.pch2
 Filesize:  5.34 KB
 Downloaded:  1824 Time(s)
Audio files: 165
PostPosted: Mon Mar 21, 2005 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wicked is a good description.
Thanks, Roland. Happy Sringtime... Cool
Roland Kuit
G2 patch files: 127
PostPosted: Mon Mar 21, 2005 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanx Mosc and have a nice ride Cool Cool Cool
settle
PostPosted: Mon Mar 21, 2005 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
at the risk of sounding like a complete fool...how does this thing work? i really dont get this style of sequencing, but i would be so happy if someone could explain it to me.
and also, why u arent using the prebuilt sequencers?
thanx
Roland Kuit
G2 patch files: 127
PostPosted: Tue Mar 22, 2005 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
The Clock module is slaved to the internal clock And is resetting the LFO 1. This LFO can be changed at phase, shape, rate and direction. The output of this LFO goes into 2 Compaire to logic modules. One is set low and the other is set high.So at some points, determed by the control signal of the LFO, you get a trigger signal which output is routed to the Mux8.(this one is controlled by the LFO as well, up and down etc.) So the LFO is pointing triggers at its routing. This trigger signals are signals at the highest level. So with a LevMultipier and a Constant module, you can shape this highes level to other levels(note frequencies) and routed the same way to a LFO controlled Mux.
This was in short my explanation of this patch. To answer your other question, sometimes i like more control over a sequencer than the provided ones by Clavia, and i like the challege to build some other stuff too! And her's a more complicated one,. Some sounds reminds me to Keith Emerson:)
Wicked Seq2.pch2
more complicated
 Filename:  Wicked Seq2.pch2
 Filesize:  5.92 KB
 Downloaded:  1539 Time(s)
settle
PostPosted: Wed Mar 23, 2005 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanx much
