How to make an on/off switch for a Reason Combinator button?
Page 1 of 1 [6 Posts]
buzz
PostPosted: Sun Apr 10, 2005 12:27 pm    Post subject: How to make an on/off switch for a Reason Combinator button? Reply with quote  Mark this post and the followings unread
If you could give me a lesson on how to do this I would really appreciate it.
Audio files: 278
PostPosted: Sun Apr 10, 2005 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure I understand, is this a G2 question or do you want to know for "Reason"
Jan.
buzz
PostPosted: Sun Apr 10, 2005 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry.
I'm trying to construct an on/off switch on the G2 to control an on/off button on a Reason module (the Combinator).
I'm assuming I have to somehow have two constant values but only send one at a time?
I'm a little overwhelmed. I was hoping there would be a simple module with a midi channel, a control value, and an on/off switch.
Audio files: 278
PostPosted: Sun Apr 10, 2005 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something like this ?
Jan.
example switch.pch2
Switch example
 Filename:  example switch.pch2
 Filesize:  897 Bytes
 Downloaded:  2397 Time(s)
buzz
PostPosted: Sun Apr 10, 2005 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay, I see.
I was on the right track (sort of).
Thanks for the help!
buzz
PostPosted: Mon Apr 11, 2005 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've attached a Combinator performance patch.
Each slot contains a Combinator front panel controller.
Load up 4 Combinators and blow out your ears!
Combinator.prf2
 Filename:  Combinator.prf2
 Filesize:  6.63 KB
 Downloaded:  1384 Time(s)
