<on air> Sorry, no program tonight. Chez Mosc
A different kind of chaos...sort of
Page 1 of 1 [8 Posts]
PostPosted: Wed Feb 27, 2013 9:53 pm    Post subject: A different kind of chaos...sort of
Subject description: Cellular Automata
I was thinking about the interesting sequencers that use more or less obscure methods to determine patterns... The Klee, the Random Looping Sequencer, Fonik's VCPS which uses grey codes, etc.
I'm curious if anyone has tried applying cellular automata in this area? I'd expect there's no practical way to implement them in pure analog terms, but with the prevalence of microcontrollers (Arduino, PIC) that doesn't seem like a very high hurdle.
I'm scratching my head over how one might go about implementing a user interface for them. Part of me thinks a simple table of the Wolfram Codes for 1 dimensional CAs that you could scroll through ought to be sufficient, but then how to display the nature of the rules in a way that's meaningful?
I did some googling and see a lot of instances of the CAs being applied as MIDI scores, including some nice results with piano sounds in "Wolfram Tones" http://tones.wolfram.com/
But I don't see an application to sequencing patterns. I'm curious if anyone else thinks that might be interesting. Some rules seem like they could be leaning in the direction of Ian's experiments with attractors.....
zthee
PostPosted: Fri Mar 01, 2013 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been thinking about this too - So I made plans for a Game of Life sequencer in Buchla format.
First you generate your game in a 16 x 16 matrix, it might be random- or a predefined pattern. Then choose what row you want your triggers to come from, and then either step through matrix sequentially (E.g. 1 to 16) or evolve the pattern for new triggers.
Made a sketch in Buchla format. It misses a lot of stuff - Like reset for the step, no way to select predefined patterns and so on.
But this is just for trigger pulses. But I guess you could just make a Klee out of it, or something like that.
PostPosted: Fri Mar 01, 2013 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's awesome. I was thinking tonight on the drive home that if I were doing it I'd be using a 16 wide 1D CA, you could set a starting state and let it propagate for 16 steps. Then you could pass the pulses out in any of the 4 cardinal directions up / down / left /right, possibly repeat each row a certain number of times, set loop points, use as a sequence of triggers or to drive a set of 16 pots. I guess you could make it 2 x 8 or 1 x 16 too.
All of which makes me think I probably ought to try implementing it in some kind of software first to be sure it's going to actually be as useful/interesting as it seems like it could be. Using something like that to drive one of those 16 x 16 lit button pads sure seems interesting though.
PostPosted: Wed Mar 20, 2013 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I've done some more thinking about this, and I think you can actually break this up into two pieces.
1) generating a data grid
For my original idea, generating the data grid would be a 1D CA, either just running 16 steps and leaving the grid fixed, or running each additional step as you needed it for the sequencer. But Life could be a different way to generate the data grid. A button grid of some sort could be another way to generate the grid, which brings the functionality closer to a more traditional trigger sequencer.
I think the biggest challenge for using a CA to populate the grid is going to be how to identify what rule set you're using.... To use Life would simplify that quite a bit, actually.
2) sequencing through the data grid
This can be entirely independent of the logic above, and can be used to create (or re-create, I imagine this is likely something that's been done before) a powerful grid-based sequencer.
Some of the other ideas that have occurred, though this sounds like its likely to be a beast (i.e. not something that's going to fit nicely on a 2U or 3U panel even in a 5U format):
switches across the top for loading--either the first row or somehow stepping through the grid--this plays back to other direct methods of populating the grid, but the first row would be needed to preload a CA as well. This plays very much like the load functions of the klee as I understand them.
momentary switches along each axis to select rows or columns.
LEDs along each axis to indicate a currently active point in the grid--possibly combine with the momentary switches.
Alternatively, use an LED button grid, which removes the need for both of those, but is more expensive....this sounds like it would be able to be implemented with software and a monome, but I don't have a monome sized budget Very Happy.
A set of pots for CV sequencing, one for each column (and/or one for each row? Hm, interesting idea to have CV outputs for each axis)
All the normal sequencer controls, run/stop, step, reset, as well as direction (forward / backward).
In addition to the obvious CV/step sequencing one row at a time, I could see using the columns as trigger sequences, or modifying the cycle sequence -- top to bottom or bottom to top, left to right or right to left, serpentine (alternating direction on successive rows).
Have a means to constrain start/stop column/row so you could confine the sequence to any sub-grid. This is inspired somewhat by what I've seen done with the Archangel with setting start/stop points.
Possibly define each row (for step sequencing anyway) as repeating a certain number of times before going to the next row.
It also seems like it might be interesting to traverse the grid in less linear ways, say a spiral or the serpentine and generate a single stream of triggers from it, or even generate separate CVs, this might work well if you take CVs from each axis and even if you do sum/difference on them.
I wish I had all the pieces in place to be able to play with this right now Smile. I have ordered an OctoMod (USB -> 8 CV outs controlled by OSC) and I think I could implement this in software and use the OctoMod to generate the outputs to the modular just as a proof of concept, but I don't expect to see the OctoMod built for another couple of months at least between lead time on the PCB, parts, and the actual build.
I've also done some of the initial investigation on how I might accomplish this with an Arduino controlling the logic, and I think it's feasible, but it'll take a few I2C expander chips to accomplish, so a PCB could be pretty big or rely on several (I haven't done any of my own PCBs for through hole, I'm not about to start first thing on SMD components Smile ).
TheAncientOne
PostPosted: Wed Apr 03, 2013 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ages ago, in my 'chaos theory & Fractals' craze. I did something like this, on the BBC micro, driving the then very cool 'Music 5000' system
The code sadly went a long time ago, and any recording were cassette, and I would have to dig through a big box to find them, but I can remember how it worked.
I used a Von Neuman automaton, initially of 16, then later 32 cells length. A rule was set up, and the first row initialised. whilst that was playing, a new row was generated and played, and so on.
I got my most pleasant results, using 8 cell values, 7 tuned tuned to a Balinese 'Pelog' scale, (I got the idea after listening to Neil Ardleys Jazz masterpiece 'A Kaleidoscope of Rainbows'), and a 'rest'. It was like a baby Gamelon player, with each sequence being somehow related to the previous one. Rules that worked in musical intervals were good, though many had a tendency to 'choke off' after a few rows played.
Some of the best results would play indefinitely, and some would deteriorate into a non-musical chaos rather fast. Some I left playing all evening whilst I was doing other stuff.
As I recall, part of the interest was in how I dealt with the end points of the rows. Looping back causes it's own problems, ( a circular automaton might never resolve, but then again, musically, that might not be a bad idea>
I don't think I could replicate the design now since it was written in 'AMPLE' the language for the Music 5000, after a prototype design in BBC BASIC, taken from a magazine article, but I will take a look to see if I can find anything.
A small processor would have no problems running it, though a neat way to input the rules on a synth module might be an interesting problem.
Edited: I forgot that I had 8 values - 1 for a space/rest.
Mike
PostPosted: Wed Apr 03, 2013 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great info! I doubt I would have thought to look into alternative scales, for example.
I have come into possession of a (slightly) used Monome 64, and I have a couple of Octomod USB->CV units that will come to me sometime this year, and I think once I have all that functioning I will work on software to try and implement this. If that works out, I'm also thinking I want to try to interface the Monome to an Arduino Leonardo (which is capable of acting as a USB Host) to make a standalone box out of it.
If you do find any of that other info I'd be really interested to learn more about your project.
TheAncientOne
PostPosted: Thu Apr 04, 2013 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
For a first try at this, I would suggest using Pd or Max. Pd is free, (as in beer), and does most of what Max does. If you have Ableton live, then there is a Max add on.
some links:
http://puredata.hurleur.com/sujet-6522-cellular-automata-synth
http://puredata.hurleur.com/sujet-8432-cellular-automata-midi-patch
http://puredata.info/community/member-downloads/patches/atct_topic_view?b_start:int=60
I haven't tried these, but they might make a good starting point. Pd is great for experimentiing with systems ideas.
Mike
PostPosted: Thu Apr 04, 2013 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, PureData was high on my list. I have an ancient laptop lying around I was going to load Linux on (I'm an IT geek in my day job), but unfortunately I'd forgotten that it doesn't actually have a CD/DVD drive, so I will have to set up to network load the OS first. Doable, but not dead easy, and takes time away from things like finishing my wogglebug Smile
The other positive for this laptop is that it has a touchscreen, so if I can get the Linux touchscreen drivers working, that opens up additional possibilities as well.
