today> Twyndyllyngs cancelled tonight Chez Mosc
Nord Modular G2 Demo
Page 1 of 2 [48 Posts]
Joshy
PostPosted: Thu May 02, 2013 10:05 am    Post subject: Nord Modular G2 Demo
Subject description: Patched
Hi everyone,
I had originally posted this over at GearSlutz, but they said it would be better released over here. Anyway, I really like the G2 modular software it has been really fun to make patches in the demo. Being in the demo though was so limiting so I decided to try and make the software a little more usable.
So, I'm letting people try my patched version of the G2 demo software that I refer to as the Nord Virtual Modular V0.01.
The features included so far are the removal of all "demo" interfacing, all modules are available, and some interface improvements. I'm planning on maxing out the voice count but have not yet worked out the function responsible for it. Hopefully I'll nail those voices down!
In the short time people have tested this from GS, I have been told some of the unlocked modules may not be working. No testing has been done on my part for the functionality of the unlocked modules, but it's possible there isn't any code behind a few of these anyway. I know the "4 Outs" module works though because that's the one I tested on. Razz
My intention here is not to spark any tension with Clavia or to break any rules. If I'm out of line with the posting rules then any moderator can feel free to modify this as needed. I'm providing this for educational purposes and the hope that Clavia would actually release a fully functioning modular software (the latter I doubt though).
Have fun! See the ReadMe for more infos.
NordVirtualModular_V001.zip
 Filename:  NordVirtualModular_V001.zip
 Filesize:  2.08 MB
 Downloaded:  5623 Time(s)
alkopop79
PostPosted: Thu May 02, 2013 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm on Mac but I do appreciate your work! I was just recommending it to a friend and tried to find it on the Clavia site. Thank you!
alkopop79
PostPosted: Thu May 02, 2013 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a legacy product anyway.
Joshy
PostPosted: Thu May 02, 2013 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad you enjoy it and hope your friend likes using it! Wink
Even though the software is legacy I can still see Clavia going either way with it.
Electromagnetic Wave
G2 patch files: 38
PostPosted: Thu May 02, 2013 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Joshy!
I tried it now. MIDI modules are not working. Audio In module receive a signal when I add one but I don't send nothing to it.
If this day come I wish it would be a software to use only with a specific sound card. Same as Access Virus do with a Digi or a Poco (use DSP, not CPU).
EDIT : I forget to say : Great work !!!
secretkillerofnames
PostPosted: Fri May 03, 2013 8:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Like!
*EDIT* FYI it works on OSX Mountain Lion under Crossover 12. Which means it probably works under Wine as well.
Joshy
PostPosted: Sat May 11, 2013 8:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for testing the modules out, I'll take a look into it sometime!
And thanks to all, glad you've enjoyed it!
iPassenger
G2 patch files: 78
PostPosted: Sun May 12, 2013 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one, don't think the DX7 modules are working and the vocoder doesn't work either.. The midi ctrl send modules are working back into the slot though. Smile
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Tue May 14, 2013 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hope you can keep working on this, do you think you might be able to get the input modules working? I suspect this will be tricky as there isn't a function to set the inputs from within the software.
iP (Ross)
Joshy
PostPosted: Sun May 26, 2013 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't worry, I haven't forgotten about it. Just busy with a lot of other things. Wink
I doubt I'll be able to get those modules working, but I haven't looked into yet. I'll check it out soon.
BigShort
PostPosted: Fri May 31, 2013 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
thx for your beautyful patch and also big respect for your work
Roland Kuit
G2 patch files: 127
PostPosted: Sat Jun 01, 2013 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Great work! Thank you so much!
ian92101
PostPosted: Sat Jul 06, 2013 12:36 pm    Post subject: MIDI Sync Reply with quote  Mark this post and the followings unread
Congrats on the work done here! amazing!
Has anyone found a way to use it as a master clock or to slave it?
I think before any other work is done getting the midi sync to work should be the priority. That way, we can integrate the software into our setups more readily. I am tired of sampling...
What do you all think?
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sat Jul 06, 2013 9:48 pm    Post subject: Re: MIDI Sync Reply with quote  Mark this post and the followings unread
welcome to the electro-music forum ian92101 Exclamation
ian92101 wrote:
...Has anyone found a way to use it as a master clock or to slave it?...
I have never tested the MIDI clock function of the Demo Software myself, but there is an option under the Demo menu Synth; Synth Settings to set the MIDI options for Clock Send and Ignore External Clock. Have you tried setting those the way that you want? You would also need to set the Demo menu selection Setup; Audio/MIDI to the appropriate MIDI I/O port on the host computer.
It really is a shame that the MIDI output modules are disabled in the Demo. The MIDI note and control output processing power of the G2 hardware is very impressive. It’s too bad that the Demo can’t show that.
varice
gnohm
PostPosted: Tue Feb 11, 2014 9:34 am    Post subject:  Is there some new things on this Reply with quote  Mark this post and the followings unread
First of all what a great job u done here Smile we are some guys that are super thrilled.
Was thinkin if u had made any new stuff on it Smile
Boom gnohm
calande
PostPosted: Mon Jul 14, 2014 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Josh for this great job! Cool
I installed Nord Virtual Modular along with MIDI Yoke (a MIDI utility application), BOME's Mouse keyboard (a soft keyboard), and Cubase.
When I play Nord Virtual Modular with its embedded soft keyboard, it is smooth, no problem. Same with BOME's Mouse keyboard playing the notes in the Nord Virtual Modular, it's seamless. However, when I play notes in Cubase, even slowly, Nord Virtual Modular takes a long, long time to return the sound, like 1-3 seconds between each note.
MIDI Yoke is used to interface between Nord Virtual Modular and other MIDI applications. Any idea why this is so slow when played from Cubase?
Thanks! Smile
gnohm
PostPosted: Mon Jul 14, 2014 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
i tried with the LoopBe virtual midi interface and also had latency big time tried after that to connect a cheap usb 1in/1out to my main midi interface and route that... and wham bam thank u mam no more latency Smile
calande
PostPosted: Mon Jul 14, 2014 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. It seems the culprit is MIDI-Yoke. Any idea to integrate Nord Virtual Modular as seamlessly as possible inside Cubase, with automation, preset recall, and so on? Rolling Eyes
gnohm
PostPosted: Mon Jul 14, 2014 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I think those "virtual midi interfaces" is to slow... i will try see later if i can do something here and then i will let u know Smile
cappy2112
PostPosted: Sun Jul 27, 2014 10:11 pm    Post subject: Re: Nord Modular G2 Demo
Joshy wrote:
Hi everyone,
I've installed Virtual Nord Modular on Crossover 13.2 on Mavericks 10.9.4
It runs OK, although I haven't tested all features, and I do hear audio.
I need to get more of the demo patches in that bottle, so i can test them.
uyoyu
PostPosted: Wed Aug 20, 2014 12:18 pm    Post subject: Re: Nord Modular G2 Demo
cappy2112 wrote:
Joshy wrote:
Hi everyone,
How did you get your USB ports to work with crossover ?
cappy2112
PostPosted: Wed Aug 20, 2014 1:16 pm    Post subject: Re: Nord Modular G2 Demo
[/quote]
USB ports? The demo doesn't need USB
uyoyu
PostPosted: Wed Aug 20, 2014 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, thought this was the open source editor thread Wink
calande
PostPosted: Thu Oct 16, 2014 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there, I've had success using Cubase 7.5 with LoopBe1 and Nord Virtual Modular. Automation works also seamlessly Cool
I had to disable LoopBe1 in the MIDI inputs of Cubase, though, to prevent a loopback.
I have one question: Do you know how to save the Audio & MIDI settings of Nord Virtual Modular? Every time I start it, these settings are reset Sad
3phase
G2 patch files: 141
PostPosted: Sat Nov 29, 2014 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
so where are the benefits of this patch in relation to the original version? you can access the locked modules but they dont work?
