Joined: Apr 03, 2004 Posts: 24423 Location: The Netherlands, Enschede
Audio files: 297
Posted: Thu May 15, 2014 10:42 am Post subject:
Fireface UFX noise issue |
Just posted this on the RME forums, maybe someone here has an idea about what is going on ?
Quote: | I'm using a fireface UFX under windows 8.1 over USB. Hardware revision 356, driver 1.043, using it under WDM with a buffer of 128 samples.
When I ouput a DC signal from software (I've tried the Clavia Nord Modular G2 demo, Audacity and my own soft synth) there is a quite audible white-ish noise present when I listen with headphones. The noise level scales with the absolute value of the DC level.
In normal music I had never noticed this, but was chasing a bug in my soft synth for which I needed to try the DC signal. Now I know that it is there I could easily design some 'music' in which it would be quite audible.
I do not understand why this happens, is it only my system doing this .. questions ...
Probably the easiest way to reproduce is to make a DC signal in a wave editor. In audacity I did this by making a 1 Hz square wave at full amplitude and then copying and pasting a DC section repeatedly .. a bit long is handy as switching the DC in and out causes some nasty clicks .. could make a fade in/out for it though. |
Quote: | In the car on the way home today I thought that maybe it would a sample rate conversion issue. Checked that just now, it is not. |
_________________ Jan
Audio files: 297
Posted: Fri May 16, 2014 12:25 pm Post subject:
Tried something else today, recorded some low frequency sine waves with CoolEdit - same problem, noise is present in the peaks of the sines, so on top of a 47 Hz bass tone I hear pulsating noise. Better audible when the frequency is lower, but still audible on 60 Hz sine too, for higher frequencies it gets masked by the tone, and the tones are getting too loud for my ears then too. So its a small effect, but I would like to know what causes it.
RME gives no reply BTW .. damn .. I could make interesting music with some effort showing the effect  _________________ Jan
Audio files: 297
Posted: Tue May 20, 2014 1:32 pm Post subject:
To which RME had to say :
Quote: | 1. Nobody uses WDM.
2. Nobody listens to DC signals.
3. If you playback a perfectly clean 47 Hz sine and notice noise modulations when listening to it on headphones then the UFX seems defective. Please send it in for warranty service. |
So basically I've still no idea.
Prolly got the WDM bit wrong or something?
The point isn't really the signal being DC, the point is that there is noise at high audio amplitudes and that it scales with the amplitude. _________________ Jan
BobTheDog
Audio files: 32
Posted: Tue May 20, 2014 3:33 pm Post subject:
Welcome to the wonderful world of RME support, I have had the misfortune of dealing with their hostile 'support' before. |
Audio files: 297
Posted: Tue May 20, 2014 3:39 pm Post subject:
Glad I'm not the only idiot then
What was your issue?
Anyway, yes it was a rude reply. _________________ Jan
BobTheDog
Audio files: 32
Posted: Sun May 25, 2014 2:08 pm Post subject:
It was some issue with the OSX kext, I can't remember exactly but I do remember they were arseholes. |
Posted: Sun May 25, 2014 5:06 pm Post subject:
WDM? Wavelength division multiplexing??? With the RME? Uh? Seriously? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun May 25, 2014 5:07 pm Post subject:
I have had absolutely no problem with my RME interface at all. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun May 25, 2014 5:10 pm Post subject:
BTW, I hope you didn´t mention the war when you messaged product support at RME. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 297
Posted: Sun May 25, 2014 5:34 pm Post subject:
I'm sorry .. I may have used some stupid word or something, and I indeed really have no idea about driver models.
But instead of giving silly replies .. could you maybe just try to make a say .. 30 Hz full amplitude sine wave play that and tell me if you hear noise on that when you listen with headphones at a level of say - 12 dB .. as that is what reproduces it here.
And yes, that is pretty loud, don't try it with your favourite headphones maybe and dont try it with frequencies of say 100 Hz, you ears wont like that.
Is RME some religion or something? djeez. _________________ Jan
Posted: Sun May 25, 2014 6:21 pm Post subject:
Tomorrow... later.. late here now. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun May 25, 2014 6:23 pm Post subject:
There are very few headphones that will play something like that in a way that does not distort. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun May 25, 2014 6:24 pm Post subject:
I only have favorite headphones. Beyer 770 Pro and AkG 271s. The bad stuff is gone years ago. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 297
Posted: Mon May 26, 2014 3:09 am Post subject:
It is not distortion, it is noise. _________________ Jan
