MFOS Wall wart power supply.
Page 1 of 1 [3 Posts]
isak
PostPosted: Sun Dec 14, 2014 10:11 am    Post subject:  MFOS Wall wart power supply. Reply with quote  Mark this post and the followings unread
Hi guys.
2 questions if I may.
If I'm using 12VAC 400mA wall wart and i wanna power with this power supply 2 or 3 modules rated say...30-50mA for eatch module.
1. Can I use 2 capaditors instead of 6?
2. Assuming the answer to Q 1 is yes, can I use 2 X 2200uF instead of 2 X 3300uF?
Thanks in advance,
Isak E.
Broadwave
Audio files: 6
PostPosted: Mon Dec 15, 2014 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Isak,
I think you may be pushing it a bit... In theory Ray's PSU would give you +/-12 @ 200ma per rail (using a 400ma TX), and if you use 3 modules at 50ma, for example, that would be 150ma per rail, which doesn't leave much headroom.
I usually calculate what current my modules use and double the result for a PSU - I'd up the wall wart to 600ma, just to be on the safe side.
Obviously the more smoothing capacitors and higher value, the better - I guess it depends what the modules are. If they're just simple "aux" modules then it may be OK, but I wouldn't skimp on smoothing if you're powering VCOs, VCFs etc.
If space permits, why not make your PCB with room for more caps, or (as I did on a project once, where room was tight) make a separate PCB for the caps and connect to the PSU with fly leads.
isak
PostPosted: Mon Dec 15, 2014 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you Andy.
actually its for small desktop effects.
there is not so much space inside.
this is why i thought to use smaller caps, cause of the size of the caps.
each desktop module is different, some with dual VCF + LFO i dont really think it comes to 50mA per module, its much less but i always take the higher bid.
size example:
so i'm working on shrinking the power supply to very small board.
thanks again Andy Smile
