 Forum index » DIY Hardware and Software » Musical Interfaces
3D Printed MIDI Drum Interface
Page 1 of 1 [11 Posts]
dshay
PostPosted: Sun Sep 28, 2014 10:27 am    Post subject: 3D Printed MIDI Drum Interface Reply with quote  Mark this post and the followings unread
http://shaytek.blogspot.com/2014/09/3d-printed-midi-drum-interface.html[/img]
CrystalWizard
PostPosted: Sat Oct 04, 2014 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
looks good. great idea, it would be easy to create any size matrix of pads this way.
http://www.gardenofsensualdelight.com/DWNLDMusic.html
http://soundcloud.com/user3694125
dshay
PostPosted: Sat Oct 04, 2014 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't done multiplexing with analog, something tells me the time it takes to charge the capacitor on the ADC might be too long. These days you'd be hard pressed to find a microcontroller with more than 16 ADC inputs on it but you could easily chain a SPI bus, then your only limitations on your main microcontroller would be chip select ports. What's really going to cut back the project would be the cost of the Force Sensing Resistors from Sensitronics or Interlink. The interlink ones are usually $6 a piece. I'd be inclined to not go much more than 16 and then have a PAD BANK select button to toggle the midi notes you're playing.
I'm multiplexing 8 rotary encoders with the project, I've got another electronics build that's going to take front burner for a little bit then I'll finish this one.
silvestro
PostPosted: Mon Jul 13, 2015 7:43 am    Post subject: 3d plan
Subject description: 3d plan
Hi !
Do you still have the 3D Plans (stl) ? ANd where did you find this type of pad ?
Thanks !
dshay
PostPosted: Tue Jul 14, 2015 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your follow up on this!
I moved the blog to a new web address:
http://ayatomm.com/forums.html/2015/06/06/3d-printed-midi-drum-controller-diy-project/
I have the web address of the pads linked there, and the STL but the STL file can be found here:
https://github.com/Ayatomm/DRUM_INTERFACE
The STL file is just a bezel (faceplate).
I can say the fit for the rubber pads is very good for the design file.
Thank you for showing interest! Please do share if you build anything from this. I'm getting back around to this project after finishing up a wireless MIDI XBEE radio project for my keytar. I will likely be publishing updates in the near future.
silvestro
PostPosted: Wed Jul 15, 2015 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot but i have "Error 404 - Not Found" for your new web address :/
Silvestro
dshay
PostPosted: Wed Jul 15, 2015 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I fixed the link.
Correct address here:
silvestro
PostPosted: Tue Jul 21, 2015 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
same problem :/ Maybe a private link ?
dshay
PostPosted: Tue Jul 21, 2015 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
jeez, I'm failing at the interwebz
Audio files: 261
PostPosted: Wed Jul 22, 2015 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Nah, all the links you posted are equal and work fine here Shocked
silvestro
PostPosted: Wed Jul 22, 2015 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Its work now, i dont know why x)
Thanks a lot, i will try to do my own alduino leonardo like here : http://txapuzas.blogspot.fr/2009/12/paperduino-leonardo-clon-de-arduino.html
I will try to do that in August normaly Smile
SIlvestro
