Audio jack configuraton
Page 1 of 1 [8 Posts]
rhdf
PostPosted: Sat Dec 05, 2015 5:34 am    Post subject: Audio jack configuraton
Subject description: L+R or L/R+ R or L/mono +R
I plan to design a small connector-board with "all" connectors I need for my project.
I started out with 2 1/4-inch TS jacks for Left and Right. Then I realised that I might want to have the option to just plug in a stereo-jack in one of them.
That is "easy" solved by having one TRS and one switched TS. When no plug is inserted in the R-jack that signal goes to the ring on the TRS.
The only problem I see with that solution is that if a mono-jack is inserted in the L/R connector and nothing in the R jack I will short the right signal to ground..
How to solve that in a smart way?
Another option is to have a L/mono solution. With a plug in only the L jack I get a summed L and Right signal to that.
I realise that I need some kind of summing circuit here that is only active when needed. Any ideas?
PostPosted: Sat Dec 05, 2015 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
you could use passive summing wih some resitors I think (for outputs).
 Filesize:  28.25 KB
 Viewed:  329 Time(s)
rhdf
PostPosted: Sat Dec 05, 2015 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems to be a "good enough" solution to get the L/mono R config
For a short-protection in the L/R R (I.e "someone" plugs a mono-jack in the stereo-jack) I probably need a resistor to ground in that path.. or?
rhdf
PostPosted: Tue Mar 15, 2016 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Noticed one thing with the circuit above.
There will always be a right signal present at the L jack, so if you plug in 2 mono plugs the right signal will go to ground in the L jack and to tip in R jack
Would it not be better to tap the right signal off the switched pin in the R-jack?
Then it is only there when no plug is inserted in the R jack
sure, you loose the ability to output stereo AND the right channel on separate cables Very Happy
PostPosted: Thu Mar 17, 2016 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
you mean like this ?
yeah, looks like that works Very Happy
I had a feeling it could be simplified just didn't see it.
 Filesize:  28.23 KB
 Viewed:  295 Time(s)
rhdf
PostPosted: Thu Mar 17, 2016 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Exactamundo
Now I will dig deeper in the mysteries of where to put that resistor
I've seen 2 different approaches. One where the feedbackloop of the output-amp connects after the resistor and one where its connected the "usual" way (direct to the outputpin)
PostPosted: Thu Mar 17, 2016 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you are talking about opamps than in this case put them outside of the feedback loop. I just happen to see a
thread on muffs earlier today with some examples and if you want to use resistors to mix signals together that's
the better option.
rhdf
PostPosted: Thu Mar 17, 2016 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Perfect. One thing off the todo-list Smile
