Posted: Tue Feb 02, 2016 5:51 pm Post subject:
WaveWiper V2.1: PCBs, part kits and front panels (euro) Subject description: interest check/now available! |
After doing a test run I want to order another batch of PCBs for the WaveWiper.
For those wondering what a WaveWiper is:
"The WaveWiper is a circuit, designed to be used as a synthesizer module, that merges two signals together.
It's based on Jim Patchell's Control Voltage Splitter and it splits two input signals in a positive and negative part.
The positive halve of one signal is then added to the negative halve of the other signal and vice versa.
The level where the signals are split can be controlled with a potentiometer (the Wipe pot) or an external
Control Voltage. It has 2 CV inputs, one with an attenuator and for the other one the Wipe pot works as an attenuverter."
More info about it can be found here, here and in the manual.
There are 2 PCBs, one that contains the actual circuit (Circuit Board) and the other one (In/Out Board), that can
be connected to the other PCB by means of pin headers, which has the pots and (1/8") sockets to be used as a 8HP
euro-rack module. The first limited run had green PCBs the next ones will be black. I also made a change to
the power connector so it can now have a MOTM or Dotcom connector as well.
There are 2 part kits available: Kit A with all the parts for the Circuit Board and Kit B with the pots & sockets
for the In/Out Board. So for a fully working (euro-rack) module you'd need both. (+PCBs +front +knobs)
And I also ordered some (euro-rack) frontpanels, made from 2mm PCB material. (black with white silkscreen).
I will most likely add an extra option for knobs aswell, so you can order everything to built a fully working module.
Now before I order more PCBs there are two things I would like to know:
First of course; how much interest is there ?
And how much interest is there in the Circuit Boards compared to the In/Out Boards ? If it is about the same I will
order and sell them as a set like the first run, but if there is a large difference I could order and sell them seperately.
estimated prices:
PCBs: € 1,75 (each)
Kit A: € 3,65 (Circuit Board parts)
Kit B: € 8,15 (In/Out Board parts)
Front Panels: € 4,45 (2mm PCB material, black & white)
Knobs (2x): € 2,35 (Davies Clone with brass insert)
worldwide shipping: € 3,10 ... € 6,85 (depending on weight)
123.49 KB |
| Viewed: |
419 Time(s) |
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider Twitch YouTube Last edited by PHOBoS on Sat Mar 05, 2016 5:30 pm; edited 4 times in total |
L´Andratté
Joined: Sep 23, 2012 Posts: 153 Location: Hamburg, Germany
Posted: Tue Feb 02, 2016 10:56 pm Post subject:
Hi Phobos!
I would like to build one!
1x Kit A
1x Kit B
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Sun Feb 07, 2016 3:03 pm Post subject:
pcbs?!
i'd take 4 at that price, i need some more to add to my backlog.
(dont need the front panel pcb just the brains) _________________ _Richard_  |
mcop
Posted: Sun Feb 07, 2016 11:12 pm Post subject:
Hi PHOBoS,
I'll take a pcb set and a panel when they're available if I may. |
cyclic
Posted: Mon Feb 08, 2016 5:59 pm Post subject:
yep, I'd take a pair of PCBs for sure.
lance |
Paradigm X
Joined: Feb 15, 2011 Posts: 363 Location: Null and void
Posted: Tue Feb 09, 2016 9:02 am Post subject:
Hi yes i would certainly like two of the main pcbs, no panel stuff etc tho.
Many thanks, and especially thanks for putting on the motm header (and for making the price so cheap!!)
Cheers, Ben |
cyclic
Posted: Fri Feb 12, 2016 1:14 pm Post subject:
Hey,
I'm actually only after a main PCB, not the in out one as I don't use standard jacks.
I'd thought before that they were coming together and I was just going to store the unnecessary one.
Cheers |
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Fri Feb 12, 2016 3:42 pm Post subject:
I'm in for two sets of PCB.s and panels.
Ivan |
Moosgummi
Joined: Feb 01, 2015 Posts: 15 Location: Hiltown, Germany
Posted: Wed Feb 17, 2016 3:49 am Post subject:
Hello PHOBoS,
I´d like one set of PCBs and a panel |
Posted: Wed Feb 24, 2016 11:15 pm Post subject:
Just in case I forgot... I'm after a front panel pcb only for my working WW  |
Posted: Fri Feb 26, 2016 6:45 am Post subject:
Nice!  |
raph36
Posted: Sat Mar 05, 2016 6:59 am Post subject:
hi there! is there any pcb+panel left for order ?, i'd like one or two
thanks |
khakifridge
Posted: Mon Mar 07, 2016 6:32 am Post subject:
| PHOBoS wrote: | | This is what the complete (euro-rack) module looks like. |
Neat.
I'd be up for a PCBs+panel set please, if there are still spares. |
Paradigm X
Posted: Mon Mar 07, 2016 7:13 am Post subject:
yeah, the completed module looks excellent. sadly for me its designing my own and hardwiring.
thanks so much for these, theyre such a good price, its very generous of you. ive ordered two. |
Paradigm X
Posted: Thu Mar 10, 2016 3:51 am Post subject:
hi
bit OT possibly, so apologies, but im looking into a panel design fro this in 5u (motm), and its a bit of pain - i cant fit two in one panel, easily, but one is quite sparse (lots of wasted space).
Do you have any suggestions as to a small utility module or something which would complement this circuit nicely?
(EDIT) looking at the schems, i guess at least i could add additional cv inputs?
many thanks, Ben |
Paradigm X
Posted: Thu Mar 10, 2016 7:23 am Post subject:
hi - many thanks. i had missed those posts, i will read them in detail when i get a chance. an lfo might well be a great addition, theres a few super simple ones floating around here.
cheers, Ben |
