Audio files: 705
Posted: Fri Jan 22, 2016 4:02 am Post subject:
I already sold a couple and there are some other others who showed interest so I am giving them a chance to get some first.
But if there are any boards left you're next on the list. There will probably be another run though. And yes I do want to make
panels, I need them myself anyway. I ordered some transfer paper from china to see if I can get good results with the
toner transfer method (will take a couple of weeks before that arrives). Another option would be using PCB material but
eagle lite doesn't support the panel size. So I have to find something else to design that with and figure out how to import an
image exactly to scale (I did make a design).
As for what it does have a look at the manual _________________ "My perf, it's full of holes!"
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider Twitch YouTube Last edited by PHOBoS on Fri Jan 22, 2016 11:38 am; edited 1 time in total |
Ayab
Posted: Fri Jan 22, 2016 10:07 am Post subject:
Wavewiper PCB |
Hi Phobos
Have been quietly following this thread and it is good to see your idea come to fruition. Lovely design.
I'm up for a pair of boards too - how much are they? Feel free to pm me your email and will paypal you and give you my address.
All the best Last edited by Ayab on Fri Jan 22, 2016 10:41 am; edited 1 time in total |
Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Audio files: 155
Posted: Sat Jan 23, 2016 7:25 am Post subject:
Sounds
I recorded some of the tests I wanted to try with my breadboarded wave wiper (s), here are some mp3s & descriptions of set ups .......
Description: |
one wave wipe with a vco square to in 1A and separate vco saw into in 1B , I am swinging the wipe set pot to start with then turn up the cv input which has a Mfos LFO patched up. |
Download |
Filename: |
1 wave wipe saw & squ in +lfo.mp3 |
Filesize: |
2.26 MB |
Downloaded: |
1068 Time(s) |
Description: |
2 wave wipes in series with a separate LFO into each cv input , again turning the wipe set pot and adjusting speeds of the lfo's , same inputs as before but changed the pitch of one VCO. |
Download |
Filename: |
2 wipes in series seperate lfo's to each.mp3 |
Filesize: |
2.76 MB |
Downloaded: |
1051 Time(s) |
Description: |
2 wipers in series this time with a Mfos wave freaker patched as an insert FX between output 1A and slave wiper 1A input , the wave freaker has a frequency divider & fold/ shape type actions , adjusting lfo speeds & amounts & wipe set adjustme |
Download |
Filename: |
2 wipes series with Mfos wave freaker inseterd between.mp3 |
Filesize: |
1.86 MB |
Downloaded: |
1040 Time(s) |
Description: |
2 wipers in series with a ian fritz 5pulser inserted between first wiper out 1A and slave wiper in 1A I use a slow lfo to hear the stepping sounds and adjusted the speed for lfo 2. |
Download |
Filename: |
2 wipes series with 5Pulser inserted beteween them.mp3 |
Filesize: |
3.65 MB |
Downloaded: |
998 Time(s) |
Description: |
this one I tried a delay FX between the wipers ,a dual sequencer is now playing the 2 VCOs , turning the delay time up & down, and adjusting the lfo speeds ..... at the very end of this file it sounds like a modular Status Quo riff , hehe , new terri |
Download |
Filename: |
2 wipes series with delay FX between them.mp3 |
Filesize: |
4.8 MB |
Downloaded: |
1079 Time(s) |
piedwagtail
Posted: Sat Jan 23, 2016 9:22 am Post subject:
Thanks for the samples.
I was wondering what it sounded like with harmonics of the same wave in both inputs, the 5-pulser gets in that area.
and
that Glaswegian drunken slur at the beginning of the last one is a good indication of the possibilities!
R |
Audio files: 705
Audio files: 155
Posted: Sat Jan 23, 2016 1:09 pm Post subject:
thanks , I am really looking forward to building the Quad one .
Dave. |
Audio files: 705
Ayab
Posted: Sun Jan 24, 2016 4:13 am Post subject:
Wave wiper |
Hi Phobos
Thank you will look forward to hearing if you have any spare |
Audio files: 155
Posted: Sat Jan 30, 2016 5:47 am Post subject:
Hi
Boards arrived early in the week , thanks Phobos , snapped off the top boards & got to work soldering the diodes / resistors / ic sockets / caps etc onto the 4 main pcbs .
Also finished the final layout on the panel (100mm x 250mm) , legends converted to blue and was thinking about the lfo's controlling a series wave wiper stack each , both stacks lfo amount into 1&3 / 2&4 would be swept the same direction , so I squeezed in 2 extra switches , one inverts the respective lfo1 / lfo2 into the slave wipers only, and the other switch will swap lfo 1 & 2 over (lfo2 to wiper 3 , lfo1 to wiper 4)
Hope to get the final sticker design ordered through next week sometime.
Description: |
Filesize: |
480.27 KB |
Viewed: |
474 Time(s) |
Description: |
Filesize: |
598.38 KB |
Viewed: |
465 Time(s) |
Audio files: 705
Audio files: 155
Posted: Sun Feb 14, 2016 4:16 am Post subject:
Hi all , I was bedridden with a nasty flu bug most of last week , managed to do a bit of construction on the W4ve wiper Friday evening & yesterday.
Panel drilled & sockets, pots , switches fitted to faceplate now , 4 boards plus add on veroboard circuit with the 2 LFO's is attached .
wiring to pots & jacks all done, now ready to test & record some demo sounds later tonight....
Description: |
Filesize: |
848.25 KB |
Viewed: |
472 Time(s) |
Description: |
Filesize: |
545.07 KB |
Viewed: |
473 Time(s) |
Description: |
Filesize: |
582.88 KB |
Viewed: |
475 Time(s) |
Audio files: 155
Audio files: 705
Audio files: 155
Posted: Sun Feb 14, 2016 9:55 am Post subject:
More sounds
First mp3 is 2 vcos sync'd together with square from 1vco and saw from 2nd vco going into wiper 1 & wiper 3 (left hand series stack) . A sequencer bass line runs the vcos and various combinations of internal & external lfo's / sequencer cv was tried on the cv inputs.
Second mp3 is a droney track , fed a differently modulated vco to each wiper (drums plugged into wiper 4), adjusting cv inputs & lfo speeds and wipe set positions.
Description: |
Download |
Filename: |
wipers with 2 vcos in sync.mp3 |
Filesize: |
3.65 MB |
Downloaded: |
986 Time(s) |
Description: |
Download |
Filename: |
W4VE drones.mp3 |
Filesize: |
9.51 MB |
Downloaded: |
1006 Time(s) |
piedwagtail
Posted: Sun Feb 14, 2016 2:05 pm Post subject:
Find it hard to discern what's happening without an oscilloscope
Like the soundworld of the second one, had me immediately reaching for this:
https://www.youtube.com/watch?v=YvlQ8TQsmQA
which is watchable in its entirety as Welt am Draht.
R |
Audio files: 278
Posted: Sun Feb 14, 2016 4:43 pm Post subject:
piedwagtail wrote: | which is watchable in its entirety as Welt am Draht.
Just watched part one - it has some interesting music! _________________ Jan
Audio files: 705
Audio files: 155
Posted: Mon Feb 15, 2016 11:07 am Post subject:
piedwagtail wrote: | Find it hard to discern what's happening without an oscilloscope
R |
Hullo
On the first set of demos , I had the outputs connected direct to a stereo channel on my mixer , with headphones it was easy to hear the sound sources being flung side to side with different modulations.
The mp3 "2 vco's in sync" , I used the W4ve wiper in a typical mono bass line patch up ...vcos / wipers / vca / mixer , it is acting as a type of bass line fattener almost like using something like Ken Stone wave folders to spice up a "plain Jane" synth line.
When patching up lots of wipers in series , I found just using a single output from the end of line wiper worked really well , when patching the 2 outputs of a full series chain of wipers to the built in 4 ch. mixer of my vca ( no panning) there was occasional cancellation and also distortion depending on where the wipe dials were set , but that is understandable with both outputs into a single vca.
Loving the twisting sounds this makes , perfectly suited for my Epicyclus & Orchard music
Dave. |
Audio files: 155
Posted: Mon Feb 15, 2016 11:18 am Post subject:
PHOBoS wrote: | nice demos Dave I especially like the W4VE drones.
and Welt am Draht is a great movie |
Thanks Phobos |
Audio files: 155
Posted: Mon Feb 15, 2016 11:41 am Post subject:
Thanks , wow that does look a good film , I will have to check it out when I get time some weekend .
One film I saw a few months ago was really good , The Parallax view (1974) |
madtextureenvy
Posted: Wed Jun 08, 2016 11:12 pm Post subject:
What just happened?! |
I think i just bought a WW2.1...
I was just reading up on some newish posts and reexamining your Simple Sampler(I have a YAKBAK that has been in my project drawer for 2 years now) not but minutes ago...
Then there is this blank spot in my memory... and suddenly I am staring at a PayPal confirmation...
Mwuhuhahahaha! |
Audio files: 705
