today> Various Artists Halloween Spook-O-Tron
 Forum index » DIY Hardware and Software » PAIA Equipment
PAIA low pass filter question
Page 1 of 1 [5 Posts]
Cfish
PostPosted: Fri Oct 07, 2016 1:17 pm    Post subject: PAIA low pass filter question Reply with quote  Mark this post and the followings unread
Hi all
Quick question for those of you with a stronger electronics background than myself.
I want to perf board this schematic up to play with. However I would rather use my existing 15v+- power supply for this version.
If I'm thinking correctly, I just need to change the values of R10 and R11
Problem is I loaned out the book I would usually refer to in such sercumstances.
Any suggestions?
I would like to try it rail to rail on the power supply to eliminate the offset
I'm thinking the diodes for control would still attach to 0V. Am I thinking correctly?
 Filesize:  211.73 KB
 Viewed:  459 Time(s)
Audio files: 29
PostPosted: Wed Oct 12, 2016 1:53 am    Post subject: Re: PAIA low pass filter question Reply with quote  Mark this post and the followings unread
Could you elaborate on this, because I have no idea what you mean?
Are you saying you want the emitter of Q1 to -15 volt?
Because the input as the output are both AC coupled.
Cfish
PostPosted: Thu Oct 13, 2016 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes grumble. That is what I was thinking.
Started to think about replacing the transistor with an op amp.
Not sure what my best option is.
I'm about finished with another project, then I can bread board it and start. Playing.
Just trying to minimize the magic smoke
Audio files: 29
PostPosted: Thu Oct 13, 2016 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
why not use the circuit as drawn? there is no offset, the output is ac coupled as is the input.
Cfish
PostPosted: Fri Oct 14, 2016 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Will give it a try.
