Yusynth - Mixout-VC Panner - headphones amp
Page 1 of 1 [21 Posts]
isak
PostPosted: Mon Oct 17, 2016 2:18 pm    Post subject:  Yusynth - Mixout-VC Panner - headphones amp Reply with quote  Mark this post and the followings unread
Hi Guys.
did someone here tested the headphone amp with 600ohm impedance headphones?
if so, did it worked well?
i attached the PDF scheme just in case.
Isak.
mixout-output-sch.pdf
 Filename:  mixout-output-sch.pdf
 Filesize:  70.22 KB
 Downloaded:  487 Time(s)
LFLab
PostPosted: Tue Oct 18, 2016 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Haven't tried it myself (all my cans are low impedance), but it'll probably work. You can always do away with the series resistor on the end, or add a resistor from the node between the output transistors to "-" input of the opamp, rather than having a direct wire, to add some gain if it is not loud enough.
isak
PostPosted: Thu Oct 20, 2016 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
hi LFLab, how are you?
thanks for replying.
i was asking about this cause when reading about the gyraf one you gave me it says it will not handle 600ohm headphones.
LFLab
PostPosted: Thu Oct 20, 2016 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, the main limitation are the rails, and so yes, there might be better amplifiers around. But it will probably work.
The headphone amp I did is aimed at very good quality audio (hence the use of a 15 euro potmeter Very Happy ), in low impedance transducers, and so there are amplifiers better suited to 600ohm cans.
Maybe try it first? It will not kill anything.
Curious to know what kind of headphones you'd like to use it with? Most recent headphones are 250ohms and less.
More info:
http://sound.whsites.net/project113.htm
(similar amp) either 120mW or 82mW into 600ohm, depending on sensitivity, it might be enough.
isak
PostPosted: Thu Oct 20, 2016 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
from 24ohm
https://www.amazon.com/Sony-MDR-V700DJ-Studio-Monitor-Headphones/dp/B00005QBU6/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1476974236&sr=1-1-catcorr&keywords=sony+mdr-v700
to 600ohm
https://www.amazon.com/Beyerdynamic-990-Premium-600-Headphones/dp/B0024NK34O
i want the amp to be versatile
if you have any ideas that would be great man.
LFLab
PostPosted: Thu Oct 20, 2016 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
No other ideas than "give it a try", I think it will be hard to find something that excels at all impedances.
But IF you want something that drives everything, I'd go for the Gyraf one, use an opamp which can handle higher rails (although those usually are specialty opamps not aimed at sound reproduction) and follower transistors which can do some serious pushing if needed (the BD139-BD140 pair).
There are still a couple of headphones I'd like to try, and Beyerdynamic (in my case DT770) is certainly one of them, I'd go for the 80 ohm version I think, one of the three impedances apparently sounds the most neutral, 80ohms IIRC.
isak
PostPosted: Thu Oct 20, 2016 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
LFLab wrote:
More info:
this is great, thanks Smile
BTW, do by any chance know the current draw of the gyraf HP amp for both rails?
LFLab
PostPosted: Fri Oct 21, 2016 1:05 am    Post subject: Reply with quote  Mark this post and the followings unread
No I don't, it'll depend on the bias of the follower transistors primarily.
In some builds it's a 1N4148, in some I used two Schottky's in series for more bias current, also built a few with LED's for a lot more bias current.
Measure voltage drop over R9 and R10 and do the math (ohms law) Very Happy
isak
PostPosted: Fri Oct 21, 2016 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Dont you mean R7 and R8 (47ohm)?
LFLab
PostPosted: Fri Oct 21, 2016 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, R9 and R10
isak
PostPosted: Fri Oct 21, 2016 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, but i cant find them in gyraf scheme Embarassed
LFLab
PostPosted: Fri Oct 21, 2016 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, sorry, I was talking about my own schematic:
In the power supply section, lower left.
isak
PostPosted: Fri Oct 21, 2016 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
You mean in your power supply?
LFLab
PostPosted: Fri Oct 21, 2016 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
isak
PostPosted: Fri Oct 21, 2016 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, ive missed that Smile
Do you think i can some how do the same with the MFOS wall wart power supply?
I just dont want to built a new one.
Thanks man, this is a great idea!
LFLab
PostPosted: Sat Oct 22, 2016 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure!
By the way, there is a potentially enthousiastic mistake in the schematic I posted, some of the electrolytics need to be reversed!
I'll correct the schematic to prevent someone from building it this exact way.
isak
PostPosted: Sat Oct 22, 2016 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW, in the MFOS wall wart power supply i have only 2 load resistors, this is where i need to check the V after connecting the HP amp?
LFLab
PostPosted: Sat Oct 22, 2016 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are they in series with the headphone amp, or from each rail to ground? In the first case "yes" else "no".
If they are in series, the current drawn by the load will cause a voltage drop over the resistor, which you can easily measure and calculate current with the value of the series resistor.
isak
PostPosted: Sat Oct 22, 2016 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
do you mean like Yusynth does to his modules, protection resistors from each power rail 10ohm value?
LFLab
PostPosted: Sat Oct 22, 2016 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, those are the ones!
isak
PostPosted: Sat Oct 22, 2016 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool thanks a lot Smile
i will try to build the ESP one.
i just read about it here:
http://www.diyaudio.com/forums/headphone-systems/236762-rod-elliot-113-headphone-amp-too-much-gain.html
if its truly to much gain i think i just replace the BD139/BD140 to BD135/BD136
