pcb board gif for wp20
Page 1 of 1 [12 Posts]
PostPosted: Thu May 26, 2005 11:35 am    Post subject: pcb board gif for wp20 Reply with quote  Mark this post and the followings unread
Hello everyone
I made a decent copy of the wp20 circuit board and sent it to Ray who's very kindly put it up for grabs on his site. Please feel free to go and use this image to make up your own wp20.
http://www.musicfromouterspace.com/analogsynth/WP20/wp20pcbbig.gif
of course Ray isn't supporting this unit any more- but at least this gif of the board will help make this classic circuit go a bit longer.
The logo has changed slightly (on the board) because I didn't have the original font on my Mac- but perhaps this is good because all those who have already built this little box of fun- well your pcb has now catapulted itself into 'classic status'- cool!
Tom
Wild Zebra
PostPosted: Thu May 26, 2005 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great! thanks.
Have to make one of those after the mini-synth, although
should have done WP-20 first. The sound lab is just laid out so nice though.
no pressure how bout an updated panel wiring layout Wink
"your stripes are killer bro"
PostPosted: Thu May 26, 2005 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
cripes what did your last slave die from?! Wink
I'll see what I can sort out Smile
ACHTUNG!
PostPosted: Fri May 27, 2005 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Good morning Zebra.
I had a look at the panel wiring last night- I don't see why you have a problem with it? It looks perfectly adequate to me.
What is it you don't understand?
best
Tom
ACHTUNG!
Wild Zebra
PostPosted: Fri May 27, 2005 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, its not that bad. I understand everthing on it. Its just a little hard to see some of the letter connections. I haven't even rotated it of zoomed in a little because I haven't gotten close to making it. I just
thought maybe a little more updated layout would get more people
interested in this cool little synth. Some people may be reserved about trying it, even though its seeems more simple than the sounlab. The sound lab page is just laid out so much nicer.
thanks
ladislaobiro
PostPosted: Wed Jun 08, 2005 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
this is my little contribution to the good old WP-20...
Into the compressed folder you will find these three GIF files:
1- the PCB (component side view)
2- the Panel Wiring Diagram
3- the Additional Parts Layout
1- PCB:
this PCB is almost the same presented on Ray's pages... I only added a On/Off status LED, with related resistor, and the mods for CV input and GATE input with related components. The diagram is bigger than actual dimensions so you have to reduce the scale to proper dimensions in order to use it.
2- Panel Wiring Diagram:
the original project uses slide switches, but since toggle switches are easier to mount, I had to make a brand new wiring diagram because toggle switches work in the opposite way compared to the slide switches.
THIS PANEL WIRING DIAGRAM WORKS WITH TOGGLE SWITCHES ONLY!!! DO NOT USE IT WITH SLIDE SWITCHES!!!
3- Additional Parts Layout:
this file shows the components and the inputs related to the mods I've done on the original PCB... take note of the following list:
Rl = this resistor gives a proper supply to the LED. Choose the value you prefer.
Rc = 100K
Rg = 10K
Qg = transistor 2N3904
Hey Wild Zebra, I hope this helps Wink
ladislao
wp20.zip
 Filename:  wp20.zip
 Filesize:  126.07 KB
 Downloaded:  606 Time(s)
Wild Zebra
PostPosted: Wed Jun 08, 2005 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks alot. Can't wait to get done the sound lab so I can start
these other great projects.
thanks for your efforts
PostPosted: Thu Jun 09, 2005 3:39 am    Post subject: Philosophy for this morning! Reply with quote  Mark this post and the followings unread
Hooray! There's no stopping you now! :)
It's great when someone on the other side of the world, who you respect for what they do, endorses your efforts- its a nice feeling. I just wish more people trusted others- perhaps then we would live in a slightly less fucked-up world that we do today :)
ACHTUNG!
ladislaobiro
PostPosted: Thu Jun 09, 2005 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
you are welcome Wild Zebra... have fun!!! Wink
v-un-v wrote:
Hooray! There's no stopping you now! Smile
v-un-v wrote:
It's great when someone on the other side of the world, who you respect for what they do, endorses your efforts- its a nice feeling. I just wish more people trusted others- perhaps then we would live in a slightly less fucked-up world that we do today Smile
I totally agree... you are perfectly right...
ladislao
ladislaobiro
PostPosted: Fri Jul 01, 2005 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
for those who might be interested in this project:
I'm digging the opportunity to connect to the WP-20 the simple S&H circuit presented on Ray's pages, in order to widen the palette of sounds we can get out of this good synth... will keep you updated.
ladislao
MickMad
PostPosted: Fri Sep 01, 2006 7:02 am    Post subject: helpppppppppp Reply with quote  Mark this post and the followings unread
Ok, quindi hai fatto la pcb con gate e cv in...perfetto!
comunque non capisco una cosa...sulla tua pcb dice B C ed E vicino al transistor 2n3904 ...vuol dire che sono i pin del transistor (quindi C sta per Collettore) o vuol dire che devo attaccarmi ai punti B C ed E nel pannello?
ps: se non voglio il led di stato, basta che elimino la parte che prosegue dal punto E vicino al transistor Qg ? poi,le saldature di tutti i componenti le faccio sulla parte dei collegamenti???
anvasp2000
PostPosted: Thu Mar 08, 2007 5:02 pm    Post subject: ¿¿PCB size??
Subject description: ¿¿PCB size??
HELLO EVERYBODY
I have a small question??
What size should the pcb board diagram be when i print it??
thanks
