Clock signals through a Transistor
Page 1 of 1 [21 Posts]
cerkit
PostPosted: Sat Dec 10, 2016 10:04 am    Post subject: Clock signals through a Transistor
Subject description: Is this possible?
Consider a scenario:
* Microcontroller (Raspberry Pi in this case)
* Oscillator output (in this case it's just a simple 40106 single oscillator)
* Transistor
* Trigger signal (from GPIO pins of Raspberry Pi)
I'd like to be able to send the signal of the oscillator through the transistor so it can be triggered by the microcontroller.
Is this possible or do I need to look at it differently?
Will this have an impact on the oscillator (something tells me the transistor will alter the signal in some way).
If not a transistor, what's the best way to gate the output of an oscillator?
Should I use the transistor between the "loop" resistor on the oscillator and the output pin?
Maybe between the capacitor to ground and the "input" pin of the oscillator?
Thanks in advance for any insight.
PostPosted: Sat Dec 10, 2016 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
yes a transistor can work, downside is that the output wil be floating when turned off so you might need an extra pulldown resistor. Better would
be to use an AND gate since you are using digital signals, or probably even better: make the oscillator using a schmitt trigger NAND gate (CD4093).
You can find an example of those here
wackelpeter
Audio files: 10
PostPosted: Sat Dec 10, 2016 12:16 pm    Post subject: Re: Clock signals through a Transistor
Maybe i'm wrong but i think a CD4016 or Cd4066 would do the trick to swithc the output on/off via other logic levels.
PostPosted: Sat Dec 10, 2016 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
a switch like a 4016 or 4066 would work, but since the output of the
oscillator is a digital signal an AND gate would be more suitable.
wackelpeter
Audio files: 10
PostPosted: Sat Dec 10, 2016 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
well that's true, since you have a defined logical level, high or low at the output, when you want to use the oscillator for further logic implementations...
guess with a switch you had to pull down it's output when you want it to use the same way, as otherwise it wouldn't be a defined logical level.
cerkit
PostPosted: Sun Dec 11, 2016 10:10 pm    Post subject: Thanks for the answers
Subject description: I was able to get it working
Thanks for the assistance. I just happened to have a 4093 on hand, so I hooked it up based on your suggestion.
However, I'm still using the 40106 as the oscillator and the 4093 as a simple gate.
Could you take a look at my blog post on the subject and let me know if my description of how/why this works is correct? I may have some of the details wrong in my description, especially as it deals with the output of the gate (I'm still a little unclear of what I'm getting as an output from the gate as I haven't bought a meter, yet). I'm connecting the output pin of the gate to a PNP transistor that controls a +3v source to an LED.
Would a -5v output form the NAND gate trigger the transistor? I guess in this case, evidence points to a yes if what I understand about the relationship between my 40106, the diode, the 4093, and the transistor is correct.
Thanks again for all of your help.
2016-12-11 16_58_10-GatedOscillatorSchematicWithPinHighIndicatorLEDNoGrid.png
This is the schematic that I created to describe the circuit that I put together based on using a 40106 and a Raspberry Pi to trigger a 4093 NAND gate to flash an LED.
 Filesize:  41.4 KB
 Viewed:  438 Time(s)
PostPosted: Mon Dec 12, 2016 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
You could also use one of the gates of the 4093 to make an oscillator while controlling the oscillator with the second input.
PostPosted: Mon Dec 12, 2016 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
yep, that's what I meant when I mentioned "make the oscillator using a schmitt trigger NAND gate (CD4093)"
as for the GatedOscillatorSchematicWithPinHighIndicatorLEDNoGrid I'd use an AND gate for that function, but I guess a NAND will work if
you invert the output. You don't need the diode on the input (pin2) of the NAND gate and if you do you should add a pullup resistor to +5V.
I am not sure if Q2 will be happy with 5V on the Base and 3.3V on the Emitter and I would also put a resistor (10K or so) in series with the
Base. If you do want to use a NAND gate instead of an AND gate you could use another one as an inverter instead of the transistor but that
also depends a bit on what you want to drive with it. You could drive the LED straight from that gate's output if you increase the resistor
value a bit and if you really need 3.3V to drive something else you could just add a voltage divider to the output.
Audio files: 297
PostPosted: Mon Dec 12, 2016 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Q1 needs a base resistor too - both Q1 and Q2 will blow up when their base goes to ground. Oh, CMOS driven, Q2 will survive and so will the CMOS port, but it's really a short circuit (in both cases).
The GPIO of the Raspi he's using has a logic voltage of 3.3 volts.
PostPosted: Mon Dec 12, 2016 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Checked the blog and the only thing that doesn't seem to be correct is "(with a negative 5v - a behavior of the NAND gate)"
The output will be either high (Vcc) or low (0V/GND) it will not be negative. (at least not on a single supply) Although you could
regard GND as the negative rail but it is not -5V.
cerkit
PostPosted: Mon Dec 12, 2016 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I was unsure how the NAND gate worked with my 5v supply.
cerkit
PostPosted: Mon Dec 12, 2016 8:50 am    Post subject: 5v for entire circuit? Reply with quote  Mark this post and the followings unread
Based on the feedback I'm getting, I think it might make sense just to drive the whole circuit on 5v, including Q1 and Q2. However, with P1Pin07 of the Pi being 3. 3v, how will this affect the 4093 considering pin 2 will be 5v?
Where would the resistors go on Q1 and Q2? Also, if I switch Q1 to a 5v supply, what's the best way to protect P1Pin07 from the 5v?
Thanks for all of the help, this has been very fun.
PostPosted: Mon Dec 12, 2016 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
As you can see in this drawing the logic high for a cmos powered at 5 volt is 3.5 volts, and that is to high for your raspi gpo signals.
So the circuit will not work. (Well, not reliable anyway)
Audio files: 297
PostPosted: Tue Dec 13, 2016 5:22 pm    Post subject: Re: 5v for entire circuit? Reply with quote  Mark this post and the followings unread
cerkit wrote:
Where would the resistors go on Q1 and Q2? Also, if I switch Q1 to a 5v supply, what's the best way to protect P1Pin07 from the 5v?.
The transistors have a fixed voltage drop from base to emitter, it depends on the base emitter current, from zero to about 0.7 Volt. So when the emitter is at a fixed voltage and the base is at a fixed voltage and the difference is over that 0.7 V an unlimited amount of current could flow (which will not happen as there are other physical constraints, like limited supply current to be available or components to go up in smoke).
In the schematic above, for example, for Q2 the emitter is fixed to 3v3, and the base can be switched from 5V to 0V. The 5V situation would reverse bias Q2, but only by 5 - 3.3 = 1v7, and it can handle that. The 0 V situation would cause a drop of 3v3, which is over the 0v7 limit, that is a nono as it would cause unlimited current to flow (which in this case will not happen as U2A can only sink a limited amount of current - hence nothing will actually blow, but it is bad design).
You can fix this by adding a resistor, either in the emitter or in the base connection. Effectively this will change the mode from voltage driven to current driven, and that is what a transistor was designed for.
In this particular case putting a resistor in the emitter connection would be troublesome, as it would affect the LED (D2), but a base resistor would solve the problem by limiting the amount of current that could flow. The base resistor would be connected from the base of Q2 to pin 3 of U2A, replacing the direct link that is there now.
For Q1 the situation is basically the same. When P1pin07 is high (and I assume that to be 3v3) all is ok, as there is no BE voltage over Q1. However when P1pin07 goes low (oV) it will try to put a voltage over 0v7 over Q1, resulting in potentially unlimited current again. Again an emitter resistor would affect the LED, but a base resistor (replacing the link from Q1's base to P1pin07) would limit the current.
In both cases a resistor of say 1 .. 10K would do it, its not very critical, there must be something though.
cerkit
PostPosted: Wed Dec 14, 2016 8:12 am    Post subject: Re: 5v for entire circuit? Reply with quote  Mark this post and the followings unread
Wow, thanks for the explanation. I really appreciate your patience and time writing it out. I have been doing research on the web to learn this, but sometimes it's good to get pointed in the right direction. I was also looking at the logic level convertors at Adafruit. I put the transistors in as a learning exercise for me. The key statement that really helped was that they are "current driven" and not "voltage driven". I need to learn more about the theory behind transistors. Basically, I just hacked this until it (perceptibly) "worked" (as you can tell by all of the mistakes).
Thanks again for your help.
cerkit
PostPosted: Wed Dec 14, 2016 3:59 pm    Post subject: Re: 5v for entire circuit? Reply with quote  Mark this post and the followings unread
OK, I made the modifications as you suggested and it seems to be working.
I took out the addditional LED (Q1 onj the original schematic) as it was causing unnecessary confusion.
This circuit seems to be working properly, but I'm not sure if I have everything in the proper place.
Even though the output voltage of Pin 7 is 3.3v, it seems to be triggering the NAND gate effectively (I checked the data sheet and the lowest voltage is right below 3.3v, but it states that it requires a 5v trigger). I don't have any AND gate IC's yet, so I need to wait until I get one.
Do you see any short circuits or design flaws with this particular schematic?
This is a revision of the original schematic (that contained short circuits and errors). This schematic removed the flag indicator LED to make it simpler.
 Filesize:  37.15 KB
 Viewed:  324 Time(s)
gdavis
PostPosted: Wed Dec 14, 2016 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm a little late to the party so I haven't read the whole thread in detail, sorry if I missed something, but in your latest schematic, why the 5V instead of just putting everything on 3.3V?
Why is R2 there?
cerkit
PostPosted: Wed Dec 14, 2016 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why is R2 there?
The CMOS chips I'm using have trigger voltages of 5v and I'm driving all of my Lunetta CMOS chips at 5v.
R2 was recommended when I had a transistor on that Pinout frOm the Raspbery Pi, it may not be necessary any longer. However, when I'ts not there, pin 1 of the 4093 doe not ever go to 0v since there seems to be some signal coming through the Pin7 of the Pi when my program exits. Maybe it's floating at some unknown value.
gdavis
PostPosted: Wed Dec 14, 2016 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
cerkit wrote:
Why is R2 there?
The trigger level should be relative to VDD, the 4093 data sheet I looked at states a minimum VDD of 3V. If you're feeding it 3.3V, you really should supply it 3.3V.
if you want to drive 5V out then the transistor should be on 5V, not 3.3V.
You need to decide where you want to shift your level from 3.3V to 5V. If you want to keep consistent and run all your CMOS logic at 5V (which I think is a good idea), you should level shift the output from the PI. It may seem to work now, but as you noted from the data sheet, you're right at the limit which could make it unreliable.
R2 was recommended when I had a transistor on that Pinout form the Raspbery Pi, it may not be necessary any longer. However, when I'ts not there, pin 1 of the 4093 doe not ever go to 0v since there seems to be some signal coming through the Pin7 of the Pi, even when set to low.
Hmm, if the output is actively driving high and low the resistor shouldn't be necessary for the current circuit. I suspect the output might not be configured correctly, you may want to look into that.
cerkit
PostPosted: Wed Dec 14, 2016 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
gdavis wrote:
cerkit wrote:
Why is R2 there?
Thanks, that's basically the same conclusion I came to.
From an earlier post (I know this thread is a bit long):
I'm just going to wait until I get the logic level converters and do it the correct way. My "experiments" with transistors simply taught me that I have a lot to learn about theory. I'm trying to balance my time between "hacking" and learning theory. I know there's a basic level that I need to get to so I have enough working knowledge that I don't zap all of my components or kill myself with hooking things up wrong. Shocked
Ultimately, I do plan to graduate beyond blinky lights and actually come up with experimental applications combining CMOS Oscillators, counters, dividers, and the Raspberry Pi (plus my favorite programming language) to do interesting things with code and hardware.
