Drum sequencing
Page 2 of 2 [31 Posts]
Goto page: Previous 1, 2
Wobble
PostPosted: Sun Mar 12, 2017 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I can do a video tutorial when its done. Smile
Audio files: 268
PostPosted: Mon Mar 13, 2017 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
A little more progress, still not 100% but getting there.
Skips and resets still not good enough - I may want to change the implementation that I now have. Outputs do what they should do now. Also added added a reset button and a done output.
The problem with skips and resets is that it is not quite clear to me how they should behave .. well .. when there is a skip on a part it should skip that entire part IMO and that is what I have now .. but it is implemented by setting the skip on all sections for the part and on all elements for those sections .. which saves a couple of administration bytes ... but it behaves a bit odd all it seems. So will probably add the saved bytes anyway.
For resets it does not matter much BTW how its implemented - just the first encounter will do the reset.
My thought was that it makes sense only to have skips and resets on elements .. so I have also considered removing the red and blue colors and make two extra buttons near the bit buttons instead.
ideas?
Audio files: 268
PostPosted: Mon Mar 13, 2017 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems to be working ok all .. except that I'm not sure still how I want the skips and resets to work ... but its workable as is .. just looks a bit odd in the display now and then .. not wrong .. but odd .. just a bit :-)
2017-03-13--Blue Hell--Silly Sequence.mp3
Blue Hell - Silly Sequence
 Filename:  2017-03-13--Blue Hell--Silly Sequence.mp3
 Filesize:  1.26 MB
 Downloaded:  1031 Time(s)
Wobble
PostPosted: Mon Mar 13, 2017 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice Smile
Audio files: 268
PostPosted: Tue Mar 14, 2017 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Made a release with it : http://bluehell.electro-music.com/modules/forums.html - things can still be changed of course.
Wobble
PostPosted: Tue Mar 14, 2017 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool! Gonna try it out soon.
