Understanding the WSG schematic
Page 1 of 1 [11 Posts]
t1d
PostPosted: Mon Apr 10, 2017 9:22 pm    Post subject: Understanding the WSG schematic Reply with quote  Mark this post and the followings unread
I am not accustomed to seeing a particular type of notation that Mr. Wilson used on his schematic. They appear to be nets/traces that do not terminate to a component, or a pad. Are they simply names for the nets?
A sample has been highlighted with red circles. Please tell me what is going on. Thank you.
 Filesize:  149.29 KB
 Viewed:  455 Time(s)
gdavis
PostPosted: Mon Apr 10, 2017 9:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you look at the pictures of the boards on the MFOS site it looks like those labels correspond to pads on the board for connecting the pots and switches. The pads have the same labels silk screened by them.
So, for example:
R1 pin 3 would connect to the pad WK1A
R1 pins 1 and 2, S1 pin 1 and S2 pin 1 connect to pad WK2A
S1 pin 2 connects to DPSA
S2 pin 2 connects to WSWA
and so on.
It's a little confusing but I think it minimizes the amount of wiring between the board and panel.
t1d
PostPosted: Mon Apr 10, 2017 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, gdavis, for your reply. That was my conclusion, as well. However, I find things that make me continue to question the idea... Mainly that there would be various pads missing, for the off-board wiring.
For example, the Wacky Frequency pot and the Wacky Too switch are wired off-board and return to the board at pin #1 of the Wackiness switch. There is not a pin labeled for this return, if this is the correct interpretation of the labeling convention.
t1d
PostPosted: Mon Apr 10, 2017 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm... Maybe I see it better, now... WK1A serves all three, the pot and the two switches...
t1d
PostPosted: Tue Apr 11, 2017 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
What about the circle with "ODD" inside? Might that be a network flag?
gdavis
PostPosted: Tue Apr 11, 2017 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, it's WK2A, but yes, that's the idea. The three pins of the pot and two switches are all connected together on at the panel, then you just need one wire from the panel to the board. There's no need to connect each of the pins to the board individually so they all share one connection to the board to reduce wiring between the board and panel.
I believe that's just an off page label to indicate that the net on page 1 should be connected to the corresponding net on page 2.
PostPosted: Tue Apr 11, 2017 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
My guess is that it's an input for a second unit.
There is another thread on this forum about this module: http://electro-music.com/forum/topic-42077.html
and/or read: http://musicfromouterspace.com/analogsynth_new/WSG2010/wsg_page2.html
gdavis
PostPosted: Tue Apr 11, 2017 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
After getting a better look on a bigger screen, what I stated above is exactly what it is. That net is the summing node for all the oscillators into the filter. Page 1 contains the oscillators for "voice 1" and the filter, page 2 contains the oscillators for "voice 2". The nets labeled "ODD" on both pages should be connected together in the actual circuit.
Since it's a summing node, you could in theory treat it like an input and connect other sources to it (you'd need another resistor for each input).
t1d
PostPosted: Tue Apr 11, 2017 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, to all. Very good information...
I am wittlin' down the schematic. The off-board components will only be annotated. The reason to need to do the thinning is that I am working in KiCad... And, KiCad makes associations between what is in the schematic and what is on the board. So, if it's not going to be on the board, it does not need to be an ("active") item on the schematic.
If someone would help me proof my work, I would be willing to post the KiCad schematic, on this forum, for others to use. It would save them a world of work. I am close to having it completed. I can provided it as a pdf, so having KiCad would not be necessary. Any takers?
My brother and I are retired and have taken up electronics to keep our brains sharp. We built a Reflow Oven and I will be doing this project with SMD components. Kewl!, as the cool kids say...
PostPosted: Wed Apr 12, 2017 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ray had no objections to people making their own PCBs in whatever fashion, stripboard, CAD, etc, but I do believe he drew the line at public posting of CAD that could just be shipped off to a fab to do mass PCB runs. Not that such is your intent, I think you're clear about that, but if you post the CAD publicly, someone who is less scrupulous may well take advantage of that.
Synthcube arrived at an arrangement with Ray's estate to keep his PCBs in print, so if someone wants an off-the-shelf PCB they ought to be able to go there to purchase one, and part of that money goes back to Ray's family. He has them in stock right now for $15:
http://synthcube.com/cart/music-from-outer-space/noise-boxes/mfos-weird-sound-generator
And for a little more you can get a panel to go with it.
I don't want to discourage you from working with KiCad on this, that sounds like a great project in several dimensions. But I would suggest it would be better not to post the CAD files.
PostPosted: Wed Apr 12, 2017 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
OH, and if you're doing it SMD, small format, you might talk to Synthcube to see if he wants to pay you for the layout Very Happy I think there are people who would be quite interested in a Euro-compatible WSG for example (though you might want to incorporate some of the CV-able mods that are mentioned on Ray's website for that to be really compelling).
