zloth
Joined: Nov 18, 2016 Posts: 12 Location: Augsburg, Bayern
Posted: Mon Apr 17, 2017 11:04 am Post subject:
CV for vactrol rhythmic patterns? |
Sure everyone is fed up with novices asking about this, but should I use an r/2r ladder before the LED or would a simple set of resistors in series work?
Thanks |
JovianPyx
Audio files: 224
Posted: Mon Apr 17, 2017 3:18 pm Post subject:
Re: CV for vactrol rhythmic patterns? |
| zloth wrote: | Hi,
Thanks |
We love novice people here at E-M.
Perhaps I don't understand the question - usually a DAC (such as an R/2R ladder) is used with a microprocessor to create an analog voltage from digital data. Not sure how this relates to a LED. If you just want to safely turn on / off an LED, all you need is a properly sized current limiting resistor (just one).
Since there's no schematic to look at, I can't tell what "the LED" is for... _________________ FPGA, dsPIC and Fatman Synth Stuff
zloth
Posted: Tue Apr 18, 2017 12:00 am Post subject:
Thank you for your reply
Perhaps if I explain as best I can:
As I understand it, a vactrol is basically an enclosure containing an LED & an LDR, the brightness of the LED controls the LDR which can be used in place of a potentiometer.
I want to be able to vary the brightness of LED in a rhythmic way to control pitch, filter cut off, anything that could be done with a pot. Basically a simple type of CV-driven sequencer.
I have used an r/2r with various timing sources (4093 LFOs, 4060 ripple counter, shift register) for creating a CV to control the pitch of a 4046, and assumed it could be used similarly to vary the brightness of the LED inside a vactrol.
On the dlbelectronics Lunetta page there is a schematic for a WSG filter modified "I got rid of the coarse and fine pots for cutoff and instead added 2 CV inputs via Vactrols for controlling cutoff with other modules... I used some hand made vactrols, 4N25 opto-couplers as well as a couple VTL5C3's. It would be a good idea to add a pot as an adjustable voltage divider before going to the Vactrol's LED. This way you would have more control over the level of CV getting to the LED." This got me thinking (never a good thing) that a CV from a DAC could be used, but wanted to ask more experienced Lunettists before investing in anything.
Hope that clarifies my situation at least a little
Posted: Tue Apr 18, 2017 2:37 am Post subject:
hmm, never thought about using an R2R to control a vactrol, could be interesting. It might work if you choose the
resisors small enough, but don't make them too small or it will draw too much current from whatever you want to
drive it with. There is a better method though which is using an opamp as a current source. There are several ways
of doing it, with or without extra transistors, but you can easily connect an R2R to the input of it. If you search for
"opamp current source" you should be able to find something useful. _________________ "My perf, it's full of holes!"
zloth
Posted: Tue Apr 18, 2017 5:14 am Post subject:
Thanks
I normally use a 3 or 4 bit DAC (50k/100k) with a pot between that and the 4046 to control amplitude and therefore tonal range, so I thought that might work. To be honest, it was the only way I could think of doing it with my limited knowledge/experience.
Whilst on the subject of DACs, has anyone tried using outputs from a 4026/4033/40110 with other clocks into a DAC to create unusual "polyrhythms" or would that not work from a technical point of view? |
gasboss775
gasboss775
Posted: Tue Apr 18, 2017 7:59 am Post subject:
| zloth wrote: |
I've been meaning to try this idea out, can't see any reason why it wouldn't work in practice.
I love the sort of creative thinking that goes on amongst musical electronics enthusiasts, that's something you can't learn from a book. |
zloth
Posted: Tue Apr 18, 2017 11:41 am Post subject:
Another possibility is using a weighted resistor network. The idea is the most significant bit goes through the lowest value resistor, which we shall call R, then the next less significant bit goes to a resistor of 2R, then 4R, 8R, etc and theses are summed together usually at a virtual earth point of an opamp based inverting amplifier.
Funnily enough I'd seen about those only a couple of days ago but couldn't remember the technical name.
I tried this passive version on my Everycircuit simulator app & it appeared to work quite well, the switches represent the logic inputs ( I made them 0 & 12 Volts as that's what I usually use with CMOS circuits ) the 12 volt source and 47K resistor on the right provide a bias to overcome the forward voltage of the LED.
I use a 9v clip or 5v from the Arduino.
You would probably need to experiment with the values of the resistors to suite your specific vactrol as there is quite a large difference between different parts, same goes if you brew your own.
40K can be made with an 18K & a 22K in series, 80K can be made from 33K & 47K in series.
How about this for a 3-Bit solution? Resistor network, star connection, 8 pin 7 resistor (R + 2R + 4R), 4 different values @ 0.09€ each, going into the 4 different sections of an LM324 (0.24€). Last edited by zloth on Tue Apr 18, 2017 11:54 am; edited 1 time in total |
zloth
Posted: Tue Apr 18, 2017 11:50 am Post subject:
| gasboss775 wrote: |
We're like the MacGyver of musicians  |
zloth
Posted: Tue Apr 18, 2017 12:11 pm Post subject:
| zloth wrote: |
How about this for a 3-Bit solution? Resistor network, star connection, 8 pin 7 resistor (R + 2R + 4R), 4 different values @ 0.09€ each, going into the 4 different sections of an LM324 (0.24€). |
Looking at the diagram I think I got it wrong so networks won't work. Luckily I recently got given a bunch of 10k and 25k trimpots which I hadn't decided what to do with. |
gasboss775
Posted: Tue Apr 18, 2017 2:31 pm Post subject:
| zloth wrote: | | zloth wrote: |
What you want is one of the DIL resistor arrays with 8 independent resistors in the one package, however the expense probably isn't justified in this application. |
gasboss775
Posted: Tue Apr 18, 2017 2:37 pm Post subject:
This is just to show you what I'm talking about:
8 ISOLATED RESISTORS
As I said a bit pricey. |
Posted: Tue Apr 18, 2017 3:04 pm Post subject:
| zloth wrote: | | Whilst on the subject of DACs, has anyone tried using outputs from a 4026/4033/40110 with other clocks into a DAC to create unusual "polyrhythms" or would that not work from a technical point of view? |
Never used any of those chips to control one directly but it might actually be nice to make a simple module using one
similar to a binary and digital counter/divider. If you hardwire it it will always be the same sequence which probably isn't
too interesting but combined with some other things it is useful. I do usually connect all kinds of different digital signals
to an R2R to create interesting patterns so it should work fine.
note: I did use a 7 Segment decoder chip years ago for my Cosmic Space Beeper. _________________ "My perf, it's full of holes!"
Posted: Tue Apr 18, 2017 11:46 pm Post subject:
Maybe a little over the top, but why use a DAC and a Vectrol in a Lunetta, when with the same efforts one could use a Digital Controlled Potentiometer.
I mean you have a processor (Arduino?) to control the R2R-DAC...
The advantage of using a DCP compared to a Vactrol is that they are VERY linear, may have different impedances (1k, 10k, 50k, 100k), different steps (32 - 1024), there are type to be used with a single supply (like 5 volt) or dual supply (up to 33 volt span)
A drawback might be that the footprint is usually SMD...
In my modular I use on one module four 256 step digital potmeters, two for creating some kind of VCA, one for a triggered S/H and one for supplying a triggered random voltage.
There are a numerous types to choose from:
http://www.analog.com/en/products/digital-to-analog-converters/digital-potentiometers.html
http://ww1.microchip.com/downloads/en/DeviceDoc/22017c.pdf |
zloth
Posted: Wed Apr 19, 2017 12:50 am Post subject:
| gasboss775 wrote: | This is just to show you what I'm talking about:
"Order in multiples of 25" No chance Apart from the LM324 I think I can work with what I have, but thanks for the info. Last edited by zloth on Wed Apr 19, 2017 12:56 am; edited 1 time in total |
zloth
Posted: Wed Apr 19, 2017 12:55 am Post subject:
| PHOBoS wrote: | | zloth wrote: | | Whilst on the subject of DACs, has anyone tried using outputs from a 4026/4033/40110 with other clocks into a DAC to create unusual "polyrhythms" or would that not work from a technical point of view? |
note: I did use a 7 Segment decoder chip years ago for my Cosmic Space Beeper. |
No hardwiring. Ever. Breadboard only. For the same reason I would never use superglue with LEGO: those pieces, and all their potential, are locked away, effectively lost forever  |
zloth
Posted: Wed Apr 19, 2017 1:47 am Post subject:
| Grumble wrote: | Maybe a little over the top, but why use a DAC and a Vectrol in a Lunetta, when with the same efforts one could use a Digital Controlled Potentiometer.
Thanks, to be honest I don't use the arduino for anything else than a USB power supply. I bought a cheap clone from China out of curiosity & because it came with some genuinely useful stuff - breadboard, jumper leads, momentary switches, selection of resistors etc. Got bored and frustrated with the coding side very quickly. |
gasboss775
Posted: Wed Apr 19, 2017 3:19 am Post subject:
| I've never been very interested in the programming side of my electronics hobby. I do like experimenting with digital hardware though. Occasionally there are situations where it would be a lot more convenient to just program a microcontroller. One day I'll give it a try. |
gasboss775
Posted: Wed Apr 19, 2017 3:23 am Post subject:
| zloth wrote: | | gasboss775 wrote: | This is just to show you what I'm talking about:
"Order in multiples of 25" No chance Apart from the LM324 I think I can work with what I have, but thanks for the info. |
You're welcome
It would be a lot cheaper just to use 1% MF resistors, although in this sort of application you could probably get away with just using 5% CF resistors. |
Posted: Wed Apr 19, 2017 4:47 am Post subject:
| gasboss775 wrote: | | Occasionally there are situations where it would be a lot more convenient to just program a microcontroller. |
Occasionally? Don't get me started  |
zloth
Posted: Wed Apr 19, 2017 5:05 am Post subject:
I could do anything I can with a Lunetta on SynthEdit in a fraction of the time with far less difficullty, but sometimes that isn't the point, just like I could order a takeaway curry but also I enjoy growing my own beans, potatoes and veg and making one from scratch  |
gasboss775
Posted: Wed Apr 19, 2017 6:04 am Post subject:
| Grumble wrote: | | gasboss775 wrote: | | Occasionally there are situations where it would be a lot more convenient to just program a microcontroller. |
If programming ( or coding as the youngsters say ) was easy or interesting to me I'm sure I would choose that path more readily. As it is I get a real joy from experimenting on breadboards, its so easy to put something together and change it whilst you listen to the outcome. Surely with microcontrollers such easy manipulation would be challenging, given that the code would need to be redownloaded every time you make a change. |
Posted: Wed Apr 19, 2017 6:08 am Post subject:
Joy! Thats what diy is all about!  |
Joined: Jan 15, 2011 Posts: 430 Location: Montreal, Canada
Posted: Wed Apr 19, 2017 2:27 pm Post subject:
| Grumble wrote: | ... one could use a Digital Controlled Potentiometer.
Could you tell us exactly which one you are using for these applications?
I looked briefly at DCP's a while ago, but my understanding is that they use serial interfaces like I2C, SPI, up/down, etc. So one cannot just supply a few bits and get a resistance corresponding to the binary value.
Thanks.
.:James:. |
Posted: Wed Apr 19, 2017 9:01 pm Post subject:
I use an Arduino using SPI to control the position of the runner of the DCP.
If you are interested I could write a piece about this module.
(remember: my module is almost 5 volt only!) |
