elkayem
Joined: Jul 04, 2017 Posts: 33 Location: Santa Clara, CA
Posted: Fri Dec 29, 2017 9:40 am Post subject:
DIY Multichannel MIDI to CV converter, new design |
Hi All,
I had recently solicited and received great advice on the design of a MIDI to CV converter. The final result was a single-channel converter using a 5-pin DIN MIDI input, built directly into my synthesizer.
After building it, I realized I wanted MORE! My synthesizer has 3 VCOs after all, and wouldn't it be nice if I could drive all three independently with a sequencer app on my iPad. I finally put together what I wanted, and just uploaded the design (including a nifty 3D printed case) at:
https://github.com/elkayem/usbMIDI2CV_MC
I thought I would share the design here in case anyone else was looking for a good winter project. I'll also entertain code feature requests. This design features an OLED user interface for configuration settings, so it is quite flexible. A few more features:
- Three channel Note CV output (88 keys, 1V/octave, MIDI channels 1-3) using a 12-bit DAC
- Configurable note priority for each channel (Highest Note, Lowest Note, or Last Note Priority)
- 5V Gate/Trigger outputs, where each channel can be independently configured to either output a gate (output high for entire length of time that note is on) or trigger (20 msec pulse each time a new note is initiated)
- Velocity CV output (0 to 4V) for each channel
- Pitch Bend CV output (0.5 +/- 0.5V), which can be configured for channel 1, 2, or 3
- Control Change CV output (0 to 4V), which can be configured for channel 1, 2, or 3
- OLED user interface, used for setting parameters and saving to EEPROM
Anyway, here are a few photos. Enjoy!
Joined: Nov 23, 2015 Posts: 1311 Location: Netherlands
Posted: Sat Dec 30, 2017 5:13 am Post subject:
Nice built!  _________________ my synth |
elkayem
Posted: Sun Dec 31, 2017 4:09 pm Post subject:
Grumble wrote: | Nice built!  |
Thanks Grumble!! |
Sheer Kahn
Joined: May 07, 2007 Posts: 12 Location: Bottom Left, UK
Posted: Wed Feb 28, 2018 11:31 am Post subject:
Thanks man, I'm still using the first model. Looking forward to building this one, you saved me even more work. Much appreciated!
If you are taking requests for modifications/additions then I vote for more CC outs . the more the merrier as far as I am concerned. Really handy if you are sequencing your synth from a DAW.
I probably won't build it for a while, got a big project on, but I will try to incorporate it. Again, big thanks for sharing your work! |
elkayem
Posted: Thu Mar 01, 2018 9:24 am Post subject:
Sheer Kahn wrote: | Thanks man, I'm still using the first model. Looking forward to building this one, you saved me even more work. Much appreciated! |
Thanks Sheer Kahn! Good tip on the extra CCs. It is useful to know how people use these out in the field. I don't anticipate doing a redesign anytime soon, but the pitch bend (if you aren't using it) could easily be modified to another CC out with a simple code change. I have extra bare PCBs if you ever do wind up building one. The PCB manufacturers like you to buy in bulk. Good thing they're cheap! |
