Modal Electronics CRAFTsynth + Axoloti Core
diffrentstrolks
PostPosted: Wed Mar 21, 2018 9:23 pm    Post subject:  Modal Electronics CRAFTsynth + Axoloti Core Reply with quote  Mark this post and the followings unread
Anyone here have both of these items? Are the working nicely together?
I'm wanting to use the Axoloti as a USB host so that I can (a) play the CRAFTsynth with a MIDI (5 pin) controller, and (b) not be hooked up to a computer or phone.
For some reason the Axoloti is not recognizing the CRAFTsynth as being USB class compliant even though the manual says it is. When I plug it into the Axoloti, the console output simply says "USB Device Attached," as if it were a USB storage device (ex. thumb drive) or something.
If you happen to have both of these things, would you mind hooking them up and letting me know if you have the same results?
The CRAFTsynth really does sound amazing for what it is, but being able to play it with a keyboard (while untethered from the computer) would take it to another level.
