Roland D5 sounding weird...
Page 2 of 2 [29 Posts]
Goto page: Previous 1, 2
Jrichter
PostPosted: Sat Mar 28, 2020 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Treygreer, your advice worked for me.
Here’s how to load factory sounds thru laptop connected with midi. you’ll find the Roland SYS file at Rolands website here: https://www.roland.com/us/support/by_product/all/general_apps_tools/eac42271-4aef-4eed-ab46-d6b6ee6df208/
Next you’ll need to download midi-ox here: https://m-audio.com/kb/article/2060
Follow the loading directions for midi ox and also prepare the D-5 to receive the system exclusive dump. I assume you have done that before but here’s directions anyway: press Data Transfer then ‘display right’ to get ‘bulk load’ , press upper arrow to select then enter, remove write protect with write and enter.
glennonjd
PostPosted: Sat Mar 28, 2020 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Motivated by this thread and a reach out via a DM, I'll re-do my fix and try the capacitor.
Jritcher -thanks so much for the instructions on how to load the presets. I'll followed these to the letter but when I start that One-way Bulk Load and try to send the data:
- On MidiOX, it shows the data is being sent fine
- On the synth, it just stays on "Waiting" and never changes to "Loading"
Suspect it may be my midi interface - though midi seems to be working fine and the midi-self test on the synth say "OK" too. I'm on a PC with Windows 10 and a low-cost USB to midi interface - https://www.amazon.co.uk/gp/product/B07CC4B9L4/
USB plugged into the PC and the midi-out connector from this midi interface plugged directly into the mid-in of the synth. I can also connect the midi-in of the midi interface to the midi-in of the synth. I'm NOT using any midi cables between the midi interface and the synth - just plugging it in direct. All "looks" to be working fine - but something is wrong with my set-up.
Great to see people still taking the time to respond to the thread after all these years - thanks from a appreciating guy in Corona lockdown in Liverpool, UK.
John
StormLord11
PostPosted: Thu Apr 02, 2020 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Had the exact same problem with garbled/underwatery output due to pitch bend/mod wheel behaving erraticly, can confirm Treygreer's method worked perfectly.
matrix12x
PostPosted: Thu May 14, 2020 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
@glennonjd try a different MIDI interface or slow down the MIDI transmit speed of the sysex.
I've had an issue sending patches to this synth with cheap USB to MIDI interfaces.
I don't know if anyone's had this problem before, but I just swapped out my battery with a known good battery (I measured 3.5VDC) and I get the check battery warning. Any ideas? I wonder if one of the cables or something was left loose when I reassembled.
