Matching transistor procedure
Page 1 of 1 [4 Posts]
carlo64
PostPosted: Sun May 24, 2020 10:01 am    Post subject: Matching transistor procedure Reply with quote  Mark this post and the followings unread
in an old manual I found a procedure to match the transistors, maybe someone better than me can try the place!
emmaker
PostPosted: Mon May 25, 2020 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't know what you are asking. That is the standard Moog transistor matcher that a lot of people use. There is an error in the schematic though. There should be a 10K resistor between the 2N3906 collector and the PNP socket emitter just like the NPN tester.
These might of interest too.
http://ijfritz.byethost4.com/MiscProj/transmat001.pdf
https://www.muffwiggler.com/forum/viewtopic.php?f=17&t=228886&p=3219777&hilit=match+matching#p3219777
PostPosted: Mon May 25, 2020 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Highly recommend Ian Fritz' circuit linked above. Works well for me (and I have a little perf board with sockets and a power header kicking around for it somewhere!)
carlo64
PostPosted: Tue May 26, 2020 8:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't know this method, thanks!
Carlo
