PERFORMANCE
Posted: Sun Nov 15, 2020 2:04 pm Post subject:
This post might even be relevant to appear in the general DIY board since I suspect many people to be interested in RS works, right?
P.S.: I couldn't reactivate my more-than-a-decade old account over so don't blame me for being overly demanding for a newbie, hehe, theoretically I am not one.... |
crazeydazey
Posted: Mon Nov 16, 2020 2:08 am Post subject:
I know this circuit pretty well now I have studied it quite a lot, first with having to fix my own, then I decided I want to modify it, so I built it all on breadboard then started changing things to see what happens
it wasn't a massive success but I did learn a lot about the circuit.
I've not had much chance to look at what you've done, but the first thing that I noticed was that you might need to move it around a little bit, R4, R5 and R6 should all be 10k NTC temp co and should be bonded to T1 and T2, it will still work ok but will be more stable with 1V/Oct this way
I'll have a better look when I have a bit of spare time...
also (I think this advice is in this thread actually ??) - you need to make sure you put the invertors in the same order that Rene did as I think you can run into problems otherwise ?? I don't know as I have always made it the same way he says to, but unless you take that from the prototype design that's pretty difficult as he doesn't label the pins on the schematic...
yep found it ...
JovianPyx wrote: | I had asked Rene for help while I was developing the linear current sink for it. I was getting a nasty "hash" noise in with the sawtooth. Emails back and forth later, Rene gave me the exact pinout he was using. When I wired mine to match - problem solved, no more hash. He's helped me several times with experimental stuff. |
_________________ Nothing is impossible, unless you can't do it!!! |
PERFORMANCE
Posted: Mon Nov 16, 2020 9:07 am Post subject:
Quote: | I've not had much chance to look at what you've done, but the first thing that I noticed was that you might need to move it around a little bit, R4, R5 and R6 should all be 10k NTC temp co and should be bonded to T1 and T2, it will still work ok but will be more stable with 1V/Oct this way  |
Yeah, haha, I know I should use thermistors instead of regular resistors but for now i think I'll stick to the average ones...until my next order of supplies or my next visit to the electronics store. thanks anyway!
yep found it ...
AH, thanks for pointing that out! Are the exact pinouts to find anywhere? Since the individual Schmdit Triggers even in the schematic are ordered in sort of groups of three I wasn't even thinking about that (although I would have expected each does the same - but still it is just a CMOS-thing without proper opamps...).
Thank you so far![/quote] |
