Jurgen Haible's Morphing Programmer
vladosh
Audio files: 33
PostPosted: Sat Dec 12, 2020 10:06 am    Post subject: Jurgen Haible's Morphing Programmer Reply with quote  Mark this post and the followings unread
Jurgen Haible's Morphing Programmer ,it appears to be very cool module ,and not so many people have built it ,but the idea is more then something between panner and scanner ..and it prolly is fun to play ,i have not built this so i can not confirm it's operation , however i assumed that Jurgen's drawing is correct ,here's a pcb layout if anyone wants to give it a try ,the wiring for this would be a nightmare for some ,i re-checked the layout few times and it appears to be the Jurgen's drawings ,the pcb is big 175x105mm but maybe it will fit in 5U or as standalone controller ,i intended to make a standalone controller with it ,and this fits exactly in the enclosure i intended .
here's the wesite for this module along with schematics : http://jhaible.com/legacy/tonline_stuff/morph.html
 Filesize:  450.79 KB
 Viewed:  25 Time(s)
 Filesize:  298.39 KB
 Viewed:  16 Time(s)
