Nord G2 editor in 64 bit for Mac OS X Catalina
Page 1 of 1 [13 Posts]
xav
G2 patch files: 7
PostPosted: Sat Aug 03, 2019 9:20 am    Post subject: Nord G2 editor in 64 bit for Mac OS X Catalina Reply with quote  Mark this post and the followings unread
Hello everybody,
Does anyone have any idea of a solution to keep editing Nord G2 with Mac OS X Catalina, the new OS that only runs 64 bit apps?
Thank you for your tips
Xavier
Audio files: 262
PostPosted: Sat Aug 03, 2019 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
A virtual machine like VMWare maybe, apparently older OSX versions can still run then .. USB could be tricky then, dunno.
grimley
G2 patch files: 9
PostPosted: Tue Sep 17, 2019 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Surely somebody has "wine bottled" the 1.62 editor, no? I gave Wine a try but got completely lost in the configuration and didn't get anywhere. I do see that there is an older version of the editor on the Wine forum though (1.24 maybe?).
Sleep Distillery
Apeirophobe
337is
PostPosted: Sat Sep 28, 2019 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm curious about this as well. Getting to a point where I'll possibly need to freeze the OS of one of my machines to ensure I can still access the editor.
Burp
G2 patch files: 7
PostPosted: Mon Oct 07, 2019 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Same here, cause eventually i have to upgrade due too my work.
I tried it with parallels running Windows7, but couldn't get it to work.
Maybe best solution is a dedicated (cheap old) laptop for the G2.
if you don't know where you're going, you will allways arrive
Rudt
PostPosted: Mon Oct 07, 2019 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was able to get it working in Mac Mojave and using parallels. The secret I found was an extremely short usb cord. I also got it working using a star tech thunderbolt 2 hub. And that was using a slightly longer usb cable.
Burp
G2 patch files: 7
PostPosted: Tue Oct 08, 2019 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Definitely worth a try!
dorremifasol
G2 patch files: 49
PostPosted: Mon Oct 21, 2019 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Nowadays there are very nice chinese laptops and tables that would work well for dedicated G2 control. This one for example: https://www.amazon.es/CHUWI-Hi10-Air-Quad-Core-Bluetooth/dp/B07JB4S2QM/
Albert
RyanB
PostPosted: Mon Nov 30, 2020 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there,
I know this is an older post, but is there now a solution to get the Nord G2 Editor work on Catalina?
I try it with crossover but I can't get connection, cause I don't know the port name.
On the codeweavers page theres a distrciption how to get the port name but for me that didn't work. The terminal didn't show me any names of the ports only for my bluetooth controller.
For Infos here is the link: https://www.codeweavers.com/support/wiki/mac/mactutorial/usbtoserial2
Maybe someone made it by now!
Thanks,
RyanB
tendril ferris
PostPosted: Fri Dec 18, 2020 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love to hear any sort of update about this as well.
In the meantime, I'm happy to install bootcamp and dual boot; it's just a bit of an inconvenience. I will say that the list of apps I need to run on windows is growing by the minute as Apple dropped 32-bit support and many of these pieces of freeware/shareware/minimal-donation-ware were 32bit only.
t____
Burp
G2 patch files: 7
PostPosted: Wed Dec 23, 2020 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried CrossOver, but indeed, no hardware connection Sad
For now i use Parallels running Windows7 and the Windows Editor. Works perfect (on macOS Cataline).
xav
G2 patch files: 7
PostPosted: Tue Jan 05, 2021 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the information.
Parallels seems seems to be the only solution tested with success, isn't it?
Burp
G2 patch files: 7
PostPosted: Tue Jan 05, 2021 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as i tested, yes. And offcourse a dedicated old laptop.
But i'm very happi with the Parallels solution, it works perfect. And in coherence mode it's almost like a native mac app.
