 Forum index » Online Music
Music for lap top
Page 1 of 1 [7 Posts]
vladosh
Audio files: 46
PostPosted: Wed Jun 08, 2022 7:24 am    Post subject: Music for lap top Reply with quote  Mark this post and the followings unread
this is recorded with audiomulch ,just fooling around ,listen Smile
alternatively you can buy this at bandcamp for 7$ ,the sloppy artwork there is in color
 Filesize:  6.12 MB
 Viewed:  127 Time(s)
Nren.flac
 Filename:  Nren.flac
 Filesize:  143.32 MB
 Downloaded:  326 Time(s)
vladosh
Audio files: 46
PostPosted: Sat Jun 18, 2022 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
These were recorded in June - July 2020 ,the project originally was named Panda-Mix ,it was the summer when my neighbour was building his front yard ,usually after 2PM ,i left this project disappointed with no satisfaction . I found these recordings only 2 years later and really i haven't played them not even once ,they were to serve as raw material upon which i was to build a compositions of a kind . They are recorded using various software .Enjoy!
https://vladoshribski.bandcamp.com/
vladosh
Audio files: 46
PostPosted: Tue Jun 21, 2022 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile
vladosh
Audio files: 46
PostPosted: Tue Jun 21, 2022 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
vladosh
Audio files: 46
PostPosted: Sat Jun 25, 2022 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
vladosh
Audio files: 46
PostPosted: Sun Jul 03, 2022 6:53 am    Post subject:   Reply with quote  Mark this post and the followings unread
vladosh
Audio files: 46
PostPosted: Fri Jul 29, 2022 10:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is recorded using audiomulch and using it's x/y field for mixing ,it's always recycling materials from earlier and used some fancy vst's ,maybe not fancy enough .. This is type of sound installation that you will not remember ,you can't hum it and you can't dance to it ,small music made with big moves .
