Looking for MIDI Switcher that handles MIDI Clock
Page 1 of 1 [5 Posts]
Audio files: 40
PostPosted: Wed Mar 09, 2022 2:02 pm    Post subject: Looking for MIDI Switcher that handles MIDI Clock Reply with quote  Mark this post and the followings unread
Hello!
My MIDI Switcher is an old JLCooper Nexus 8x3 MIDI switcher.
It works ok however it does not work very well with MIDI Clock messages -- there are numerous dropouts.
I would like to find a MIDI Switcher that handles MIDI clock dependably and would like to know if you have any suggestions.
Currently when I work with clock signals, I have to exclude the MIDI switcher and patch directly to my devices. I like to change configurations and the limitation of my switcher has become an annoyance.
I appreciate any suggestions.
schaltstern
PostPosted: Sun Oct 30, 2022 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Kevin,
if you are tech-savvy, you could solve this with a RaspberryPi and a couple of cheap USB midi interfaces. You woud have to program this yourself (or find someone) but you have much more flexibilty this way.
I can confirm that this library in conjunction with NodeJS works perfectly with clock messages even on a Pi3:
https://github.com/justinlatimer/node-midi
Hope that helps!
Cheers, Dirk
Audio files: 40
PostPosted: Mon Oct 31, 2022 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info and the library reference.
Sometimes rolling your own is the best solution!
rEsrEs
PostPosted: Mon Nov 07, 2022 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
have you seen the MRCC
https://conductivelabs.com/mrcc/mrcc-880/
Audio files: 40
PostPosted: Tue Nov 08, 2022 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the info. Looks like a good solution.
