Joined: Apr 03, 2004 Posts: 24008 Location: The Netherlands, Enschede
Audio files: 274
Posted: Fri Mar 25, 2022 10:20 pm Post subject:
Version 2022.3.25.0 - and you can:
This release uses an installer - stiil - you must not install Wren in a µsoft owned folder (like program flies, desktop, whathaveyou). The installer may survive that though, but Wren still needs user writable files in the exe folder. The installer should warn about it  _________________ Jan
Audio files: 274
wikter
Posted: Sat May 21, 2022 11:23 pm Post subject:
HI, while trying to install last version my installation folder changed from C:\Audio\Wren to C:\bin\Wren
I reinstalled again to find the exe file because after the first install Wren didn't copied in the expected folder.
I think it may be corrected. |
Audio files: 274
Posted: Sun May 22, 2022 5:19 am Post subject:
Hi wikter,
Ah, so it goes a bit messy then ... saw you were in the chat too this morning .. I was still sleeping of course
Was it the first time you used the installer?
The current installer should - when you do an upgrade from within Wren itself (help menu) - install over the current Wren.
Howver, when the installer is used stand-alone (which unfortunately has to be done the first time the installer is used), it will not know where Wren is and you will have to tell it during the installation.
You can always solve the issue by copying all Wren files except Wren.ini to where you want it to be.
I'll run some tests here too ... later today ... maybe the installer could issue a warning or something when it can not find Wren, or show a dialog to help find the current Wren. _________________ Jan
wikter
Posted: Sun May 22, 2022 1:53 pm Post subject:
Hi, it was the first time installed in this machine and I specified c:\audio\wren (and also created a folder to avoid folder owner problems).
I installed it again because I was unaware of where my files went to and again the program changed the path after the second step of the installation.
I did a third "try" after moving & running Wren from the c:\audio\wren
The installer did that c:\bin\wren swap again. |
Audio files: 274
Posted: Sun May 22, 2022 2:13 pm Post subject:
Ah ok, thanks, I see what you mean now - it will indeed mess up the path and it has to be set again after selecting what must be installed.
And this is not what is intended - I will look at it. _________________ Jan
Audio files: 274
Posted: Sun May 22, 2022 2:49 pm Post subject:
Ok, I've updated the installer (to version 2022.5.22.0) and remade the depending installs (for the full installation and the pre-release) to contain the new installer version as well.
And - oh miracle - it was not immediately false flagged by bitdefender as a virus this time. Maybe I should zip the installer better ...
Anyways, I hope this will fix it  _________________ Jan
Audio files: 274
Posted: Thu Jun 02, 2022 6:54 pm Post subject:
another new one |
Aand another new one 2022.6.2.0 - I think it is about 30% faster than a while ago .. and some more stuff ...
Details are @ https://bluehell.nl/blogje/ _________________ Jan
John_W_Thompson
G2 patch files: 5
Posted: Thu Jan 12, 2023 6:20 am Post subject:
Blue Hell I have lost track and have a stupid question. Could one say Wren is sonically the same as Nord Modular G2? Or is it a do not compare situation. Thanks sir. |
Audio files: 274
Posted: Thu Jan 12, 2023 5:48 pm Post subject:
John_W_Thompson wrote: | Blue Hell I have lost track and have a stupid question. Could one say Wren is sonically the same as Nord Modular G2? Or is it a do not compare situation. Thanks sir. |
Sure! One can say just about everything!
And nowadays .. oh damn .. let me keep plottix out - just be sure to vote the right thing . erm left thing .. next time
But anywway ... eh .. eh .. I've never tried to make Wren sound like a Nord.
Hmm and that is not 100% true .. just 0.327% or so ...the OSC1/OscPercCS module .. i've made that one listening to Nords!
So eh .. the short answer is : No  _________________ Jan
Audio files: 274
Posted: Thu Jan 12, 2023 5:52 pm Post subject:
Oh and btw it is at 2022.12.4.0 now, version wise : https://bluehell.nl/
The blog has some update / revision news .. overall though .. I think Wren to be be finished!
I'm out of ideas and out of plans .. i use it .. just that .. use it :) _________________ Jan
John_W_Thompson
G2 patch files: 5
Posted: Fri Jan 13, 2023 9:51 am Post subject:
THANKS SO MUCH! |
Audio files: 274
Audio files: 705
Audio files: 274
Posted: Thu Feb 09, 2023 2:12 pm Post subject:
PHOBoS wrote: | Blue Hell wrote: | I think Wren to be be finished! |
amazing piece of work!
maybe I'll play around with it again someday, but I don't seem to get along with softsynths very well. |
Hah, thanks pho
And .. you know .. even when my apartment maybe is, I think, slightly larger than yours .. I do not have that amount of space that you have for hardware
Also .. the 2023.2.7.0 fix was not ok yet .. made a 2023.2.8.0 as well to repair inputs better  _________________ Jan
