Audio Input?
Page 1 of 1 [6 Posts]
Octave-Shift
PostPosted: Wed Jan 25, 2023 7:36 am    Post subject: Audio Input? Reply with quote  Mark this post and the followings unread
Hello @BlueHell and everyone else.
I tried my best to make external audio input work but I can’t get it done. Is it possible or am I missing something here?
Input itself is working as I can see the level meter inside Wren, but I cannot get a connection to actually hear anything. I tried patching the input module directly into the output module but even then… nothing happens.
What can I do and how can I solve this?
Thanks a lot for your hard work programming all this, it is so amazing.
Edit: I of course did assign the ASIO driver‘s in- and outputs to each in- and output to the individual ones in the menu. I use a Focusrite Scarlett and I use their ASIO. Even if I change the order nothing happens. What I forgot to tell is that the program crashes as soon as I start the audio test. Happens with any configuration and driver. But as I can hear the patches I thought that might be a tiny bug not too important for working inside the synth. Smile
Airlock
Audio files: 50
PostPosted: Wed Feb 01, 2023 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try pressing "run," it'll work.
Cheers!
Octave-Shift
PostPosted: Sun Feb 05, 2023 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Smile
First of all: Thanks for your reply to that absolutely noob-question.
Indeed as soon as I press "run" the input-meter shows that there is input on channel x (in my case input channel is 6, it wont work on 5 either.)
I took a screenshot, I hope it speaks for itself. I can hear the oscillator on channel 1 but i cannot hear any input audio from channel x (6) on output 1 or 2 as it is patched.
help
I feel dumb and a bit lost here Embarassed
 Filesize:  227.93 KB
 Viewed:  6 Time(s)
Audio files: 273
PostPosted: Sun Feb 05, 2023 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't - you may just have found a bug Shocked .. will look into it soon.
Audio files: 273
PostPosted: Yesterday, at 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, after looking I can confirm that audio in is not working properly ... trying to find a reason ...
Octave-Shift
PostPosted: Today, at 6:58 am    Post subject:   Reply with quote  Mark this post and the followings unread
After literally hours of trying a few weeks ago and again the last week or so I just HAD to ask if there’s solution because I thought I had tried it all.
Many people including me definitely appreciate your work AND for spending more hours rechecking this even though I understand you didn’t want to anymore. It’s so cool you’re going to devote more time into it.
The linkage between Wren as a virtual and another “real” (you know what I mean) instrument and controlling both vice versa expands all the features of each even more. I tried a Doepfer Dark Energy as my source and wanted to control it via its audio in from Wren. Maybe it’s possible to do so.
Smile
