Noise Oscillator
Page 1 of 1 [10 Posts]
G2 patch files: 626
PostPosted: Wed Sep 28, 2005 2:08 am    Post subject: Noise Oscillator Reply with quote  Mark this post and the followings unread
Am I missing something? The noise oscillator seemed very promising, the inexpensive choir and a great Lesley organ effect. But I can’t seem to find any other use for it.
Anyone got some tricks to share or is it just a two trick pony?
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Sep 28, 2005 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
It's very handy for synthesizing mosquitos.
mosquito.pch2
this patch does exactly as it says -or your money back!
 Filename:  mosquito.pch2
 Filesize:  835 Bytes
 Downloaded:  1742 Time(s)
Axiom
G2 patch files: 28
PostPosted: Wed Sep 28, 2005 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I use a lot them as impulses to filters when I want to use their self-oscillation capabilities as sine wave replacement. I my latest hammond patch i've replaced standard sine oscillators with filters driven by a noise osccilattor. The possibility to set its width has been very useful to me to soil the hammond sound.
Here is a short sample:
Download MP3
Luca
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
AngusHastie
PostPosted: Wed Sep 28, 2005 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Quite useful for percussive sounds like the snapping sound in this clip (bit of modulated delay, reverb and chorus also added)...
Noise osc for percussion.mp3
 Filename:  Noise osc for percussion.mp3
 Filesize:  313.78 KB
 Downloaded:  1139 Time(s)
G2 patch files: 626
PostPosted: Wed Sep 28, 2005 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey that is good, back off the mod level and increase the width and it makes a pretty good slipping fan belt as well.
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Sep 28, 2005 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
sheridan
Audio files: 27
PostPosted: Wed Sep 28, 2005 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I have used it for sound design patches (to save on filters), and percussion sounds... so, the same as these guys basically. Also, you can get some nice sounds from the narrow band noise, when overlayed with synth type sounds, to brighten the attack for instance, or when frequency modulated.
Personally, I would have preferred it if the noise osc could go from one extreme to the other, ie. to full band noise at one extremity.
transformer Sheridan
Audio files: 278
PostPosted: Wed Sep 28, 2005 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I've used 'm to FM / PM other oscs, better than plain noise but kind of expensive.
davep
Audio files: 10
G2 patch files: 73
PostPosted: Wed Sep 28, 2005 4:48 pm    Post subject: Re: Noise Oscillator Reply with quote  Mark this post and the followings unread
I've used it on several patches with good results. Try using two or three of them tuned to higher harmonics of the main oscs in the patch (like 4:1, 6:1 and 8:1) and mix in just a bit of them on top of the main oscs. Really nice if the signal is being passed through phasors of chorus modules later in the chain. You can get some really lush breathy rompler-type sounds.
48 hours 'til I'm cruising up the Mekong, sitting in a wicker deck chair with some really strong Vietnamese coffee and watching the passing jungle...
Dave Peck
Audio files: 278
PostPosted: Wed Sep 28, 2005 5:15 pm    Post subject: Re: Noise Oscillator Reply with quote  Mark this post and the followings unread
Thought you were there already, in the middle of a typhoon ...
And a patch using the noise osc multiplied by some other oscs as the main sound source. It gives some grain like sounds here.
05-013-003.prf2
noise osc multiplied by other oscs
 Filename:  05-013-003.prf2
 Filesize:  8.59 KB
 Downloaded:  2384 Time(s)
