Copy and paste of modules names
Page 1 of 1 [7 Posts]
Being able to copy and paste module names is...
Essential
60%
 60%  [ 3 ]
Frivolous
40%
 40%  [ 2 ]
Total Votes : 5
zinoff
PostPosted: Sun Nov 27, 2005 4:13 pm    Post subject: Copy and paste of modules names Reply with quote  Mark this post and the followings unread
In the editor, I couldn't find a way to copy and paste names for modules in the little module name text box, how about you?
jamos
G2 patch files: 41
PostPosted: Sun Nov 27, 2005 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Same as any other Windows program:
1) Click the name for editing
2) When the text editor appears, right click and select Copy
3) Go to the place you want to paste the text and repeat steps 1 and 2, only select Paste rather than Copy
zinoff
PostPosted: Sun Jan 08, 2006 6:55 am    Post subject: Je sais - wouldn't it be nice... Reply with quote  Mark this post and the followings unread
It'd be nice if it worked.. but it ain't working over here.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Jan 08, 2006 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, Ctrl+C & V don't work as well. They must have subclassed the edit control and somehow screwed the clipboard.
Audio files: 279
PostPosted: Sun Jan 08, 2006 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
CTRL+C, X, V indeed dont (and necer have) work(ed), but double clicking to bring up the edit window then right clicking to pop up the context menu and selecting Copy/Cut/Past works here, and AFAIK it always did (I run a beta, so can't be really sure for the current production version).
I'd like the CTRL shortcuts to work as well though.
Is it a Mac issue maybe ?
jamos
G2 patch files: 41
PostPosted: Sun Jan 08, 2006 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, it's a Windows problem as well. Special code needs to be called for an edit control to support the clipboard shortcuts; apparently Clavia didn't add that code.
cappy2112
PostPosted: Sat Jan 14, 2006 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Is this compiler dependant? Does this only happen with standard Microsoft edit boxes?
