Problem with bouncing tracks in Logic 4
Page 1 of 1 [5 Posts]
bleep
PostPosted: Thu Mar 02, 2006 7:26 am    Post subject: Problem with bouncing tracks in Logic 4
Subject description: negative amount of memory needed???
I have quite an ancien set up: Logic Platinum 4.7 on Powerbook with OS 9. Has served me extremely well for years. But, last night, for some reason, it stopped working for me.
I can't bounce! It says that it needs "-3,3 MB of free memory"
How can it need a negative amount of memory? Or am I too dumb to figure out what that means?
And when I click OK to save my track as an aiff file, it says not enough memory on the hard drive (although I have 8 GB free).
Anyone knows what to do? Please help ASAP - I have no money to upgrade the system!
Thanks.
http://www.bleeptunes.com
paul e.
PostPosted: Thu Mar 02, 2006 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
igor....that is a strange one....can't think of anything at the moment...will keep pondering this...
do you have an old copy of your prefs ?
is your drive partitioned?
i am personally leaning toward an OS issue and not Logic
do you have an external drive ? try exporting to that
anyone else ?
Spiral Recordings
klangumsetzer
Audio files: 31
PostPosted: Mon Mar 06, 2006 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
try double-clicking on the number beneath the tempo/time signature in the transport bar. this will reorganize/defragment the computer's ram.
hope this helps
best regards
eike
PostPosted: Mon Mar 06, 2006 12:51 am    Post subject: Re: Problem with bouncing tracks in Logic 4
I haven´t used Logic with OS9, but if you get a message specifically telling you that the disk is full, then you just might have a disk problem and it could be that it is also extremely fragmented. The disk problem could simply be a corrupted directory.
Have you used this computer for years without ever defragmenting the disk? You could be looking at least 2 problems here. On the other hand, maybe noodulators advice will work. It could be the ram, and not the disk? I dunno.
Flickr
PostPosted: Mon Mar 06, 2006 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh good old OS9!
Try trashing the preferences (logic).
Then rebuild the desktop.
Keep a spare copy (of the preferences) just in case that doesn't work- because you will have to set everything up again Shocked
