Do we want more inter slot busses? |
No thanks, 4 is enough. |
12% |
[ 3 ] |
Hmmm... I'd like some more audio busses please. |
4% |
[ 1 ] |
Those control signal busses sound like a good idea... yes please! |
25% |
[ 6 ] |
I could do with more audio AND new control signal busses! |
58% |
[ 14 ] |
Total Votes : 24 |
Joined: Apr 03, 2004 Posts: 24396 Location: The Netherlands, Enschede
Audio files: 296
Posted: Sat Mar 11, 2006 3:04 pm Post subject:
selvmarcus wrote: |
May be the crossfaders as DIY sample and hold
behave not so well, sometimes. Will try this.
One could exchange the other ones for valswitches and use the
"standard" logic inverter as clock, as they didn´t work
together with my level converter clock for some reason.
Oh, come to think of it .. I did have problems with the cross fader in the delay line multiplexer as well & got 'm out ... sory, could have remebered that earlier :-) _________________ Jan
selvmarcus
Joined: Feb 08, 2006 Posts: 121 Location: Berlin, Germany
G2 patch files: 39
Audio files: 296
Posted: Sat Mar 11, 2006 3:49 pm Post subject:
Much better, it works !
I'm going to make a building block item for the long delays, may I invite you Marcus to do so for the multiplexers ? I'll put some linking in the new and old threads then.
Things are geting out of bounds a bit for this thread maybe.
Edit : also see : http://electro-music.com/forum/post-7076.html _________________ Jan
selvmarcus
G2 patch files: 39
Posted: Sun Mar 12, 2006 8:16 pm Post subject:
I´m working on it...
I figured out inter-slot sync *is* needed sometimes.
You´ve been right, of course.
This is the solution I came up with so far.
The other perf is the corrected 8 channels diy multiplexer
for the interested (without the extra sync yet).
Should this go to Experimental Forum for now?
Feel free to move it.
Marcus
Description: |
Experimental perf sending signals of 8 voices to fx area using multiplexing ( 4 pairs ). All clocks are synced by sending a click on bus1 at patch activation. |
 Download (listen) |
Filename: |
8voices-to-fx.prf2 |
Filesize: |
4.09 KB |
Downloaded: |
1180 Time(s) |
Description: |
DIY 8 channel audiorate mux/demux (12 kHz sampling for each channel) |
 Download (listen) |
Filename: |
8audio-ovr-bus1+.prf2 |
Filesize: |
7.01 KB |
Downloaded: |
1070 Time(s) |
Audio files: 296
Posted: Sun Mar 12, 2006 8:49 pm Post subject:
selvmarcus wrote: |
I thought it would be a nice one for the building blocks section. I'm feeling lazy though right now (hell its about time I went to bed ), so when you still have some energy left ... hint ... hint
Too bad the asynchroneous syncing, so to speak, dont work. I'll check the patches later, tomorrow or so. _________________ Jan
Audio files: 296
Posted: Mon Mar 13, 2006 4:26 pm Post subject:
Ok, had a look at the patches.
The topmost indeed has some channel mixup/bleeding.
Thought the 2nd one was not working ... but having a better lookI found a bad audio cable :-(
The sync click is pretty smart ! And as it's only once at patch startup it could be sent even over the same bus line as used for an audio signal (just make it !LOUD!).
Nice as well to see the voice allocation at work. _________________ Jan
3phase
G2 patch files: 141
Posted: Mon Mar 13, 2006 11:46 pm Post subject:
wow...One at first non patch related discussion leading to breakthru new tricks for the G2 *applause* ..thats the way i like it...
thanx... |
selvmarcus
G2 patch files: 39
