Gothboy
Joined: Feb 21, 2006 Posts: 369 Location: Santa Monica, Ca.
Posted: Mon Mar 20, 2006 7:50 am Post subject:
Setting up Softsynths in OMS |
Can anyone please fill me in on how to setup a softsynth in OMS. I'm using OMS 2.3.8 in OS 9.2.2. I understand fully how to add a hardware synth in OMS having done it about a thousand times, but for some reason can't quite get my head around this one partly beacause the synths' manual info is so sparse on the subject! There's a Midi in and a Midi channel select from the drop down menu in the synth software and THAT'S IT! Do I use the IAC bus as the midi in, for instance? Do I have to add a device in the OMS setup? None of this is explained in this manual Plus it's an old, no longer supported product. So I guess what I need is a Softsynth/OMS 101 course. It's probably easy and I'm just missing it. Any help would be great. _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Novation SL49/Remote Zero
Mophox4, Nord Lead 2, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE
"We are the music makers and we are the dreamers of dreams"
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ |
Posted: Mon Mar 20, 2006 7:55 am Post subject:
Softsynths usually won´t show up in OMS. Mostly they are inside a host, like Cubase 5.x or similar. Standalone apps have their own midi settings, like B4 and Pro 52. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Gothboy
Posted: Mon Mar 20, 2006 11:54 am Post subject:
So how do I get it to show up in the Pro Tools list of instruments in a Midi track? _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Posted: Mon Mar 20, 2006 12:34 pm Post subject:
Any PT users here? When I still was on 9, I used Steinberg Cubase 5.x VST 32. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Joined: May 16, 2005 Posts: 8933 Location: Birmingham, England, UK
Posted: Mon Mar 20, 2006 4:07 pm Post subject:
Re: Setting up Softsynths in OMS |
Gothboy wrote: | for some reason can't quite get my head around this one partly beacause the synths' manual info is so sparse on the subject! |
The info is all there- it looks brief but it does make sense and it's actually easier than you think. Trust me
What midi interface are you using? |
Gothboy
Posted: Mon Mar 20, 2006 6:17 pm Post subject:
M-Audio 8X8 Midisport _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Posted: Tue Mar 21, 2006 2:22 am Post subject:
Oh no- not the midisport!!
I had nothing but problems with the smaller version- no actually I tell a lie- it worked flawlessly for a while then one day it just 'died'!
If you can find one, the best cards are the PCI ones- not the usb ones. _________________ ACHTUNG!
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Tue Mar 21, 2006 7:38 pm Post subject:
not exactly sure about Pro Tools
but in OMS setup [which i presume is in PT's], make sure you have all ports checked off as inputs ....
i assume you will be triggering the softsynth from a controller..if so, make sure the port number that corresponds to the controller's midi input on the MIDIsport, is selected on a PT's track _________________ Spiral Recordings |
